Question about Toshiba 28N33 28" TV
Toshiba 2877db flashing green light ,how can the fault be cleared
Toshiba AC Pre-Def orange light is flashing as well as operation green light is flashing. What could the possible fault be.
Please re post and include the model number and place the question under the correct heading for our experts to pick up for you. This is laptops.
Dec 24, 2016 | Toshiba Computers & Internet
I have a 2011 Toshiba 55 55SL417Uand the picture wont come on the green flashes 3 times pauses 3 flashes pause over and over
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 21, 2015 | Toshiba 55 55SL417U LCD TV
Flashing green light once constantly
Main system control IC fault. When replacing, Main system control & its Memory IC; both should be replaced. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 18, 2014 | Toshiba Televison & Video
Toshiba Codes
Hi i have Toshiba 2877DB and need remote control code?
Nov 10, 2013 | Televison & Video
Just the power light comes on
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Dec 02, 2012 | Zanussi FJS1225W Front Load Washer
What is the code to sync up with a sky remote
Hello
Sky remote codes for Toshiba TVs are:
Toshiba
28W93B 2563DB
536 063 271 098 117 232 530 581 130 473 088 182 064 216 253 508
Toshiba
156T9B 175T9B 213T4B 2151TB 2197DB 2512DB 2535DB 2539DB 2550TB 2563DB 256T9B 28Z27B2 2812DB 2857DB 2835DB 2873DB 2877DB 28W93B 2500TB 3357DB 573DB 2879DB T1510T8 25001TB7 32DB 32M8DB 2855DB CT9689 2939DB 40PW03B MV40PWA 32M9DB3 2893DB 32317B 2573DB 337BB 2552D 36/21P 28207B 2173DB 285T8B 2173DB 28W8DBA 28N03B 2505 238DB 439J936 3377DB 2181TB 82Z27B 28W23B 32ZP18P 42PW33P 32NW2DB 28ZH37B 32W8DB 32ZP38B 32NW7DB 32WIS 28N33B VTV1400 2987DB
536
Toshiba
2101TB 213T4B 2573DB 32ZP38
581
Toshiba
3377DB
216
Toshiba
2987DB
253
Toshiba
2987DB 3339DB 2877DB 322D09B 2173D6 14N21B2 14N21B2
063
Toshiba
14T01B, 21TO1B, CT815, CT81500082B, CT824, CT832
746
Toshiba
TVD213B
726
Toshiba
CT90040
508
OK.
Oct 13, 2011 | Toshiba Televison & Video
I disconnected my TV when we were having work done in the house. At the time I had no trouble getting Sky. A new connection to the dish has been installed but I cannot get onto Sky. I have checked the...
Hello
To synchronise with sky you have to resynchronise it, as you have disconencted it and reconencted with new one. The sky remote codes for Toshiba to check with are:
28W93B 2563DB
Toshiba
536
Toshiba
581
Toshiba
3377DB
216
Toshiba
2987DB
253
Toshiba
Toshiba
746
Toshiba
TVD213B
726
Toshiba
CT90040
508
063
Oct 05, 2011 | Toshiba 32WLT58 32 in. LCD Television
Flashing green light on toshiba 2877db and wont switch on
i have a old toshiba 2877db tv it was working great then it just went off with a green light flashing on the on/off button but no picture and no sound can you please help
Nov 10, 2009 | GE 13GP243 TV
Toshiba 2877DB
Before you do anything else, make sure you do a hard reset. Unplug your television for an hour or two and then plug it back in. If you are still seeing the blinking lights and no picture or sound then we know of several possible prolbems that it might be. All of which require a local repair service to open the tv and replace a part.
Thanks,
Jul 03, 2008 | Televison & Video
Flashing error code
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Dec 20, 2007 | Toshiba e-Studio120 Copier
Toshiba 28N33 28" TV Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
