Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Seagate Barracuda 500GB. What do the different jumper settings do
How should the jumpers be set if the drive is used i) as a Master, ii) as a Slave on a Mac G4 Tower?
  • hgw5 Jan 20, 2009
    This answer was good enough to get me on the way to solving my problem but it still did not provide information about function of each of the four pairs of pins.
    Scholar:
  • 77 Answers
Serial ATA interface disk drives are designed for easy installation. It is not necessary to set any jumpers, terminators, or other settings on this drive for proper operation. The jumper block adjacent to the SATA interface connector on SATA 150MB/s drives is for factory use only. The jumper block adjacent to the SATA interface connector on SATA 300MB/s drives can be used to force the drive into SATA 150MB/s mode for use with older SATA controllers that only work with SATA 150MB/s drives.
HTH,
Deboo
Posted on Jan 19, 2009
  • 15,935 Answers
If looking at the rear of the drive....
1 2 3 4 5
Jumper pinset 1 for master
Jumper pinset NONE for slave
  • blueextc3221
    blueextc3221 Jan 19, 2009
    Leftmost pinset is jumpered for master (7-8)
    No jumpers erquired for slave
    For cable select, jumper pinset 2 (6-5)
    For Master with NON-ATA compatable HDD jumper pinset 1 and 2 (7-8 & 5-6)
    There are only 8 pins on your drive... labelled like this...(reading looking at the rear of the drive)
    7 5 3 1
    8 6 4 2
  • 13,433 Answers
The details read on the top of the hard drive on the label, you need to have the jumper connected to certain pins for to be on slave, master or on cable select.
Installation of the drive and setting of jumpper to make it either as a master or slave
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
Sep 27, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I HAVE MY MASTER 160Gb SATA SEAGATE, I HAVE TO ATTACH A NEW 500Gb SATA SEAGATE ,I'VE GONE TO BIOS SET UP. BUT IT DOESN'T DETECT MY NEW DRIVE.CAN YOU SHOW ME THE WAY TO SLAVE A SATA SEAGATE HARD...
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
May 16, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate 80GB hard disk
Dear
Your jumper setting is wrong.your elected is none ata compatible .plz set the jumper setting master or slave.
Jul 19, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How to set master, slave settings in sata hdd
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Regards
Ashly
Feb 02, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hard drive and/or jumper and/or data cable problem?
ok, Lets start by looking at the cable colors you are talking about. The drive doesn't care wether it is on secondary or Primary drive cable. As EIDE drive cables can support 2 drives each, 1 being a Master and the other being Slave. With no jumpers on the drive it should be set as Master. You can only have 1 Master drive on each channel or cable as you identified it. If you have set the drive to Cable Select and the Computer does not support this you will have problems. There should be a diagram on the top of the drive showing the different jumper settings. If not a computer store that sells parts should be willing to give you a cd that Seagate distributes that you can use to see the settings or teh Seagate website. They have used teh same jumper settings for years on EIDE drives regardless of how large they are. The only real limitation is going to be what the computer can see and use. If you are going to use that drive as a Master Drive on the Primary EIDE channel you will have to have and OS installed on it eventually as that will be the boot drive. The computer is not going to boot from a Slave drive without a third party boot loader which acts as the initial boot OS until you have selected teh OS you want to load.
Jan 02, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
How to make sata hard disk a slave???
Look at the jumper settings. These jumpers are located near the data cable and the power port of the hard disk. Usually by default, this jumper is set to "Master". To make it a slave, just remove the black or blue jumper or please refer to the jumper guide table printed in you hard disk's label.
Dec 29, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How do I set my 7200 Seagate drive as slave
Look at the diagram on the drive, you will need a jumper
MA = Master
SL = Slave
CS = Cable Select
If it's EIDE use the center connector on the cable
Oct 25, 2009 | Seagate Barracuda 7200.10 750 GB SATA Hard...
Jumper settings for slave
Page 21 in this manual shows the jumper should be removed to set this drive as a slave. You could also position it over the second column of pins, that is the cable select position and should also work if the drive is a slave or master. Your other drive on the cable would also need to be set to cable select if you do that.
Jul 11, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
808 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
