Question about Elitescreens VMAX100UWH 101" 16:9 Projector Screen
My VMAX100UWH elite screen will not go back up. However I can hear the motor running when I press the up button. Is there a fix for it or does it sound like the motor is blown
I have the same problem. I removed the motor, at the end of the cylander that holds the screen on the motor side, there is a black cap that connects to the motor and makes the cylander turn. Mine was broken, hence the reason for the screen not retracting back up even though the motor still works. I contacted EliteScreens but they said they no longer carry parts for this screen. Now I'm trying to find the part online.
Posted on Nov 18, 2010
  • Brett
    Brett Dec 21, 2014
    We're you able to find the parts online? If so please advise. Thx
I CHANGED DRUM SUPPORT ROLLERS AND PUT BACK TOGETHER AN IT WILL NOT START
Suggest the following.
  • Check drum light. No light defective door switch. Light yes one leg of 220 circuit OK.
  • Be very sure motor doesn't start when you set to run. Belt may be off the motor and motor is very quite. Fix belt. Motor may be stuck or failed listen to hear if it is buzzing
  • When pressing start button listen for distinctive run relay activation. If when the start button is depressed I would expect to here the relay.
  • Motor run circuit relatively simple. The drum motor and blower are one assembly.
Nov 30, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Tip
How to fix a PS3 when it's frozen at startup
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · Step1
The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
· Step 2
Put your PS3 in Standby Mode.
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
· Step 3
Time to enter Safe Mode.
Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
· Step 4
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
· Step 5
jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a05/kb/9c/fix-ps3-it_s-frozen-startup-1.5-800X800.jpg'); }); Connect controller to PS3 screen.
You will then see this screen.
· Step 6
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
· Step 7
jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.com/images/a05/kb/9c/fix-ps3-it_s-frozen-startup-1.7-800X800.jpg'); }); Safe Mode options screen.
· Step 8
Select option number 3, (Restore File System). Then select yes to perform step.
· Step 9
You will then see this screen. "The hard disk's file system is corrupt and will be restored."
· Step 10
First press the PS button to turn the controller back on. Then press the x button and it will restore, it will then restart and your problem is fixed!
on Apr 02, 2010 | Video Game Consoles & Games
Tip
Fix PS3 "Corrupt Hard Disk"
Connect controller to PS3 screen. You will then see a screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. Connect controller to PS3 screen. You will then see this screen. Safe Mode options screen
-REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
on Feb 20, 2010 | Video Game Consoles & Games
Kenmore elite dishwasher 665.12793k311 will not drain automatically. Drains fine when drain button is pressed. Has been running perfect for the past 14 months then all of a sudden stopped draining aut
Wow, that's interesting! I would have guessed the control module (control circuit board) too. But, once upon a time, I encountered a similar situation, and the problem turned out to be the drain pump! It seems like that after the dishwasher ran in the main cycle (where the heater is used to heat up the water), the heat somehow made the drain pump stop working! I don't know if it made the motor wires expand and break a connection, or if the heat made the seals of the motor expand or somehow impeded the free-turning of the motor, but replacing that drain pump fixed the problem! If you want to try this, I would really like hearing back from you on whether or not that fixes your problem. Good luck!
Jan 16, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Our Kenmore Elite Dishwasher has a blinking green light next to the clean cycle. It won't reset. We changed the motor and this has been going on ever since. Do you know what we need to do to fix it....
Hello
Blinking green light can be reset by following two buttons in sequence: press HIGH TEMP WASH-HEATED DRY buttons in sequence around 3-4 times so that the control reset itself. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front washer show code cl? How do i fix it
The CL fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
You should have been able to clear the display by pressing the STOP/CANCEL button.
If you try running the washer again and continue to get this fault code even with a small or medium load, I recommend calling a service technician to diagnose and repair the washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 29, 2010 | Kenmore Elite 45986 Front Load Washer
Hi my hard disk's file system is corruped how can i fix it?
Connect controller to PS3 screen.You will then see a screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. Connect controller to PS3 screen.You will then see this screen. Safe Mode options screen
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
Kenmore Elite Gas Dryer. Cycle wont start
This sounds like one of two things in order of most likely:
- the centrifugal switch in the motor is not functioning (burned, stuck, broken)
- or the run winding in the motor is bad
Need more info, let me know...
May 08, 2009 | Kenmore Dryers
Dryer turns on, but does not run
Try to turn the drum inside with no clothes in it, does it turn freely both ways?
Then as someone is holding the start button, hold the door switch button, then try to turn the drum counter-clock wise, and see if it will start turning on its own.
If it does start turning, then the motor is more than likely the problem.
If it dosen't then the timer is more than likely the problem.
Feb 05, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Elitescreens VMAX100UWH 101" 16:9 Projector Screen Logo
550 people viewed this question
Top Elitescreens Televison & Video Experts
Are you an Elitescreens Televison and Video Expert? Answer questions, earn points and help others
