Question about Toshiba Televison & Video
Repair power button toshiba tv 36zp38
Pressed the power button on the above and it slipped and is now lying at 45 degrees on the long silver bar where the button is situated. have tried to put back in to no avail, and any help obtained would be of great help. thanking you
    Top Expert:
  • Toshiba Master
  • 37,796 Answers
Disassemly is required to determine how the button failed and repair it. Power buttons can be rather delicate and tend to break, especially in older TVs
Posted on Jan 03, 2013
Hi I have a Toshiba Regza 55" flat screen TV Model 55ZV65OU. Yesterday we had a power outage a quick flicker Off the power then on came the power but my TV won't turn back on.Note I use a power bar w
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 11, 2015 | Toshiba REGZA 47HL167 TV
My philips sound bar htl4110b doesn't turn on at all.i just bought it today
have you pressed/pushed in the silver button in the middle of the device. you should here a click. if this does not light up and your power cable is connected it is defective.
Oct 22, 2014 | Televison & Video
How to install a Kingston 1GB DDR2 memory into the Toshiba Satellite A135 S2386 laptop
The memory compartment is dead center of the bottom of the case. open the access door and look at the modules in their slots. On either side of the module you will see a silver arm that flexes. Pull these arms off to the outside away from the module. The module will flip up at a 45 degree angle. Pull the module from the slot at that 45 degree angle. To insert the module back into the slot, go at the slot at that same 45 degree angle and push into the slot until it "seats", it only goes in one way because of a "keyway" slot cut into the bottom where the gold contacts are. Once you have "seated" it, push the module straight down and the arms will snap into place. If you are replacing both, make sure to put the bottom one in first, then the top.
Jun 10, 2010 | Toshiba Satellite A135-S2386 Notebook
Black, Red and yellow triangle in upper right corner of the scrn.
YOU HAVE A CONVERGENCE PROBLEM IC'S WILL NEED TO BE REPLACED. THE FACT THAT THE LINES DID NOT MOVE WHEN YOU TRIED TO ADJUST THEM CONFIRMS IT.
Jan 19, 2009 | Toshiba 57H81 57" Rear Projection...
Image larger than screen on toshiba cx21419
You have Vertcle problem .Which causes pitcure hieght to be streached. Should call TV repair shop.
Nov 04, 2008 | Toshiba Televison & Video
Power button
Sharp has issued a recall on this model. Go to www.sharpusa.com/tv to have it repaired.
Oct 23, 2008 | Sharp 27L-S100 27" TV
Can't find code for my RCR312W to work on my Toshiba TV. I tried all different codes. Any suggestions?
Have you tried these codes?
Code 1000 for Toshiba TV Code 1048 for Toshiba TV Code 1072 for Toshiba TV Code 1105 for Toshiba TV Code 1109 for Toshiba TV Code 1118 for Toshiba TV Code 1160 for Toshiba TV Code 1190 for Toshiba TV Code 1241 for Toshiba TV
Sep 10, 2008 | RCA Universal Remote Control
Reset to factory setting
Hold stop button pressed in front of the unit, and press power on the front.
Jul 06, 2008 | Televison & Video
Toshiba Picture Frame 2 36zp38 No picture
Hi
This fault is not something you can repair your self.
It is a problem with the DFS module normally dry joints but it is near imposible to do without specialist equipment.
So definately take to repair shop.
Do not attempt this repair.
Sorry for being bearer of bad news.
http://dc07.atspace.com/
Chris..
Dec 15, 2007 | Televison & Video
Televison & Video Logo
120 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
