Question about Whirlpool Duet GHW9150P Front Load Washer
I cannot get washer to restart after adding a garnet
  • 22 Answers
Switch off at plug then try to restart by draining machine then restart cycle again
Posted on Jan 03, 2013
Kenmore 11025102310 washer isnt working. I press the start button, and the sensing button lights up for just a second and there is a couple of minutes of a grinding type of noise but then nothing.
SENSING Page 5
When the START/PAUSE/Unlock Lid is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer will use short, slow spins to estimate the load size. These sensing spins may take 2 to 3 minutes before water is added to the load and you may hear the hum of these spins. If the sensing light is on, then washer is working properly. You will hear the motor turn the basket in short pulses to thoroughly wet the load. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: Avoid opening the lid during sensing. The sensing process will start over when the washer is restarted. The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
If there's no water, then Page 13
Washer won't run or fill, washer stops working, or wash light remains on (indicating that the washer was unable to fill appropriately)
Check for proper water supply.
Both hoses must be attached and have water flowing to
inlet valve.
Both hot and cold water faucets must be turned on.
Check that inlet valve screens have not become clogged.
Check for any kinks in inlet hoses, which can restrict water flow.
Or you have an inlet valve that is not working
Apr 29, 2016 | Kenmore Washing Machines
How do you stop the cycle immediately after starting (found a sock that needs to be added in the washer) and then re-start wash cycle
You can only add items to the wash for a few minutes after that washer starts. If you found something you want to add you have to restart the cycle. This is a safety feature added to the front load. After the washer is full of water it doesnt allow the door to open so the water in the machine doesnt flood you laundry room.
Jul 15, 2011 | Asko W6021 Front Load Washer
I can't get the washer to run for more than 4 minutes regardless of choke position. When trying to restart, there is pressure that builds and I must release before restarting
the carb needs to be cleaned as well as the fuel tank,ad a gas stable product to the fuel.standing fuel causes these problems
Jun 12, 2011 | Homelite Garden
My Garnet Pro 200 tube guitar amp has low volume
You must first isolate the stage that is causing your problem. Start at the master volume control by injecting a signal using a screwdriver. If you get a good level of hum from the speaker then output and phase splitter stages are ok. Work your way back to the front end by touching the screwdriver to inject hum into the input grid of each valve in turn to isolate weak stage. Check anode and cathode voltages on valve of suspect stage. Check cathode bypass capacitor and anode/grid coupling capacitor for open circuit. If fault in output stage check screen grid resistors for open circuit. WARNING high voltages exist in valve amps, keep one hand in your pocket and do not hold on to the chassis while testing.
Feb 21, 2010 | Audio Players & Recorders
Pushed pause. Added garment. Washer will not start again.
possible you have not held "start" button down for the required 5 sedonds to restart cycle??
May 16, 2009 | Kenmore Elite 45986 Front Load Washer
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Won't restart or clear off
try unplugging for a few min adn replug see igf that clears the computer, you didinbt by chance force the door open to addd a garment didi you??? if so the door lock has probalby beed compromised
Apr 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
