Question about Whirlpool GGQ8831L Gas Dryer
Black spots in cloths after drying
Hi.
I have a whirlpool gold series II, Recently I'm getting my cloths with
something like black spots after use my dryier.
The drum is all spoted too and the heat exaust as well. I had cleaned several times but problem appers again after some weeks.
Can someone please help me
    President:
  • 1,214 Answers
Gas or electric dryer?
If gas, I would be suspect the black spots are carbon, which, based on your describing that when you clean the interior of the drum, the spots return, is coming from the burner area.
1) If the above is correct, then call quit using the dryer serviceman immediately before continuing use.
2) If your handy repairing things, you will need to remove power from the unit, and access the combustion chamber from the backside of the appliance for cleaning.
This will be a messy job, as carbon black is messy. It comes from incomplete burning of the gas as it goes into the combustion chamber. This is normally caused by restricted airflow into the combustion chamber, and that cause is difficult to identify without looking at the unit. Best thing is to just clean the unit up real good, removing any lint buildup and carbon that can be found, and confirming that the proper orifice is installed (is this an LP dryer operating on natural gas, or vice versa.). Once cleaned and all repairs made, you will need to operate the dryer with old, clean rags in the drum for several cycles until you are certain any residual carbon has been blown through.
Posted on Jan 19, 2009
Whirlpool Quiet partner V Dishwasher will not start no lights ,,,nothing
Try unlatched door and hit heated dry, normal, heated dry, normal all within 3 seconds of each ither. Close dior, latch and try again.
Mar 02, 2015 | Whirlpool Gold Series Quiet Partner Iv...
Copies of documents are not clear
Spots on copying: Chk is there any marks on flat bed glass?,clean flat bed glass with wet cotton cloth, allow it for dry.
Spots on printing: There is no particular reason for this issue. clean paper path with wet cotton cloth & allow for dry..
Mar 18, 2013 | HP Deskjet 2050 All-in-One Printer
Dish washer lights dont work and will not run
Prabably no current running throught the dishwasher or a breaker or
somethings disconnected also the button or turn on or off switch mmay be bad
Aug 23, 2012 | Whirlpool Gold Series 24" Tall Tub...
Whirlpool gold GT4175SPS-2 inside door paint is flaking and revealing metal. Is it safe to use?
Scratches, flaking and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord first.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
May 09, 2010 | Microwave Ovens
Whirlpool gold series replaced element clothes still do not dry in one cycle
Howdy: A firing ignitor tells the element to heat up. It seems that the ignitor is shutting off too soon. It also could be the timer . Doug
Dec 09, 2009 | Whirlpool Dryers
Whirlpool dryer gold not drying clothes
  • Check for proper air flow
  • Check the ignitor
  • Check gas jet
  • Test the gas valve coils
  • Check the flame sensor
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the temperature selector switch
  • Here is a website to aid with these tests
    http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
    Nov 11, 2009 | Whirlpool GEW9250 Electric Dryer
    When washing i get dirt all over my clothes
    Could be oil from a leaky bearing. try flushing out machine 1st to try to cure...Good luck...
    Oct 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    I have a whirlpool gold ultimate care II electric dryer and have to dry everything on high twice to get it dried. any suggestions?
    first how is the clothes out of the washer? That might not be spinning fast enough in final spin. When was the last time the dryer vents was cleaned. Do you have a flow out the vent? If so then something might be going on with sensors.
    May 18, 2009 | Whirlpool GGQ8831L Gas Dryer
    My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
    HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
    Oct 07, 2008 | Dryers
    Whirlpool GGQ8831L Gas Dryer Logo
    78 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
