Question about Ricoh Aficio 3025 All-In-One Laser Printer
How to reseting error code ricoh aficio 3025 copy machin
lolita
  • 385 Answers
SOURCE: Error message says reset PCU correctly
You get this message because the PCU isn't seated properly. This is a link for the user manual for this printer: http://www.ricoh-usa.com/downloads/manuals/printers/cl2000.pdf On page 13 shows a diagram that indicates the photoconductor unit on the printer. Page 60 shows you different error messages, what they mean and how to fix it. It means you have to take out the pcu and reseat it into the printer, it is not in correctly. Page 29 shows you how to do this. It has pictures of how to take out the pcu and put it in correctly. I hope you get it fixed.
Posted on May 12, 2007
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
  • 29 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC545 error code after
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
Posted on Aug 18, 2009
  • 7 Answers
SOURCE: how i reset error sc 546 on ricoh aficio 4100n
Turn the machine off, hold down online & escape, turn machine on and wait for "1.Service Menu"
Select service menu, find sp 5-810, select #/enter, when it says "execute select #/enter, then escape. Turn machine off then on.
Posted on Oct 24, 2009
No loading toner my ricoh aficio 3025
you need to replce the PCU - unit order code is
  • B205-0153
  • that depends on the counter number.
  • or the cap from the other toner is still inside the the toner holder.
  • check the old toner bottle does have a cap on it.
  • how ever for i need the print counter to see if the PCU is for replacement.
  • write the print counter, and see do the old toner bottle have ca p on it or is just a open hole.
  • please write some additional info.
  • Best Reagrds
Oct 16, 2016 | Ricoh Aficio 3025 All-In-One Laser Printer
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Ricoh Aficio 3025 Copier LCD Touch Screen gets hang after calibration
You need to replace the screen to fix your problem. But if this machine is the model I think it is you need a whole new machine.
Jul 23, 2017 | Ricoh Office Equipment & Supplies
Error code sc 650
Ricoh AF 3025 error code SC650 is wat problem?
Jan 03, 2012 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh Affcios 3025 Functional problem with copier
Hello!
This code is related to a Fusing temperature error.
You probably need to change Hot roller (or fusing roller), Pressure Roller and both thermistors.
You can reset this code but it will pop-up again sooner or later.
The best advise i can give you is to call a technician (if you do not have technical knowledge)
If you still want to reset the code try this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Press "copy SP"
On the key pas press 5810 and #.
On the touch panel press "execute"
Exit all the way out.
Turn the machine off and on.
Hope this helps you
Aug 04, 2011 | Ricoh Aficio 3025P Black and White Copier
My ricoh aficio 3025 copier has the capabilities to scan, print & fax but it only copies. Can we add those modules?
you need to buy a enable sd card for print and scan... and the problem with the fax function just conect it., the line and the phone.
Jul 09, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
I have a ricoh Aficio 3025 all in one, it is now giving me a fault code of SC543 please advise
its temp. or fixing error. try to clear it in service mode.
yellow 197 red when it says SERVICE MODE turn off and on machine, if it does not help you need to call service to replace thermistor, or lamp, or rise temp. ,or ...
Nov 12, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Ricoh aficio 2022 error code sc542
2. 107
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 3025 All-In-One Laser Printer Logo
63 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
