Question about Microsoft Windows Server Standard 2003 for PC
Procedure of configuring dns server
I have install dns in windows 2003, how it will configure ?
    Problem Solver:
  • 13 Answers
You can find all needed information & step by step guide at
http://support.microsoft.com/kb/814591 and at http://www.computerperformance.co.uk/w2k3/services/DNS_Home.htm
Posted on Jan 19, 2009
How to set DNS setting
This step-by-step article describes how to install and configure DNS on your Windows Server 2003 computer.
Before You Start loadTOCNode(2, 'summary'); Before you start to configure your DNS, you must gather some basic information. Internic must approve some of this information for use on the Internet, but if you are configuring this server for internal use only, you can decide what names and IP addresses to use.
You must have the following information:
  • Your domain name (approved by Internic).
  • The IP address and host name of each server that you want to provide name resolution for.
Note: The servers may be your mail servers, public access servers, FTP servers, WWW servers, and others.
Before you configure your computer as a DNS, verify that the following conditions are true:
  • Your operating system is configured correctly. In the Windows Server 2003 family, the DNS service depends on the correct configuration of the operating system and its services, such as TCP/IP. If you have a new installation of a Windows Server 2003 operating system, then you can use the default service settings. You do not have to take additional action.
  • You have allocated all the available disk space.
  • All the existing disk volumes use the NTFS file system. FAT32 volumes are not secure, and they do not support file and folder compression, disk quotas, file encryption, or individual file permissions
Install DNS loadTOCNode(2, 'summary');
  1. Open Windows Components Wizard. To do so, use the following steps:
    1. Click Start, click Control Panel, and then click Add or Remove Programs.
    2. Click Add/Remove Windows Components.
  2. In Components, select the Networking Services check box, and then click Details.
  3. InSubcomponents of Networking Services, select the Domain Name System (DNS) check box, click OK, and then click Next.
  4. If you are prompted, in Copy files from, type the full path of the distribution files, and then click OK.
Configure DNS loadTOCNode(2, 'summary');
  1. Start the Configure Your Server Wizard. To do so, click Start, point to All Programs, point to Administrative Tools, and then click Configure Your Server Wizard.
  2. On the Server Role page, click DNS server, and then click Next.
  3. On the Summary of Selections page, view and confirm the options that you have selected. The following items should appear on this page:
    • Install DNS
    • Run the Configure a DNS Wizard to configure DNS
    If the Summary of Selections page lists these two items, click Next. If the Summary of Selections page does not list these two items, click Back to return to the Server Role page, click DNS, and then click Next.
  4. When the Configure Your Server Wizard installs the DNS service, it first determines whether the IP address for this server is static or is configured automatically. If your server is currently configured to obtain its IP address automatically, the Configuring Components page of the Windows Components Wizard prompts you to configure this server with a static IP address. To do so:
    1. In the Local Area Connection Properties dialog box, click Internet Protocol (TCP/IP), and then click Properties.
    2. In the Internet Protocols (TCP/IP) Properties dialog box, click Use the following IP address, and then type the static IP address, subnet mask, and default gateway for this server.
    3. In Preferred DNS, type the IP address of this server.
    4. In Alternate DNS, type the IP address of another internal DNS server, or leave this box blank.
    5. When you finish setting up the static addresses for your DNS, click OK, and then click Close.
  5. After you click Close, the Configure a DNS Server Wizard starts. In the wizard, follow these steps:
    1. On the Select Configuration Action page, select the Create a forward lookup zone check box, and then click Next.
    2. To specify that this DNS hosts a DNS zone that contains DNS resource records for your network resources, on the Primary Server Location page, click This server maintains the zone, and then click Next.
    3. On the Zone Name page, in Zone name, specify the name of the DNS zone for your network, and then click Next. The name of the zone is the same as the name of the DNS domain for your small organization or branch office.
    4. On the Dynamic Update page, click Allow both nonsecure and secure dynamic updates, and then click Next. This makes sure that the DNS resource records for the resources in your network update automatically.
    5. On the Forwarders page, click Yes, it should forward queries to DNS servers with the following IP addresses, and then click Next. When you select this configuration, you forward all DNS queries for DNS names outside your network to a DNS at either your ISP or central office. Type one or more IP addresses that either your ISP or central office DNS servers use.
    6. On the Completing the Configure a DNS Wizard page of the Configure a DNS Wizard, you can click Back to change any of the settings. To apply your selections, click Finish.
After you finish the Configure a DNS Wizard, the Configure Your Server Wizard displays the This Server is Now a DNS Server page. To review all the changes that you made to your server in the Configure Your Server Wizard or to make sure that a new role was installed successfully, click Configure Your Server log. The Configure Your Server Wizard log is located at %systemroot%\Debug\Configure Your Server.log. To close the Configure Your Server Wizard, click Finish.
