Question about AEG Washing Machines
Washing does not work puts E20 - AEG Washing Machines
  • 22 Answers
Look in manual that came with machine, there should be codes at the back, or look your machine up on the internet AEG fault codes, repairs etc or contact manufacturer
Posted on Jan 03, 2013
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
What does E20 mean
If the washing machine you're using is a Zanussi then the error code means that the pump is not working properly. This can cause the water to not drain properly.
One solution you can try is to check the filters located in the bottom front of the washing machine. If this don't work you might need to change the pump.
Feb 28, 2011 | Washing Machines
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
Error code E20
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Washing Machines
Error message on washing machine E20
E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
the drain pump may be blocked
or possible your filter is totally blocked. Clean out the filter everything will work again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there.
Good luck.Please rate the solution if accepted, also do post comments in case of any doubts.
Jan 23, 2009 | Zanussi Washing Machines
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Error code 20
Hi, I also got the error code E20 when the filter became totally blocked during the washing cycle (due to a pair of my son's old work jeans!). Once I cleaned out the filter everything worked ok again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there. Regards, John
Sep 04, 2006 | Zanussi ZJD1219 Front Load Washer / Dryer
Washing Machines Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
