Question about Cell Phones
I have a lg l85c and it wont start up. it just keeps going to the tracphone service page
Is there a reset button?
Lg phone won't turn on. It pulls up the LG logo, after several minutes it makes the start up tone and the blue TracPhone page appears, that's where it stops
You can try a factory reset, I don't know the model, but here is the usual LG reset routine
Ensure the device is powered off.
Press and hold the Volume Down button then press and hold the Power button.
When the System recovery screen is displayed, release both buttons.
From the System recovery screen, select Factory data reset.
Note Utilize the Volume buttons to highlight and the Power button to select.
Select Yes to confirm.
Note Allow several minutes for the reboot process to complete.
Note To set up the device after completing the factory data reset, refer to Initial Activation and Setup.
Sep 22, 2017 | LG Cell Phones
I NEED TO ACTAVATE A NEW CELL PHONE
You have to speak to customer service to do that because it isn't a straight activation.
New phone.
Keep Old number
Transfer minutes.
http://www.lg.com/us/tracfone-phones
Feb 10, 2017 | LG Cell Phones
LG Sunrise from Tracphone won't start up.
Hold the Home Button or On/Off and Volume UP button for 5 seconds. Should perform a soft reboot.
Sep 30, 2016 | LG Cell Phones
Have a LG tracphone and the language is on Spanish, need to change to english
Kurtis, attached links will tell or show how to switch language on tracphone. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Languages on TracFone eHow
How to change language back to english on my tracfone
accidentally set my tracfone voicemail to Spanish apparently on an LG...
Jun 14, 2016 | LG Cell Phones
Keeps showing lg screen and flashing
Android is corrupted. You need to factory reset it. Hold volume down and home buttons while turning it on. You can let go of those buttons once the screen changes to the Android loading icon.
This will erase everything from your phone - so good idea to keep things backed up for incase it happens again.
Near as I can figure, this happens when:
- phone battery is allowed to die
- pull battery from phone when it is still shutting down (hard to tell when it's finish)
Dec 28, 2012 | LG Optimus Net P690 Touchscreen Android
Waste ink reservois is full
Hi
The waste ink are in the inside of your printer you need to get at it to clean out, but after this you got to reset it after you cleaned it or it will still not work, you may not have to get inside to clean it try this first to reset it.
Reset CANON PIXMA IP5000 printer To reset the counter or to find out about it’s reading you have to use the service mode.
Turn off the printer, push the resume button and keep on pushing.
Press the power button and keep on pushing. Now let go off the resume button,
but not the power button. Push the resume button twice, then let go off all buttons.
You are now in service mode.
To leave the service mode, give the power button one push.
Push the resume buttons once, after that the power button once.
The first information page appears.
Push resume twice, then power once: You get the second page.
Newer PIXMA-printers print the first page as a test for the nozzles.
The second page contains a lot of information.
Our advice: Print the second page before and after reset of the waste ink counter.
Only then can you be sure that the reset was a success.
To reset the waste ink counter right now, push resume four times and after that power once.
Important: Before starting with normal printing again, switch off the printer.
That gets you out of service mode.
Then switch on the printer again and print, as you like
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Absorber reset code for pixima ip5000
Hello there here is the codes.
Jan 19, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Will not power back up.
Hi
Jan 05, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
My phone says "service unavailable" help!!!!! No incoming or outgoing calls can be made
Service unavailable mean you don't have any network. Check with your service provider if they have barred your service or not. This has nothing to do with mobile phone. If there will be no services from your service provider you will not be able to call or send message or receive calls.
Summary: Check once with your mobile service provider.
Dec 28, 2008 | LG Shine 720 Cellular Phone
Cell Phones Logo
51 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