-----------please let me know if this guideline helps-------------
Jun 20, 2011 | Computers & Internet
Tip
Server 2003 & client configuration
<p><span>Some days before I have done a job on Windows Server 2003 Enterprise edition & Client XP. It is departmental food court. In the office room of the restaurant have a system which will be Server system and main domain. There was another 8 system in every department of food <span> </span>with printer for billing.I</SPAN><br> <p><span>Windows Server 2003 includes a mission critical Windows Server operating system, such as security, reliability, availability, and scalability.</SPAN><br> <p><span>You have to install DNS server for DC without DNS the client computers wouldn't know which one is DC.You can host DNS on a different server than DC.</SPAN><br> <p><span>Before Starting the DC installation process you need to make sure the <span> </SPAN>following points</SPAN><br> <p><span> </SPAN><br> <p><span>1)You have installed Basic windows server 2003 installation</SPAN><br> <p><span>2)Make sure you have assigned a static ip address to your server</SPAN><br> <p><span><span> </SPAN>Now start DC and DNS Setup process</SPAN><span></SPAN><br> <a><span> </SPAN></A> <span><span>Domain Controller</SPAN></SPAN><span></SPAN> <span>Active Directory is a huge topic in itself. While DCPROMO is easy to run, planning of both the physical and the logical structure is the key to a trouble free active directory. </SPAN> <p><span>Domain controllers do not have to be your most powerful machines, however they must be reliable and always available to answer logon requests. </SPAN><br> <a><span>DNS (Domain Name System)</SPAN></A><span><span> </SPAN></SPAN><span>Role</SPAN> <p><span>Once DNS is setup, it runs itself thanks to the new dynamic component hence DDNS. TCP/IP knowledge plus understanding of how DNS works is essential when troubleshooting connectivity problems.</SPAN><br> <p><span>DNS enables client machines to resolve servers IP addresses. Once the client finds the server, Active Directory uses LDAP to locate services like Kerberos, Global Catalog that clients request.</SPAN><br> <a><span>Print Server Role</SPAN></A><span></SPAN> <p><span>In my experience there is a contrast between the software settings which are easy to configure and the hardware which constantly need for attention e.g. paper jam, 'out of toner'. Check list for print server:</SPAN><br> <p><span></SPAN> <br> <p><span>Printer Priority</SPAN><br> <p><span>Network Printers</SPAN><br> <p><span></SPAN><br> <p><b><span>Client Configuration :- </SPAN></B><span>After</SPAN><span><span> Installation of Windows Xp give the IP Add on TCP/IP of IPV4.If you want to manually configure DNS server addresses, click</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Use the following DNS server addresses</SPAN></b><span><b><span>,</SPAN></B></SPAN><span><span> and then type the preferred DNS server and alternate DNS server IP addresses in the</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Preferred DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>and</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Alternate DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>boxes. After all job try to ping each other. I'm trying this and it also pinging. Files and data also can be shared through it.</SPAN></SPAN>
on Feb 15, 2011 | Computers & Internet
I have win2003 i want it serover what can i do
You can do a lot with this operating system.
Some of his features are: DOMAIN Controller, Active Directory, Ftp Server, DHCP, Web Server, Terminal Server, File server etc.
Here i have some very useful links.
About Windows 2003 Server Editions: http://en.wikipedia.org/wiki/Windows_Server_2003
Futures: http://www.microsoft.com/WindowsServer2003/evaluation/features/default.mspx
Configuring DNS Server: http://www.petri.co.il/install_and_configure_windows_2003_dns_server.htm
Configuring DHCP Server: http://www.windowsreference.com/windows-server-2003/install-and-configure-dhcp-server-in-win-server-2003-step-by-step-guide/
Configuring File Server: http://www.windowsnetworking.com/articles_tutorials/File_Server_Windows_2003.html
Configure Printing Server: http://www.brightrev.com/how-to/enterprise/55-best-practices-for-setting-up-a-windows-print-server.html
Configure FTP Server: http://support.microsoft.com/kb/323384
Configure Active Directory: http://helpdeskgeek.com/how-to/windows-2003-active-directory-setupdcpromo/
Configure Web Server: http://support.microsoft.com/kb/324742
All these are only some of his features.
I hope is useful to you and your friends
Mar 13, 2010 | Microsoft Windows Server 2003 Enterprise...
Make additional DNS
Yes, all Windows Servers have the option to install DNS.
Set up a second Windows server and configure it to be a secondary server for your DNS domains on you current server.
Add the second DNS server's IP address to the secondary DNS field to your DHCP scope options and to all computers with static IP configuration so they will use it when your primary DNS is unavailable.
Don't underestimate Window's built-in Help and Support. It will help you install DNS and configure it.
Good luck.
Jul 29, 2009 | Dell Computers & Internet
Dear sir, How can i configure my domain
First and formost, you need following check list before configuration
1) System partition must be formatted as NTFS.
2) Machine must have static IP address.
3) DNS installed
Then run a dcpromo command and configure domain.
Jun 10, 2009 | Microsoft Windows Server Standard 2003 for...
DNS Name resolution Between private & Public network.
You do not need to configure ISP's PTR records. Instead define their DNS addresses as forwarders in the properties of DNS server under forwarders tab and flush DNS cache.
Mar 24, 2009 | Microsoft Computers & Internet
DNS
firwstu important for
dns domain name services
name to ip\
ip to name
and createto host id
and pointer.
create todomain name.
bye
Jun 04, 2008 | Microsoft Windows Server Standard 2003 for...
First timer installing a Server network
Well i'm just going to start where i would start. First off, how do your machines on the network get their IP? DHCP?
Is the first listed DNS server the AD server? 192.168.1.1?
Also make sure your using case sensitive domain information when your trying to connect. It is rare but i have had that be my trouble.
I have remote software available and would love to help you fix this hands on if possible. I live for network problems ;)
Sep 29, 2007 | Microsoft Windows Server Standard 2003 for...
Win server 2003 enterprise
You need to ensure your DNS server is the first in the workstation's DNS list.
Does this help?
Sep 27, 2007 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server Standard 2003 for PC Logo
113 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
