It's Kodak ESP 7 all in one printer I need it to connect to computer and it's even directly connected and it still wont
    President:
  • 623 Answers
EtHard to see on your video, but the blue cable - is that the one you are using to connect your printer to your computer? That looks very much like a network cable. Is that correct?
To connect the printer directly, you have to use a USB cable. If you use an Ethernet cable, the printer has to be plugged into your router or switch, or it will not get an IP address. Check the user guide here: http://resources.kodak.com/support/pdf/en/manuals/AiOPrinters/ESP7/1K3397_SETUP_BOOKLET_ESP7_en.pdf
What does your setup at home look like? - Router, Computer (OS), wired/wireless?
If you need more help, let me know and please provide some details.
Posted on Jan 03, 2013
  • 326 Answers
SOURCE: new ink cartridge but not printing green on esp 5 kodak all inone
you need to use the head cleaning tool in the printer properties, youll need to keep running it untill it runs clear and it uses alot of your ink while it does it.
youll find the cleaning option if you go to your
start/settings/printers and faxes, right click on your printer and go to printer preferences then maintinence
Posted on May 08, 2009
  • 295 Answers
SOURCE: esp 7 cartridge resetter and color refill .
no,ink cartridges cannot be refilled .kodak printers dont recognize refilled cartridges and as such,ink price is very reasonable,clear liquid is white coloured ink. no cartridge resetter is available,cartridges are seated in the printhead of the printer
Posted on Jul 27, 2009
  • 295 Answers
SOURCE: reset chip kodak esp 7 ink cartridge
Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges. The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
Posted on Sep 21, 2009
  • 103 Answers
SOURCE: Kodak ESP 7 WIFI problems
The ACTIONTEC GT124, M1000 and PK5000 Routers are not compatible with wireless-enabled all-in-one printers. These routers cannot connect to your all-in-one printer because they do not support the multicast protocol. Contact your router supplier for additional assistance and to determine if your router will be able to support the muticast protocol in the future.
Posted on Mar 01, 2010
SOURCE: I install Kodak ESP 3250 all N one print computer wont connect Is
we to were unadle to install such a printer ,customer services usless .they blamed or computer & os our's must be a different copy of windows 7 to everybody elses!!
Posted on Jun 03, 2010
Wont connect wireless
you do not give hx such as was it once connected but power went out, or have new router, etc...
have you walked through the directions starting on page 6 on the manual at this link:
http://resources.kodak.com/support/pdf/en/manuals/urg01130/ESP_7200_xUG_GLB_en.pdf
Jun 29, 2014 | Kodak ESP 7250 All-in-One InkJet Printer
The disk to install my Kodak ESP 3 is broken. How can I install it without one?
You can get the latest software for your machine, direct from Kodak here.
Just enter your model and search.
Mar 12, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Need help installing kodak esp-5 printer . I just bought an hp pavilion pc series 2159m. I cannot get printer to work.
Get the software/drivers from Epson http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=12998/12999&product=EKN035324
If you have installed the drivers before connecting the printer to the computer, try a new USB cable and plugging into a different port. If you use a print server or a hub, go for a direct connection. Make sure the printer is online and has good ink.
I hope this helps.
(btw: pavilion 2159m is just your monitor so what OS does your computer have?)
Apr 11, 2010 | Kodak ESP 5 Printer
Apr 10, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Feb 26, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Cannot install Kodak AiO ESP 5 printer in Windows 7
Kindly call 1800 421 6699 and ask for a supervisor straight away.The representatives can connect you to supervisor after taking your informations.The supervisors can remotely access your computer and get the software installed on your computer.
Nov 12, 2009 | Kodak ESP 5 Printer
I have a new Kodak ESP 7 printer and have not been able to set it up to communicate with my Mac OS 10.5 laptop. I can print if I have it plugged into the USB. I understand I might need an extra unit to...
Hi. I can help you connect your wireless ESP 7 to your Mac laptop.
The first step is to connect your printer to your wireless network. Navigate to the menu on the LCD of the printer and select Network Settings/WiFi Setup Wizard. The blue WiFi LED should be illuminating steady if the printer is connected to your WiFi network.
The second step is to add the WiFi printer to your Mac using the Print & Fax System Preference...
1. Under the Apple Menu, select System Preferences
2. Select Print & Fax
3. Click the "+" sign to add a printer
4. Select the Kodak ESP 7 listed with the Bonjour connection
5. Click the Add button.
The final step is to verify that you are printing to the WiFi printer when you attempt to print. In the Print Dialog box, verify the selected printer is named "KodakESP7+1234" where the last four digits are unique to your printer. If the printer you have selected is "Eastman Kodak Company KODAK ESP 7 AiO", then you are attempting to print using USB and this will not work unless you have a USB cable connected.
I hope this helps.
Dec 04, 2008 | Office Equipment & Supplies
jasbo
jasbo
