Question about Epson Stylus D88 InkJet Photo Printer
How to change the ink cartridge on an Epson D88 printer?
I have tried pressing the ink button and the on/off button together for a sufficient time but although the cartridge container moves to left an right several times it doesn't end up in the right place to remove the cartridge.
  • disagooner1 Feb 03, 2009
    I am not sure what i am doing - i have brought a new cartridge - but not sure how to remove old one and put new one in
  • Epson Master
  • 419 Answers
To change a cartridge the old one needs to be registering as empty.
Press the ink button and the carriage unit will move to the pointer which indicates which cartridge is empty. Press the ink button again and it will move to the exchange position.
You only need to press, rather than hold the button down as holding it down will run a cleaning cycle which is best avoided unless required.
If the cartridge is not registering as empty you can try this approach:
Turn the printer on, wait for the printhead to move off the parking pad and then pull the power cord out the back of the printer (or just turn it off at the socket). You should then be able to move the printhead manually to the exchange position and change your cartridges over. Once you're done just plug and turn the printer back on and hopefully you should be good to go.
Hope that helps.
Posted on Feb 20, 2009
Epson D88 will not print, both red lights flash, message remove obstruction switch off and on. No change still 2 redlights flashing
The Lights can flash on an error and also iff the INK levels are down. You must check the ink levels and try to do a reset with printer software reinstalled.
Remvoe pinter from the PC, unistall and then reinstall to see if the printer shows the INK level exactly. If not replace INK cartridges to confirm.
Nov 16, 2010 | Epson Stylus D88 InkJet Photo Printer
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have an Epson D88 Inkjet Printer which is a couple of years old. Both the ink and the paper lights or flashing. The manual recommends taking to the dealer but it is not worth it. Any tips on a quick fix?
Could it be you're out of ink and paper simultaneously? But is it even worth buying more ink to find out if this is the cure? If so, I'd try generic ink cartridges to minimize the cost of the experiment. On the other hand, you could probably replace the printer, with new ink cartridges for not much more than the cost of ink for your old printer. They're made to be throwaway, unfortunately.
Nov 18, 2009 | Epson Stylus D88 InkJet Photo Printer
Ink out reported as Communication Error.
Try reseating all cartridges, and power cycling the printer...
May 07, 2009 | Epson Stylus D88 InkJet Photo Printer
Epson sx 200 printer cannot change ink cartridge
Ive just pressed the 'stop' button on mine and it moved the cartridge to show which ink needed replacing and then when pressed again it moved to the replacement gap
Mar 24, 2009 | Epson Stylus CX3200 All-In-One InkJet...
My epson d88 printer has 2 flashing lights, the ink charge and paper feed lights. this is preventing me printing out. this happened after i tried to change my inks. can anybody help?
I just had the same problem. Try opening the top flap on the printer and see if you can click the lid down on the ink cartridge box more firmly (until it clicks) - i had to force the cartridges to the left slightly to do this, although I'm not sure if thats neccessary. Then i pushed the cartidge box back to the right where it was before. The 2 red lights still flashed for me, but when i turned the printer off and on again it worked just fine. I hope this helps.
Jan 23, 2009 | Epson Stylus D88 InkJet Photo Printer
MY EPSON D88 PRINTER HAS 2 FLASHING LIGHTS
This is usually caused by a problem with the chip(s) on the new cartridge.
Check that the chips are clean, and are correctly installed on the cartridge(s) (some can be knocked out of alignment and thus not connect properly).
Also check for any damage to the tiny wires in the printhead where the cartridge sits.. These can also become soiled with fluff, etc... Be VERY careful if you try to clean these as they are very delicate and if broken off you will have a broken printer.
Last thing is of course to check you have the correct cartridges... A common one with the D88 is to have C86 cartridges which are not compatible at all (different' chips!).
Hope that helps.
How do i change the ink cartridge on my epson cx6400?
I am assuming that you already have a replacement ink cartridge.
  • Make sure the printer is on.
  • If the LCD screen says that your ink cartridge is empty than
you can simply press the Color button (the button looks sorta like a diamond with a line in the middle of it).
  • If you wanna change the ink cartridge but the printer does not say that it is empty then
press the setup button, then press the top left button until Replace ink is displayed. Finally, press the Color button.
  • Lift up the scanner section
  • Wait for ink cartridge holder to move to replacement position then open its cover.
  • Identify which cartridge you want to replace. Press in the tab to release the cartridge, then lift straight out.
  • Before unwrapping the new cartridge, shake it gently four times. Then remove from wrapper.
  • Lower new cartridge into holder, press down firmly until clicks.
  • Close cartridge cover
  • Carefully lower the scanner section and press it down until it clicks
These instructions were found in http://files.support.epson.com/pdf/cx64__/cx64__pg.pdf on pg 12.
Oct 12, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus D88 InkJet Photo Printer Logo
200 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
