Question about Kodak DC215 Zoom Digital Camera
Battery tray clip is broken - Kodak DC215 Zoom Digital Camera
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello Tom, We are talking about an old Kodak model here. I do not know where you will find any parts except maybe a used one for parts on E-Bay. I would give that a shot. Sorry I can not help any further.
Best Regards, Russell
Posted on Jan 24, 2013
My SR750H has the tray locked and whatever I do it will not unlock
Is it locked, or jammed? Is there a small unmarked hole above the tray mechanism? If so, gently push a straightened paper clip into the hole until you see the tray open a bit. At this point you should be able to carefully use your fingernail to draw out the tray and retrieve your disc. Sometimes this is all it takes to unjam the mechanism. Other times a broken belt or gear renders the mechanism broken.
Sep 12, 2013 | Sony Televison & Video
99 dodge stratus, battery hold down bracket. I broke 1 of the bolt how do I remove and replace.
The best way would be to remove the battery and try to heat the nut and use a pair of grip pliers to remove the broken bolt.
Another way would be the remove the nut, this nut may be welded to tray. you will need to chisel it off and then use a regular nut. the only problem would be you should put a small tack weld on the nut to keep it from spinning next time you need to remove the battery.
The last thing is if it does not have a welded nut but rather a clip nut, in which you can pry if off by breaking the clip in two and removing it.
Mar 01, 2012 | 1999 Dodge Stratus
3110cn paper tray has small white plastic clip which has broken off on left side when pulling tray open. Now window states load paper tray. Any fix or where a paper tray can be purchased. Dell does not...
I've seen this problem before on Dell 3110/ 3115 and other versions of the same printer chassis.
The broken part prevents the paper being 'lifted' to the pickup roller and paper out sensor, so it thinks ther is no paper in the tray, and can't pick it up.
Look on 'the usual internet auction site' (as ever), and you'll probably find one (I'll list one in the next couple of days).
Jun 08, 2010 | Dell 3110cn Laser Printer
Tray Error
Paper switch has been knocked off. Remove the tray and look inside about halfway in, on the right side near the gray roller that grabs the paper, you will probably/hopefully see a black switch (LED), with a retractable 'finger' that 'swings" in and out, which is what detects the paper. Hopefully the finger hasn't been broken off. The switch may be hanging down. If you have the extra tray installed on your copier, check it, to see how it "clips on".
If the clipping mechanism to attach it to the frame is broken, you can try gluing it in with crazy glue, or ABS cement is the best.
Please rate me.
Mar 30, 2009 | Ricoh Aficio 180 Laser Printer
Remote Control Altec Lansing IM600 - Battery
Turn the remote upside down. At the bottom, there is a slot that opens the battery tray and a series of grooves that are part of a clip that releases the tray. Insert the fingernail of your thumb into the grooves and the fingernail of your index finger into the slot. Ease the grooves (clip) toward the middle of the remote and slide the tray out. There is a ridge in the tray that matches the battery only when the battery is in the proper position. Slide the tray back in. If the remote doesn't work, you've probably inserted the battery in the wrong position.
Dec 31, 2008 | Altec Lansing Inmotion-IM600...
Coin Tray Wont Stay Closed
The plastic spring clip had become stressed and had "moved" out of position resulting in no "retaining presure,hence the coin tray/fuse cover would not stay in the "Closed" position."Simple" $6.75 fix.
Dec 29, 2008 | 2002 Subaru Forester
Plastic clip holder to hold dishwasher tray is broken
If you are handy, contact an appliance parts store that sells retail. You should find them in the yellow pages. Brand and model number will be needed usually on the inside edge of the door.
If you are unsure, Look in Repair and Service link at Fixya.com for a repair service in your area.
Good Luck,
Dec 05, 2008 | Home
Top Tray clips on diswasher broken
I have the same problem and there is an inherent design flaw. You can normally buyt these at most outlets, however you can buy more than 4 to support the tray, or I have cut a small diameter aluminium tube (1/4" diameter) and threaded it through the tray from the side and into the sliding rails. It is not an ideal solution, but will last a lot longer than the silly grey wheels! Doi two bits ( one at the back and one at the front.) You have to play around a bit to get the drawer to move in and out, but it is much stronger than before. Good luck Charles in Australia
Aug 17, 2008 | Westinghouse 24 in. MDP531 RF...
Hp deskjet 6988dt bottom paper tray
Usually every clips has a certain way to sit on it's place, and it's can't be explained well enough through text, but you can try to learn it's way, by observing few important things:
- Is it reachable enough (visible & holdable)
Don't force it if it's not reachable, perhaps you have to open some screw first, and you've got to be careful
- Is there any broken mark on the clips or on the printer, coz if it is, then you have to fix it first, or get a new one
- Try to learn to put the clip back on it's place without the spring first, coz it will be more difficult, then after you got the idea, try using the spring.
Good luck :)
Feb 01, 2008 | Office Equipment & Supplies
Kodak DC215 Zoom Digital Camera Logo
37 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
