Question about Uniden BT-108 Bluetooth Headset
HOW DO I CONNECT MY BLUETOOTH TO MY PHONE
MY WILL NOT PICK UP THE SIGNAL ON THE BLUETOOTH
How to pair bluetooth
One device sends the Bluetooth signal. For example, your smartphone can send a Bluetooth signal to play music from the phone on a portable speaker, or you might send it to a wireless earphone to make hands-free phone calls.
The second device receives the Bluetooth signal and plays the sound or picture.
To pair them, first set the receiving device (example: Bluetooth speaker) in "pairing mode". This is usually done by pressing a certain button on the receiving device for 3 or 4 seconds. Next, on your sending device (example: your phone) open the Bluetooth settings and select to search for Bluetooth devices. Your receiving device should appear in the list of available Bluetooth devices. Tap to connect to the receiving device. This may take up to 15 seconds. You should see a message on one or both devices saying "Connected".
Jan 01, 2016 | Audio Players & Recorders
How do I connect my keyboard to my tablet
If it's bluetooth, put it into pairing mode and turn Bluetooth on from your phone. Put your phone into discoverable mode and pick the keyboard. It might take a short time to show up. Pick it, and whatever code it wants you to on the keyboard.
Oct 04, 2015 | Tablets & eReaders
Samsung GT C5130 connect to my car (mazda) but can't talk
I would check the settings on the phone. Some phones have various settings and it seems like your phone settings is still set to pick up via Bluetooth headset - check the answer settings and you should be able to change it to in car settings. Which will allow the car Bluetooth to pick up the call.
Jul 16, 2012 | Samsung GT C5130 Mobile
I want to connect my nokia BH-104 headset tp my blackberry bold 9700 phone. Please guide
  • 1
    Turn on Bluetooth headset and Blackberry hand-held.2
  • Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.3)Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.4)Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.5)Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
  • Mar 20, 2011 | Nokia BH-104 Bluetooth Headset
    Will bluetooth help me pick up signal
    Bluetooth is a communications radio to connect two devices, and has a range of about 30 feet. It will not increase a wifi signal, or any other type of signal.
    Mar 10, 2011 | Acer Aspire One PC Notebook
    My speaker have water damage, i can hear but they cant hear me, can i use blue tooth
    Hi, a blue tooth device would allow you to hear and speak through it so it should solve your problem.
    the only problem you may have is if the water damage has causes damage to bluetooth inside the phone, try choosing bluetooth on your phone and see if you can still do a search and connect with another phone, if you can still connect to another phone to say send music or picture via bluetooth then this would suggest your bluetooth is fine and using a bluetooth head set will solve your problem and allow you to use your phone again.
    if you cant connect to another phone via bluetooth then the chances are it wont pick up the bluetooth head set and you would be no better off
    let me know how you get on or if you need further assistance ok
    please rate this solution as i have a whole page of unrated posts, thanks
    Dec 13, 2010 | LG enV3 VX9200 Cell Phone
    Bluetooth on sony radio will not pick up phone signal
    why wont my bluetooth signal stay on for me to connect to my phone
    Mar 04, 2009 | Sony MEX-BT2500 CD Player
    How do i delete a bluetooth from samsung r430
    Have your phone in pairing mode close blutooth headset push button down hold untill solid blue open headset the phone should pair then put in pass key
    Mar 03, 2009 | Motorola Mobility H700 Wireless Headset
    My H700 Motorola Bluetooth Headset
    i just want to know how to get it to work in the first place... got a new phone and need to set it up but i lost my directions. how do i just get it to work
    Oct 01, 2008 | Motorola Mobility H700 Wireless Headset
    Uniden BT-108 Bluetooth Headset Logo
    24 people viewed this question
    Top Uniden Radio Communications Experts
    Jason
    John
    John
    AnyMHz.com
    AnyMHz.com
    Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
