Question about YouTube Videos
Connect freeview recorder
How do I connect a freeview recorder
    Filmmaker:
    Uploaded 5 video answers.
  • 20 Answers
Try to use this link http://www.freeview.co.uk/set-up. Hope It can help your problem.
Posted on Jan 03, 2013
Can't tune in tv with dvd freeview.it states ext link problem
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
Oct 16, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I can't record digital tv on the dvd recorder coupled with a new philips tv with built in digital
You need a freeview box to connect to the scart INPUT of the DVD recorder. The Freeview box has to have a programmable timer built in. Connect your aerial to the freeview box, the aerial output then goes into the TV. You program the DVD to the times you want to record each program, but always the input is the SCart. You the program the Freeview box to change to the right program at the beginning of the program you want to record.
Jun 27, 2011 | Mico DVDR311
No instruction to set up the freeview box digihome dvb 915 can you help
Set up should be quite straightforward assuming you have all the bits.
You will need
  1. a standard co-axial aerial lead from your TV antenna to the female socket on the Freeview Box
  2. A scart to scart lead to connect the Freeview box (tv out socket) to the television.
If you wish to connect a video recorder or other equipment you may also need a second coaxial lead (male to female) for the RF through socket to connect to the aerial in socket on the video recorder.
If your TV does not have a scart socket you can connect the scart lead to the scart socket on a video recorder and then use the normal method of watching videos to view the Freeview TV pictures (here you may need to press the PAUSE button on your video recorder to prevent it going back into standby-mode after a few minutes).
Simply connect the box to your TV, turn on the power and the auto channel-scan will immediately detect and install all available channels.
If the Freeview box has been previously used in a different location / with a different TV transmitter you may need to re-tune it. Press the menu button on the remote control, scroll through the menu to set-up. Follow on screen prompts.
Feb 09, 2011 | Televison & Video
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
Connect philips dvdr80 to intigrated freeview tv
Solved the problem by connecting the freeview box back into the dvd recorder. Apparently because the dvdr was made before tvs with integrated freeview, it can only recieve decoded signals from a freeview box, ie analog
Jan 16, 2009 | Philips DVDR80 DVD Recorder
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Mar 24, 2008 | Televison & Video
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
YouTube Videos Logo
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
