Question about Siemens Dryers
Have a siemens TXL 1400 that is pumping out cold air rather than hot.... my clothes are soaked -have cleaned filter but nothing! Anyone??
TXL 1400
scottowa
  • 87 Answers
SOURCE: Clothes dryer (Kenmore) only blows cold air
What is the model number on the inside by the door. It's most likely a thermal fuse or the element. Do you have a way to check fuses by a meter or something? There are usually 2 thermal fuses on the pipe with big red wires where the element is. Usually they go out if not the element.
Posted on Apr 13, 2009
SOURCE: Whirlpool electric dryer. Clothes stay soaking wet
You were absolutely right about it being a venting issue. Although we thought we had it all cleaned out there was still a ball of lint blocking the air flow and causing the problem.
Thanks for your help.
Clint
Posted on Apr 15, 2009
yecalam13
  • 41 Answers
SOURCE: Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Posted on Jul 30, 2009
  • 1738 Answers
SOURCE: My dryer isn't blowing hot air
Your heating elements has blown, or you are not getting full 220 to the outlet only 110.
Posted on Aug 11, 2009
  • 180 Answers
SOURCE: my dryer is only blowing cold air and not drying
Probably either the igniter or the gas valve.  They are both located in the front on the lower right.  You will need to remove the top of the machine and the face to get to them.  Take the switch out of the door, tape it so it thinks the dryer is shut and plug it back in.  The igniter needs to let a certain amount of current through to open the gas valve.  The easiest way to check it is to run the dryer and see how bright it glows. If it's not almost white replace it.  If it doesn't glow at all check to see if it is getting power.  If it isn't you will need to get someone to look at the control board.  If you recently moved make sure your gas pressure going to the dryer is correct.  If the pressure is too high it will keep the valve from opening.
Posted on Dec 04, 2009
Siemens WE61021GB/01 displays error code 03
http://teral.ru/katalog_stiral_nyh_mashin/siemens_simens/?p=6
best i can do is google translate
F03 is
Drain alarm (water in the tank is reduced to one level in the allotted time plot )
you ran out of time for the drum to fill
{too low pressure}
use the hot water valve as the cold
block off the hot water intake
this way you have a low pressure valve for cold
or
    1. There is a poor connection at terminals bilge pumps - seal the clamps, clean the terminals. 2. A malfunction in the bilge pump - clean the filter pump washing machine Siemens (Siemens) to either replace it. 3. There was a problem with the drain hose - hose to clean from pollution, eliminate the excesses, to restore the position of the drain hose specified in the instruction manual. 4. The pressure switch is faulty washing machine - repair of hydraulic water level sensor or replace the pressure switch.
Aug 11, 2014 | Siemens WE61021GB Front Load Washer
During the dry cycle, it seems as if water is continuing to be added. A few times i minute, at least 5 cups of water is pumped out into the drain. This continues for the 3 hr dry cycle. When done the...
could be one of your water solonoid valves is leaking by, where hot and cold hoses hook up in back, they get energized when calling for water then shut down when fill level is reached, some valves have filter in it, both valves come apart and can be cleaned, make sure no debri is caught in valves to prevent from closing fully
Oct 18, 2013 | Washing Machines
My siemens xlm 1400 wont fill with water so when it spins clothes are not cleaned.It won't drain properly either. It sees to only fill 10% of the water required. I have checked the pipes/hoses - a
I would take the back off and look for a small 5mm pipe leading upwards from the base of the drum and take it off and blow gently into it you should hear a click and one when you release the air if so then the place where you took the pipe from is blocked clean it out with a pipe cleaner or metal rod and replace the pipe as sometimes this pipe gets blocked with soap goo preventing the water sensor from doing its job eric
Jan 01, 2018 | Washing Machines
Washing machine won't spin or drain, have already checked pump & cleaned filter, any other suggestions? Thanks Kim
take clothes out put in drain-max and let it soak for 1-2hrs. now run on heavy duty hot water may have to run twice.
Jul 05, 2010 | Washing Machines
Spots on clothes after washing
Put another filter on before the washer. Try to find out if it is in the hot water or the cold. If it is the cold try a filter. If it is the hot, replace your hot water tank.
Jun 06, 2009 | LG WM0642H
Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Nov 30, 2007 | Hotpoint WMA64 Front Load Washer
Cleaning the filter
Yes to get the clean filter light to go off, you have to clean filter, put back in the machine, and hold down the power button for 3 secs to reset it. the clean filter light will go off!
Nov 14, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Clothes come out soaked
You water is not being pumped out when the spin is on; this is due to the outlet filter being blocked. Find out where this is from your users'manual and clean it out. This is to be done periodically according to your usage.
Jun 18, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
To much lint on my clothes after washing
try an emptyhot wash with some limescale remover in approx quater of a litre, let it run all the way through the wash then put on another rinse to clear out system. check the next water fill for any debris/lint left.
Jun 16, 2007 | Kenmore 22442 Top Load Washer
Dryers Logo
278 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
