Alienware m17x freezes on the starting windows screen (with the windows logo). have tried everything in the launch startup repair menu and nothing works.. i can't get past the starting windows screen. even done the alienspawn restore and emergency backup, said it completed but didnt solve my problem..
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
May be your OS booting files corrupt or your system booting file is infected by virus. you have to format your system.
Posted on Jan 03, 2013
ajx13
  • 110 Answers
SOURCE: my dell inspiron 1525 won't boot up
The hard drive could be failing. Try running the test this way.
First you'll have to power off the system.
You need to hold down the Fn button (Located next to the CTRL button on the left hand corner) and then power on the system. This will take the system to the diagnostics mode.
After running a series of tests you'll be prompted to "Press any key to boot to the diagnostics partitions". Now you'll get a prompt to test the computer. You need to select the option and run a CUSTOM TEST on the hard drive.
Write down any error codes listed and continue testing.
If you get any errors note then and contact technical support.
Posted on Aug 19, 2009
ChipcircuiT
  • 157 Answers
SOURCE: Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
when you restart try to press F11 while booting..check
Posted on Jan 05, 2009
SOURCE: blank screen appears on the startup with only cursor on it
The Acer Recovery CDs do not set the Boot flag on the hard drive. I had to manually set the boot flag to on using GPARTED Live. After restarting using the GPARTED CD, you can manage the flags under the partition drop down and click on the Boot flag. After exiting GPARTED, I rebooted the laptop and no more black screen....fixed!!
I hope this helps others.
Posted on Feb 18, 2009
SLitWrists
  • 35 Answers
SOURCE: acer lapt top will not start in any mode.It says
Hi
Sounds Like Youre O/s is the problem.
If you have youre O/s disk try and do a windows repair form the disk
Kind regards
SlitWrists
Posted on Apr 24, 2009
parrotheadpc
  • 2600 Answers
SOURCE: wont boot past second start up screen
Try this repair below....follow it closely.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Dec 14, 2009
My laptop is an Alienware 14 and I'm stuck between two screens
Try repeatedly pressing the F10 key at launch. If that does not work try other F-keys. If you are able to get an advanced boot dialog open, choose the option to startup in Safe-Mode.
Check out the following link for useful tips:
How to use the Startup Settings boot menu in Windows 8
Jan 08, 2014 | Computers & Internet
Turning off keyboard backlight
First of all, did they worked before?
If yes, then it means your Alienware maybe went into a power saving mode because the adapter you're using doesn't provide enough energy.
If the lights didn't worked before, then you should install all the necessary drivers and the Alienware OSD Application and Alienware Command Center.
If you have all the applications and drivers installed, then you should configure the lights in the Alienware Command Center.
Here are the official links for drivers and resources:
Alienware M17X Drivers:
http://www.dell.com/support/troubleshooting/us/en/19/Product/alienware-m17x
or
Alienware M17X R2
http://www.dell.com/support/troubleshooting/us/en/19/Product/alienware-m17x-r2
Jun 13, 2013 | Alienware PC Systems Computers & Internet
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Mar 19, 2013 | Computers & Internet
Alienware 17" notebook with windows 8 shutting self down at startup
If it's 3 weeks old return it. Or you can do a System Restore/Recovery. Take a look at this forum for the Restore/Recovery Procedure: http://en.community.dell.com/owners-club/alienware/f/3746/t/19441985.aspx
Mar 01, 2013 | Alienware PC Systems Alienware M17X with...
Help please, I have a compaq presario cq62-225nr notebook that refuses to start windows 7. I've only had it for 2 months, when I turn it on it gives 2 options one to start windows normally and the other to...
Since you've only had for 2 months, I would contact the seller. If they give you the run around tell them this is unacceptable and you will have to write an honest review on how sorry their products and service is. No company wanted a bad review.
Apr 25, 2017 | Computers & Internet
Hello, I have an HP Pavilion dv2000 laptop. The problem is the laptop keeps freezing on startup.When I first turn it on I get a screen that says "Windows failed to start" and gives me two options: Launch...
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reginout
Sep 22, 2010 | HP Pavilion dv2000t Notebook
Computers & Internet Logo
230 people viewed this question
David Payne
David Payne
