It sounds like you may have faulty tact switches on the front control panel that are acting intermittently. If one of the switches is defective it can cause all kinds of erratic behaviour.
Pull the little battery on the motherboard, and unplug the PC, let it sit for a minute or so. Put the battery back in and turn it on, BIOS should be reset.
Ok on keyboard, press WINDOWS logo see start page comes up. using keypads arrow keys, access the control panel, find mouse, if you are using vista, set classic view. you may get around by tab key and up>down>rigth>left arrow keys.
Install driver again or use update \. come back start and shot down the computer by shotdown arrow, do not use brown button will not shotdown, it is stanby (On vista). Then turn on again see what you see>
If can not, Just use same system and reach out the system tools from accessories>system tools>Make defragmentation.
No result > make system restore. No result see tech.
JMC
sounds like the CPU is overheating. if you feel comfortable open the case and replacing the thermal paste between the processor and the heat sink might do the the job. A tube of thermal past is inexpensive and you jsut need to use a small dab to get the job done.
my computer is automatic shotdown in 15 min...what is the problem of my pc? all connection are connected and i'll checked the cards.and the settins are correct..what is the solution?
