Question about Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon Rebel 35mm - Line down centre
I have had no problems since getting the camera over 10 years ago. All of a sudden though I have been getting photos with a terrible line down the centre. It shows up clear on the negative and doesn't always show up on every photo once developed. Any ideas?
  • 1 more comment
  • bclm Jan 22, 2009
    Here is one of the photos...
  • bclm Jan 22, 2009
    I will head back to the lab. Thanks for the great in-depth response. Fingers crossed that you're right about it being the lab. Phew!
  • Gordon Stalker
    Gordon Stalker May 11, 2010
    Can you upload a scan of a neg with this problem?
    Scholar:
  • 58 Answers
This looks as if the negative has been scratched by the minilab processor. It could be scratched in tha camera but with this camera there are only two places this could happen resulting in this kind of scratch.
One is the film cassette itself, the other is the take-up spool, where the film is wound onto itself. However this would not be likley to create a scratch affecting more than one or two negs.
Colour film has a built in orange filter which compensates for the excess sensitivity of colour papers to blue. If this is scratched away, then more blue get's through which prints yellow.
The processing machine uses sqeegee's to prevent carry-over of chenicals form one bath to another, and damage or contaminaton of any one of these can scratch the negative. This is much more likely during processing, as the emulsion is softer when wet.
Films usually have a protective anti-scratch layer, but the protection is not 100%. Also develelped emulsion is generally harder than undeveloped as the last development stage often contains chemical hardeners designed to give extra protection to the negative.
The reason it may not show on all the prints is simply that these days many colour film is printed by digital scanning. Many scanners can detect scratches by viewing the negative in infrared light. Photographic dyes are transparent to infrared in order to reduce heat absorption from enlarger lamps, so there should be no image visible in infrared, anything that is must be dust or a scratch. The image can them be processed to compensate for the scrathes making them virtually undetectable.
A thin scratch may be filled in by using pixesl just either side of the scratch to fill the scratch in. With a wider scratch, if there is some residual image then the software can use that and nearby unscratched areas as a guide to make an acceptable guess as to what was supposed to be there. If the scratch is too wide and too deep it will just give up. A bodged attempt may end-up worse than the scratch. (Often a skilled touch up artist can make it dissapear, but machines on their own are not that smart yet.)
So the good news is that your camera is unlikely to be at fault.
If this shows on one film or a batch of films processed at the same time, take them back to the processor. (I have done this before and been paid a fair amount of compensation. If they printed them at the same time it should be obvious that the negs were scratched before you took them home.)
On the other hand if this is showing on films processed at the same place over a period of time then don't use them again.
If this is happening no matter where you get the film developed, then you might need to check you camera!
Posted on Jan 22, 2009
  • Gordon Stalker
    Gordon Stalker Jan 22, 2009
    I would not worry too much about the camera.
    I run an eBay shop and EOS Rebel bodies are ridiculously cheap right now. I have sold three or four in the past 12 months each for under £30.
    These particular cameras do not seem to suffer from the problems which have affected some of the EOS range, such as sticky shutter syndrome. It sometimes strikes me as strange that often the less expensive cameras from a particular manufacturer are the ones which keep going without any but the most basic maintennance, where thier more expensive cousins do not.
I have a canon rebel XS. It's about a year and a half old, so i am pretty choked it isn't working properly. Awhile ago i noticed i was getting an error 99 message every now and then on my camera...then it...
You have to take it to service center to determine what the error 99 code is this could be to many problems to list, It has to be hooked up to a computer to solve.
Oct 27, 2010 | Canon EOS Rebel XS 35mm SLR Camera
My canon xr rebel switches on, focuses but will not fire or display!
dear sir,
the first suspect is your battery,ahich is running in low battery....kindly recharge the battery for few hours and then put your camera on........ also the problem can be because of the rough moving of lens in and out because of accumulation of dust and lint inside,which cause this problem.
next,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest canon service centre
thank you.....take care................
Oct 06, 2010 | Canon EOS Rebel XS 35mm SLR Camera
The shutter on my canon rebel 2000 jams and low battery lite coms on, can it be fixed?
Not realistically. Your EOS 300 (US=EOS Rebel 2000) was sold as a "consumer" camera. This means that it's built down to a price (it was actually designed and manufactured by Kodak on Canon's behalf) and was never intended to be repaired once out of warranty.
The camera will be around ten years old now and spares support was poor even when it was a current model. All but the most minor repairs under warranty consisted of throwing the camera away and sending the customer another one.
Although what I've told you may be disappointing, the cloud has a silver lining: you can get these for next to nothing on auction websites now and certainly for nothing on FreeCycle and Freegle; that's where I get most of my Canon and Nikon 35mm equipment from. High end models do still retain some value to both users and collectors, but any Canon EOS triple digit model/Rebel is never going to be of any real value unless it comes with non-standard lenses or other sought-after accessories.
Feb 11, 2010 | Canon EOS Rebel 2000 35mm SLR Camera
Film is not loading in my Canon EOS Rebel G...i've had this camera for a few years, but haven't used it for a while.
The camera has a capacitor to hold a charge for the shutter and the auto focussing modes. Usually when they get ten years and older they dry up and crack open. When that happens the camera will not operate
Jul 20, 2009 | Canon EOS Rebel G 35mm SLR Camera
Black line across top of all my developed pictures
You have light leak somewhere to the film.
Usually from the bad film door seal.
Mar 29, 2009 | Canon EOS Rebel GII with 35-80 lens 35mm...
ERR CF
The pins inside the camera may be damaged. Use a flashlight to check inside the slot where the card goes
Mar 16, 2008 | Canon EOS Rebel G 35mm SLR Camera
Replacement Film Door for Rebel Ti
You should be able to get that part direct from Canon USA. Here is their info: For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
Jan 08, 2008 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Quantary 100-300mm telephoto lense
I have been researching this problem and found there's nothing you can do. Appararently, the quantaray, being an older lens, wasn't made to work with this latest era of cameras. Though it might work perfectly with your older camera, its technology is outdated as it relates to digital cameras and can't mesh with the latest and greatest. By the way, most of my questions were answered on the Digital Camera Resource page (www.dcresource.com)
Jul 25, 2007 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Canon EOS Rebel Ti / 300V 35mm SLR Camera Logo
115 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
