I cannot adjust the filling mechanism . it doesnt seem to cut the water intake.
  • 22 Answers
Dry joint on circuit board
Posted on Jan 03, 2013
How difficult is it to replace toilet tank equipment?
The job is easy if you have any plumbing skills. Turn off the water. Disconnect the water hose at the bottom of the tank. Remove the nut holding the flush/fill mechanism and remove the mechanism. Reverse removal procedures and complete. Adjust for proper water level in tank.
Dec 03, 2014 | Home
Geberit how to adjust flush
You can probably only adjust the amount of water to be used in the flush. Adjust the water intake valve so that more water comes into the tank by raising the float mechanism. New, water-saving devices may not be adjustable. You'll just have to flush twice--negating any saving of water, right?
Feb 10, 2013 | Home
Leaking toilet from overflow
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing
If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
Feb 20, 2018 | Porcher Home
I have a 99 ponti sunfire 187k miles 5 speed
Sounds like either an evap system leak, maybe intake gasket. While it is running spray water around the intake, if it starts to cut out..you have a leak. If that doesnt do it, I would check the mass air flow sensor, and throttle postion sensor. Hope this helps.
Jul 12, 2010 | 1999 Pontiac Sunfire
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
I fixed a kink in the water line, water filled the ice maker, cubes froze, but the mechanism that pushes the ice out seems to have gotten stuck after the ice started to push out about 1/2". Any ideas on...
Ok. here is the fix. warm up the frozen cubes with a blow dryer to get them out. Then dry off the area, keep the metal bar up so more water doesnt come in and slow you down. When the ice cube mold is dry spray it with PAM cooking spray, which is a safe lubricant in this application. Let the Pam dry for ten minutes and then turn your lever down. You will have cubes with in 24 hours or less and they will eject as they should.
Jul 07, 2009 | Estate TS22AFXKQ Side by Side Refrigerator
Water pump doesnt stop running
bottom tray under dishwasher holds a cut out switch.this is activated when there is a leak from unit which fills the undertray.
Dec 14, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Water intake and wash cycle
change the water intake valve, that is the only answer i think
Oct 10, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Dishwasher is not giving out water
Call a plumber to check your water pipe or you could twist the tap cap back and fort. Runs the dishwasher, if no water still. change FILL VALVE this is an electro-mechanical device that opens a valve to allow water to flow.
May also be called a WATER VALVE or WATER FILL VALVE.
If this does not solve the problem , you need to change the control board.
Does sugestion solve your problem? let me know.
Oct 09, 2007 | Bosch 24 in. SGS43C12 Classixx...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
