My washer wont work.its saying f:21
My washer wont start its electric screen coming up f:21
  • 22 Answers
You will need to look in the manual that came with the machine, there should be a list of fault codes in the back, either that or call the manufacturer, they should to answer your questions, you'll find their contact details in the back of the manual
Posted on Jan 03, 2013
Hi i have a coolpad avail 3300 and when i turn it on it doesn't go past the coolpad logo it stays stuck on that screen what do I do
Coolpad Arise locked on startup screen : perktv - Reddit
https://www.reddit.com/.../coolpad_arise_locked_on_startup_scree...
RedditApr 21, 2015 - The community doesn't take too kindly to it either. ... charged battery, or on just the power cord, but it will not go past the "Coolpad Arise" logo.
Coolpad 3300A wont go past the start screen where it says ...
www.askmefast.com > Computers & Internet > Security > Screen
Coolpad 3300a wont go past the start screen where it says coolpad? ... Coolpad won t go past start up screen ... Software for avail coolpad 3300a phone ..... Can i get a new 4g coolpad for mertopcs if part of the screen doesn`t really ... coolpad phone model 3300a always freezing at the coolpad logo and how to unfreeze it?
Jan 01, 2016 | Computers & Internet
Kenmore he2plus what's troublecode f-21
F21 on the tech sheet says Long Drain If the drain time exceeds 8 minutes the water valve turns off.
NOTE: After 4 mins the "Sd" error will be displayed then 4 mins later the f/21 error code will be displayed.
Press Stop two times to clear the display.
(Solutions:) Check drain hose
unplug washer and check electrical connections at pump
Check filter for foreign objects
If these fail it says to replace pump.
Dec 11, 2011 | Kenmore Washing Machines
My Kenmore HE2 Plus wont start and it gives code F-21...... the door locks but the washer wont fill up with water.. then it faults out. What can I do?
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Aug 06, 2011 | Kenmore HE2 Plus Front Load Washer
My fisher & paykel washer wont start it beeps and says the lid isnt closed, but it is and there is a little ambulance that comes on the screen
I believe the lid switch is faulty, for the later modules the microswitch is mounted inside the door lock mechanism, others under the lid/top left side.
The ambulance is just saying to call for help....
May 17, 2011 | Fisher and Paykel Fisher & Paykel Washer
F-21 error code, washer stops
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris.
Thank you !!
Jul 13, 2010 | Kenmore HE2 Plus Front Load Washer
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
The digital readout says f- 21
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Dec 09, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Long drain f-21
Check to see if the drain hose is twisted or crimped. Start the wash cycle from the beginning
Aug 13, 2009 | Kenmore HE2 Plus Front Load Washer
F-21 on my window
F21  mean LONG DRAIN if the dreain time ixceeds 8 minutes the water valve turn off. *After 4 minuts the "Sd" error will be do;[;aied tjem 4 minuts later the        F/21 error code woll be displayed. * Press STOP two times to clear the display.
if this wont work the following mus be done by a technician.
Was this helpful?
May 09, 2009 | Kenmore HE2 Plus Front Load Washer
E-21
start /variable sp. sw. needs replacement.
easy fix for most electric appliance repair person
Jan 07, 2009 | Proform 575 Crosstrainer Treadmill
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
