Question about John Deere Step 2510 2520 3010 3020 4000 4010 4020 Jd
Condenser on 3020 john deere
Condenser keeps going bad on john deere 3020
SOURCE: john deer
Hi if you look on the side of the oil pan there should be a square plate with 4 bolts the oil filter is behind it its a paper one Fram C139PL and a new gasket comes with the filter. I hope this helps. M.L
Posted on May 05, 2009
  • 246 Answers
SOURCE: john deere 2020 water pump repair?
Hello:
From your Description it Sounds like a Bad Water Pump Bearing and Seal.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 11, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
Torque specs for the intake and exhaust manifold bolts 3020 gas
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
1964 john deere 3020 WORKSHOP SERVICE REPAIR MANUAL
Jan 08, 2016 | John Deere 3020 Gas & Diesel Tractor...
How do I change the fuel filter on my 3020 John Deere diesel tractor
Leaving the fuel valve on the tank in the on position will allow fuel to run through the line & keep the air purged during removal. On the other side between the pump & the filter, having the new filter topped off & speedily installed will lessen the chance of air entering the line. Once the filter is installed, open the bleed screw at the top of the filter. Just my redneck way.
Oct 05, 2014 | John Deere Ar50041 Diesel Fuel Filter 3020...
What is the proper sequence for the head bolts on a deisel 3020
the head bolt torque is 130 +or- 5ftlbs and as far as sequence if not sure start in the middle of the head and work your way out alternating side to side and in an X. Step up to 130 by starting at 80-100-115-130.
Nov 09, 2013 | John Deere 3010,3020 Tractor Basic...
Remove spindle john deere 3020 tractor
Remove bolts or clamp on top of spindle. Next remove steering tie
rod. It should slide out.
Sep 26, 2012 | John Deere 3020 Gas & Diesel Tractor...
No spark to spark plugs on john deere 2510
do you have a bad wire or a bad wire going from the points to the coil
Jul 28, 2012 | John Deere Step 2510 2520 3010 3020 4000...
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
Jul 04, 2009 | John Deere 3010,3020 Tractor Basic...
John deer
Apr 13, 2009 | John Deere 3010,3020 Tractor Basic...
John Deere Step 2510 2520 3010 3020 4000 4010 4020 Jd Logo
35 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
