I have a remington 5000w garage heater and after i plugged it inand all it does is make a buzzing sound when i turn it on?
Its a ceiling mounted model, 5000w garage heater
Accurate Joe
  • 61 Answers
SOURCE: add line thermostat to fahrenheat space heater
Just disconnect the other thermostat. You can leave it there just disconnet the wires
Posted on Nov 30, 2008
  • 96 Answers
SOURCE: Heater location
your best way is get all thread rod and cut to size
Posted on Jan 06, 2009
tbugger
  • 232 Answers
SOURCE: R150B Kerosene Reddy Heater-
Neither of you state the model of heater that is giving you starting problems. many of the motors have an external starting capacitor (relay). If so, you may just need that part, if your heater is equipped with one. On the other hand, many have an internal capacitor , which is not servicable.
Posted on Feb 16, 2009
tbugger
  • 232 Answers
SOURCE: kersone reddy heater won't start, just buzzes
The R150B uses motor #097308-06, has a split phase motor. The secondary windings, which give the armature a jump-start, have gone bad. The motor is not serviceable. Try reddyparts.com - they seem to have the most parts.
Posted on Feb 25, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: hello I have a Fahrenheat Ceiling-Mount Industrial
Sorry to read about your problem, I hope this helps you out.
you will have to install a 30 amp breaker, and make sure the wire is rated for 40 amps, or 110% of 30 amps, you can wire direct to the heater if you wish.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 03, 2011
Fan will not shut off what could be the problem?
if its the original model number without an b at the end it is supposed to shut off, if it is the 4604b the added a feature to keep the fan running anytime power was on to keep it from burning up the power strip, this was a temporary fix, i just picked up a new on tonight under warranty and it has a feature that lets the fan run for a while and then shut off, the newest model number is HA24-50m, is is the same heater as original but now only has 5000w and 3000w options on switch, good luck finding a listing but this is the heater northern tools gives you when they replace the 4604. im pretty computer savvy and i can not find any site that is for profusion heaters as a company, here is a number for tech support you can call, 1-866-206-0888
Oct 19, 2016 | ProFusion Heat ProFusion Ceiling-Mount...
Hello I have a Fahrenheat Ceiling-Mount Industrial Heater 240v rated. Can I use a 220 plug to wire it and connect it to my 220 aux plug in my garage? If so how should I wire it to the heater itself?
3 Thumbs - Helpful
Jan 03, 2011 | Fahrenheat Ceiling-Mount Industrial Heater...
I have a 724 heater7500 w 28x32x10 garage with dog door it will only keep garage at 40 degree not 50 like i want in minnesota what are my options
The heater is too small for the space you are heating....
You need to get a second heater or get a bigger heater to get more heat...
Heatman101
Nov 30, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
I have a 3 car garage in Minnesota all insulated attached to house. What size and type of heater do I need. I also have 4 dogs that go in and out constantly. its about 840 SQ FT
Generally they say about 10 per SQ/Ft so in reallity you would need 8400 watts. You would then have to consider your ceiling height. If it is a 10 ft. ceiling and the fact that your dogs are going in and out you may need even more.
Oct 14, 2009 | Fahrenheat Ceiling-Mount Industrial Heater...
Heater location
Jan 06, 2009 | Dayton G73 Utility Heater
Audio buzz
Check to see if reversing the plug takes away the buzz. Some times turning the plug over in the wall socket i.e. reversing polarity, will remove the buzz.
Dec 09, 2008 | Philips HTS3400/37B System
Add line thermostat to fahrenheat space heater
Nov 30, 2008 | Marley Electric Hydronic Baseboard Heater,...
Heating & Cooling Logo
325 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
