Question about Garden
McCulloch TM-210 Petrol Strimmer not rotating properly
The petrol strimmer's engine is fine, when started the end slowly rotates but when the power is applied there is no change, the rotation does not increase, I was wonding if this is a clutch problem or something, what is the best way to fix it. Thank you.
I would only like to kno who would repair it in Glasgow
Posted on Jul 21, 2014
5 Suggested Answers
  • 474 Answers
SOURCE: petrol strimmer good spark but wont start
if it ran fine then it quit it is more likely the pick up tube in the fuel tank
Posted on Sep 14, 2009
vincob
  • 718 Answers
SOURCE: mcculloch t 240 petrol will not start
If your petrol has been sitting in the machine for a long time then yes it is your petrol. Mix a new batch usually you cannot let that sit around for more than 30 days, I always try to use fresh mixes, usually that means making smaller batches unless you use your trimmer quite a bit, most people do not though and that's when problems arise.
Posted on Jul 04, 2010
hunter19_46m
  • 7482 Answers
SOURCE: EFCO petrol strimmer - can anyone tell me how to
If you need to clean the filter, remove it from the fuel tank and blow compressed air into it, otherwise you may have to do the following:
Sounds like you will need to clean your carburetor
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 24, 2010
  • 100 Answers
SOURCE: mc culloch tm 250 strimmer. petrol/oil ratio
40 parts fuel to 1 part 2/stroke oil
Posted on Aug 14, 2010
Champion strimmer 25 cc cord
its a pdf
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
Jul 17, 2016 | Garden
Mcculloch petrol strimmer
Agnes take of the cutting head again and see if it runs at full speed without it. If it does you have either put the head on too tight or it's the wrong head.
May 11, 2014 | Garden
Spear & Jackson 33cc Petrol Grass Strimmer SGT33N, black fuel pipe split. How to replace it?
empty the petrol,feed the black line (the fuel intake) into the tank and grab the end of it thats attached to the filter inside the tank. now you can feed a new fuel line through into the tank and reattach to the filter. hopefully this will solve your problem ive just done this but mine still wont start, either flooded or spark plug. by the way i bought mine new and the fuel line was split.
Jun 05, 2013 | Garden
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 | Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Hi wev put the bit on for the line onr mcculloch tm 250 petrol strimmer. Can u tell me how you get it back off thanks
Hold the big alloy nut above the trimmer head with a suitable spanner, then turn the whole head anti clockwise as you look at it whilst holding the nut, the complete head will spin off.
Apr 28, 2011 | Garden
STRIMMER TM 210 CORRECT FUEL PLUG CLEANED STARTSFOR 10 SECONDS THEN STOPS WHY?
Check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines. Make sure the choke is operating properly. Be sure to use a synthetic chain saw oil in the fuel, not boat motor oil. I'm assuming that the jet screws have not been adjusted in an attempt to fix the problem. Hope this helps!
Oct 22, 2010 | McCulloch Garden
Mcculoch mt 300mcculoch petrol strimmer carb two adjustable screw bolts ones for petrol, ones petrol & air mixture hich one does which
Actually both screws are for petrol mix. The screw closest to the engine is the Lo side. Lo side jet provides petrol at idle and during the ramp up to speed. Hi side jet (closest to air filter) only effects the mix at high speed.
From McCulloch, these were set at 1 1/4 turns out.
Sep 16, 2010 | Yard Machines Garden
Mcculloch t 240 petrol will not start
Jul 04, 2010 | Garden
Petrol strimmer good spark but wont start
Sep 14, 2009 | Garden
Garden Logo
922 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
