Question about Kelvinator Freezers
KELVINATOR DELUXE 21.1 cu. ft. freezer UFS211MM
NEED A NEW DOOR GASKET
  • 833 Answers
SOURCE: Chest freezer lid sticks in closed position
Yes, use silicon lubricant.
Posted on May 27, 2008
  • 1779 Answers
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Posted on Aug 08, 2008
  • 65 Answers
SOURCE: small upright freezer (4 cu ft) is leaking water
Could be just the coils are iced up, I would pull everything out of it, unplug for a day, plug back in and let it run....
Posted on Aug 22, 2009
  • 4793 Answers
SOURCE: Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Posted on Apr 07, 2010
  • 7 Answers
SOURCE: MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door.
Just had the same problem after unboxing.
Simple, just be sure to do the entire door.
Posted on Jan 29, 2011
ICE BUILD UP IN A MAYTAG MODEL MZF34X16DW UPRIGHT FREEZER
I have had a few of these, and others of the same ilk.
Your problem should be air leakage into the machine.
Take a thicker piece of paper, not cardboard, and try to slide it around the gasket where the door gasket contacts the front of the freezer.
The gasket should be firm enough to prevent the paper from sliding. Wherever you can move the paper, you could have a air leak.
Most of these have no adjustment in the latch to tighten the door. Sometimes a new gasket will solve the problem, sometime a new door will.
P.S. Twice I have tied a new freezer to a refrigerator dolly to move it and have accidentally warped the door, and they cannot be straightened. :-(
God bless your efforts.
Jul 07, 2017 | Maytag Freezers
How do i get a gasket replaced on a sears kenmore freezer model 31165
Order the new gasket using your model number- 31165 is not a valid/complete model. Remove the door and lay it flat on the floor, then remove the screws from the upper half of the door perimeter- DO NOT remove all the screws at once or you will be unhappy! Pull the top half of the old gasket away from the door, then put the top half of the new gasket in place and screw it back down. Next, remove the bottom half of the screws and pull the old gasket off, then put the bottom half of the new gasket in place and screw it down. If you try to do it all at once, the door will flex out of plane and won't lay flat when you re-attach it. You might need a hair dryer to soften the gasket if it was deformed during shipping. If you have a newer, press-fit style gasket, just yank it and press the new one in... Door Gasket 241872513
May 20, 2016 | Kenmore Freezers
How difficult is it to replace a Door Gasket - True TS-49F Freezer
The old gasket just pulls directly out from its slot in the door. Start about 3" away from a corner, then pull the corner out; the rest is easy. Soak the new gasket in warm water before fitting; it softens the edge and makes it easier to push in.
Apr 23, 2014 | True TS-49F Stainless Steel Freezer 2...
Need new gasket
http://diygaskets.com/search.asp
If you model number is correct these guys will have it.
Aug 25, 2012 | Freezers
My Kelvinator refrigerator temperature varies a lot; thermostat problem?
check to see that the door closes tight and it is not losing cold air. If it seems to be ok I would check the thermostat
Oct 07, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
How do i defrost chest freezer
unplug unit and open door, it should have a spout at bottom to connect drain hose
Aug 22, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Coldtech freezer door reversal
http://www.ascendmfg.com/PDFs/CT/hdmanual.pdf
start at this web site and see if this manual will help. It has phone number on last page if you need to call them.
ColdTech is now Jimes Corp. Just Google you unit if what I have does not help enough.
Good luck to you.
Oct 21, 2009 | Coldtech 21 cu. ft. / 595 liter Commercial...
Mu upright freezer door seal was loose and it is leaking from door would this cause domw food to thaw and can it be fixed
a leaking gasket can cause food to thaw and it can be fixed if a new gasket is avaliable from local appliance parts place..the gasket is held on by the liner which is removed by gently lifting the gasket and removing the screws..the reverse to install the new gasket
Sep 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
104 people viewed this question
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
AJMAL KHAN
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
