Question about Konica Minolta Magicolor 3730 Dn Color Laser Printer
Media empty fault
I have a Minolta 3730 DN which has an irritating fault to do with paper. When I try to print certain documents such as labels and some internet pages I get a message "Put Media tray 1 A4". There is always plenty of media and opening and closing the drawer does not get rid of the error code. To do this I have to open and shut the righthand cover. However, the same error will come up if I try to print the same document regardless of what I do. Obviously the fault has nothing to do with the media since, if I cancel the job and print a configuarion page or a different document it works perfectly. I have tried changing the default tray in the setup options (that's tray 2 although there is only one tray) and I have tried changing the media from plain paper to thick stock - but nothing works. I presently have some labels on the screen that I can't print - although the machine did print them a few weeks ago. Posted by Author imageGuest on 1/3/2013 Details I have a Minolta 3730 DN which has an irritating fault to do with paper. When I try to print certain documents such as labels and some internet pages I get a message "Put Media tray 1 A4". There is always plenty of media and opening and closing the drawer does not get rid of the error code. To do this I have to open and shut the righthand cover. However, the same error will come up if I try to print the same document regardless of what I do. Obviously the fault has nothing to do with the media since, if I cancel the job and print a configuarion page or a different document it works perfectly. I have tried changing the default tray in the setup options (that's tray 2 although there is only one tray) and I have tried changing the media from plain paper to thick stock - but nothing works. I presently have some labels on the screen that I can't print - although the machine did print them a few weeks ago. The solution just gievtn doesn't help as it's fior the wron printer
  • 214 Answers
SOURCE: printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Posted on Jun 19, 2008
  • 214 Answers
SOURCE: Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
Posted on Jul 02, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Cannot print Labels
The printer is setting the size from the position of the tray guides.
If it is reading it as K16 then that is the closest size to the paper you have loaded. The device will oook at the tray and then set it to the closest match this is the function of the Auto size feature.
Try measuring the paper and entering it as a custom size instead. Mimic the setting through the driver of course.
Run it through the bypass tray and be sure to specify the stock type/weight for proper printing.
Posted on Sep 10, 2008
SOURCE: media jam fuser
I turned the printer off, took the power cable out, and turned the printer on. After 60 seconds I turned the printer off, put the power cable back in and turned the printer again on. This is a solution in order to loose all the voltage/current build up in the printer. Whether this is the solution or just coincidental, I don't know. The printer worked well after that.
Posted on Mar 05, 2009
male_28_cam
  • 1555 Answers
SOURCE: Hi I have a Konica Minolta 2490MF and when I
Mr Stephen You have to check paper settings at 3 places first that you are putting correct paper size in correct tray and the paper supporter is touching the paper. Secondly your documents page setup paper size. Finally go to printer properties and under paper selection you will find letter size change it to a4 Thankyou for using free solutions at yafix-ratings from your side would be appriciated.
Posted on Jun 22, 2009
I have a KonicaMinolta Magicolor 3730DN. It fails with Fatal error code 0094m
Check the 2nd transfer roller the sponge looking roller replace it normally done when replacing the transfer belt
Nov 01, 2016 | Konica Minolta Magicolor 3730 Dn Color...
Media tray empty
Printer is not sensing the papers.Try and re-load the papers a few times
Apr 24, 2014 | Brother Office Equipment & Supplies
The black ink is NOT showing empty but it will not print
Firstly two things here assuming everything is fine with your printer.
Firstly have you changed the options in the document or picture youre trying to print? For example, if printing a document from Word, go to printing options and click advanced then print in 'black/white' rather than 'color'.
Secondly when you installed the ink cartridge in the printer, have you removed the plastic/paper sticker attached which protects the circuits and ink leakages?
good luck,
kc
Feb 23, 2011 | Konica Minolta Magicolor 1600W Printer
Paper comes out incomplete and with a blue background.
HP printers require a certain type of paper and ink that is compatible with the printers.
Here are some print quality Issue suggestions from HP:
General print-quality problems can be solved by using the following checklist:
  1. Make sure that the paper or print media that meets the specifications. Generally, smoother paper provides better results.
  2. If a special print media is being used such as labels, transparencies, glossy, or letterhead, ensure that they are printed by type.
  3. Print a Configuration page and Supplies Status page at the device.
    • Check the Supplies Status page to see if any supplies are low or empty. No information is provided for non-HP print cartridges.
    • If the pages do not print correctly, the problem is with the hardware. Contact HP Customer Care.
  4. Print a Demo page from the HP Toolbox. If the page prints, the problem is with the printer driver. Try printing from the other printer driver. For example, if using the PCL 6 printer driver, print from the PS printer driver.
    • Use the Add Printer Wizard in the Printers (or Printers and Faxes in Microsoft Windows XP) dialog box to install the PS driver.
  5. Try printing from a different program. If the page prints correctly, the problem is with the printing program.
  6. Restart the computer and the device and try printing again. If the problem is not resolved, choose one of these options:
    • If the problem is affecting all printed pages, see General print quality issues.
    • If the problem is affecting only pages printed in color, see Solving issues with color documents.
I will get more information on this topic in a secondary post very shortly. The information was too long for one post. If this information was helpful, please remember to leave positive feedback. If you need additional assistance. Please include the model of printer that you are using.
Thank You,
Brian
Feb 10, 2011 | HP DESKJET PRINTER, HP OR COMPATIBLE
My Omni 3730/3730LE VeriFone printer does not print on the paper
Ensure thermal paper is being fed from underneath the roll, as it will only print on one side of the paper. hope this help
Jan 16, 2010 | VeriFone Omni 3700
Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
Minolta Magic Color 2300dl printer won't print legal size documen
Is tray one the bypass tray or a tray. check which one is tray 1
Nov 24, 2008 | Minolta magicolor 2300W Laser Printer
"490: MP tray is empty" message when trying to print labels from Word 2003
The MP tray referred to is the Multi Purpose tray and is located at the front of the printer. To access it, you need to find the 2 indentations at the side of the front feed assembly and pull them towards you. this then gives access to the MP tray. Don't forget to press the blue button after loading the paper. Your user guide/manual will give clear instructions and pictures. It may also be called manual feed tray. Once loaded with the correct paper press the online button and printing will start.
Oct 18, 2008 | OKI C5500n Printer
Cannot print Labels
Sep 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta Magicolor 3730 Dn Color Laser Printer Logo
42 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
