Question about Rcf ART 715A Powered 2Way Speaker (750 Watts 1x15 in)
Rcf art 715a problem status led
Defect led status
Can I download and print the manual for the ART 355 Dual 31 Bank Graphic Equalizer
Simple, how much instruction would you need? Check here http://www.manualslib.com/manual/210377/Art-355-Eq.html
Mar 05, 2013 | ART 355 Dual 31 Band Graphic Equalizer
Need the manual
V/u meter not operating. no tube light?
If the tube is not lit, then it may have a broken heater... replace the tube... OR the power supply may have a problem.
Sep 10, 2011 | ART New Art Tube MP Studio V3 VIII Mic...
Protect indicator is always on and motor boating sound
The amplifier is unable to achieve DC balance. This will require servicing. Could be a bad capcitor in the power supply.
Sep 04, 2011 | Rcf ART310A 10 Active Reference Speaker...
Hi i have recently purchased an rcf hc3200 and 4 x event 4000 speakers, these were all dommenstrated and shown to be working fine however when i connect 1 speaker to the amp (either channel) the sound...
Bass cancellation can occur if the polarity of one cable is reversed? Positive at the amp MUST go to the positive at the speakerS else one speaker will be pushing & the other pulling & the low frequencies get cancelled. You may also hear some strange imaging effects as you walk around the room - a bit like stereo from a mono setup.... check your cables :-)
Mar 23, 2017 | Rcf Hc 3200 Rcf Hc3200
The Limit Prot LED on my RCF Art-321A speaker remains on upon power up. The speaker also pops upon powering down. What do you think it could be? Thanks
The amp is blown. Some popping on power down is NOT uncommon, but the protect LED means the pwer amp is out of balance which is ******* speakers. Take in for repair.
Aug 05, 2011 | ART 315-a Rcf Art 315a 2-way Proaudiostar
Need the part nmber for a rcf art 315 woofer 15"
The part number can probably be obtained from RCF directely as the speaker may be specially made for them. The specs are:
15" high power woofer, 64mm edge wound aluminium coil
email them to request part number at:
e-mail: rcf-usa@comcast.net
Apr 13, 2011 | ART 315-a Rcf Art 315a 2-way Proaudiostar
Hi my name is Mike and I have a problem with my mini spot. It was working fine for about 2 weeks. Now right when i start, instead of it going through its intitial 10 second or so boot up (with the red led...
hey Mike, I just got 2 brand new minspot rgbws and they worked for 3 days and now tonight the same thing!
they power up and goto a white light and dont move. no display on led panel either...
did you find a fix?
Apr 11, 2011 | Chauvet Minspot Rgbw Min Spot Led Mini...
I have bought a Lexicon alpha and have a consenser mic. Since the alpa doesn't support condenser mics I am running the mic through the system I bought it with, a ART TUB MP. Still I cannot get any...
You should be using XLR to XLR cable from the ART to the Alpha. You need to have recording software and the driver for the Alpha correctely loaded. Verify that in the PC when you go to the control panel in Windows and click on the "Sounds and Devices Icon that clicking on the VOICE tab that the Alpha is listed as the default audio for both in and out.
Dec 27, 2010 | Lexicon Alpha Personal Recording Studio
My peavy has three lights at power on when in use red light comes on is that beacuse my amp is overheating or is it normal it does that when i crank the volume amp i not hot well vented
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00512180.pdf Page8 sections 2 through 4 discusses the LEDs. I think what you arte talking about is the DDT active LEDs. Page 12 specifically discusses this and page 15 notes that Red signifies DDT clipping. Peavey recommends that you don't defeat the DDT circuit and that is good advice as it protects your amp and your speakers. The clipping is not caused by the amp but by the amount and quality of signal being input. Check earlier in your signal chain for the cause.
Aug 14, 2010 | Peavey Pv 2600 Power Amplifier
Rcf ART 715A Powered 2Way Speaker (750 Watts 1x15 in) Logo
50 people viewed this question
Top Rcf Music Experts
Vito Vacirca Jr.
Are you a Rcf Music Expert? Answer questions, earn points and help others
