Question about Brother IntelliFax-2820 Laser Fax
Settingup a group fax number
I want to set up a group fax number so that I can send communications to all our Pharmacies in Southwark at the same time. How do I do this?
The model I have is Brother 2820. I am not sure if this is the latest model or an older one. Serial number: E63380C7J271588
I also need to do this for the Brother MFC-8860DN model.
Serial number: E64052G8J732701
Hope you can help.
Thanks,
Ian Townson
  • ian_townson Jan 19, 2009
    Where do I find the 'brodcast mode'. It isn't on the 'menu'. Also when I find this - what do I do then? Do I tap in all the individual fax numbers of each pharmacy and then save them before sending stuff? I need more isntructions on this. Can you help?
    Champion:
  • 320 Answers
You will need to go to the broadcast mode for multiple numbers
Posted on Jan 19, 2009
  • STEVE RAYMOND Jan 19, 2009
    hopefully you have the manual that came with either one of the machines, it takes you thru the procedure step by step, otherwise we will be emailing back and forth for the next couple of days good luck
I need to send 1 fax to several recepts
You can send a fax to up to 142 fax numbers, using any combination of dialing methods:
- One-touch Speed Dialing (up to 32 destinations)
Press the desired One-Touch Speed dial button(s)
- Coded Speed Dialing (up to 100 destinations)
Press [Coded Dial] > enter the 2 digit code (00-99) using the numeric buttons and be sure to press [Coded Dial] before each code
- Regular dialing and redialing (10 destinations)
Enter the number using the numeric buttons or [Redial/Pause] and be sure to press [Set] after each entry with the numeric keys
After all the numbers are listed, press [Start]. The machine will scan in the document (memory) and then begin sending it to the destinations in numerical order, starting with One-Touch, then Coded and finally the numbers dials with the numeric keys.
You can also create a group if you frequently send faxes to the same group of people by first saving them as One-Touch and then adding them to a new group.
Apr 13, 2011 | Canon FAXPHONE L170 Plain Paper Laser
How do I send one fax to multiple receipents?
you need to set up a group to send to. So if the group is always changing this may not help much.
Groups allow you to send the same fax message to multiple numbers (broadcasting). You can store the Groups on your One-Touch keys or SpeedDial locations and then broadcast by pressing a One-Touch key and Fax Start or by pressing Search/Speed Dial, the three digit location and FaxStart. First, you will need to store each fax number you wish to includein your Group as either a One-Touch or Speed Dial number. Then, you can combine these numbers into a group. Finally, you can have up to six Groups, or you can assign up to 131 numbers to one large Group. Each Group uses one One-Touch key or Speed Dial location. To set up a Group, please follow these steps:
1. Press Menu, 2 (Fax), 3 (Set Auto Dial), 3 (Setup Groups).
2. Press the One-Touch key on which you wish to store the Group or pressSearch/Speed Dial followed by the three-digit Speed Dial location where you wish to store the Group. The LCD will read SETUP GROUP:G0 ENTER & SET.
(from the Brother manual)
Nov 18, 2010 | Brother IntelliFax-4100e Fax
How would I set up on my fax machine to send one report to multiple numbers?
You need to add numbers first in all Speed Dial & then add those speed dials in Group dials.So that you can send that group to all locations at 1 time.
If you think it was helpfull rate me..
Aug 04, 2010 | Office Equipment & Supplies
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
Program one touch button to send fax to multiple numbers
Setting one touch numbers:
press function 72
set
press 1 for one touch numbers
press a position on the soft pad example 01
enter fax number with round buttons
set
enter name with soft pad letters
set
continue with more numbers or press stop to end.
For GROUP DIALING
Setting Group Dial:
press function 73
set
choose group dial
set
press program 1
set
name the program such as field offices.
set
press the one touch numbers you entered in the first step for this group,,,,01,02,05,08,17 etc
press set
press stop
load document in feeder, press Program 1 key, START
Jan 23, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
How to send a group fax for panasonic UF-8000
For a one time action
Press the first one touch number
Press Set
Press the second one touch number
Press Set
etc, etc.
set
When all numbers are entered, put the document in and press START
To permanently set up a GROUP
Press 73 SET
Select GROUP
press the stations you want to be in the
group one after another
press PROGRAM 1 key
Name the group
press set.
Jan 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
I need to store a lot of fax numbers and every monday send out a mass fax to all of these numbers. How do I do this?
Press Function 72
Choose ONE TOUCH
Put the numbers in one touch positions 01...02...03...etc.
Press Function 73
SET
Choose GROUP
Press PROGRAM 1 on soft pad and name it. Press SET
Add the one touch numbers into PROGRAM 1 by pressing their numbers on the soft touch pad.
01...02...03...etc. SET....STOP
Nov 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
WORKCENTRE PE220 - How do I print reports from the fax? and I want to set it up to do automatically, but I also need to look at a certain day, to see if a fax went through. Thanks
Hope this helps.
  1. Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
Report / List Description Phonebook List This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers.
NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
Sent Fax Report This report shows information on recently sent faxes. System Data List This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified. Scheduled Job Information This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax. Message Confirmation This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job. Junk Fax Number List This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID. Multi-communication Report This report is automatically printed after sending documents from more than one location. Power Failure Report This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure. elem_1_spacer.gif
Jul 23, 2008 | Xerox Office Equipment & Supplies
Is there a way to program it to fax to a group of numbers at one time
You can use the "Broadcast " feature to send one fax to up to 112 numbers listed in your speed dial. To set this up:
  1. Insert the original into the ADF.
  2. Press Quick Scan/Reports. The display should show how much memory is available.
  3. Enter the One-Touch or Speed Dial numbers for the recipients you want to send to (one after the other). You can also setup a group dial number.
  4. Press Fax Start. The machine will scan the document into memory and then dial all the numbers you've entered. If any are busy it will attempt to redial.
  5. Press Stop/Exit at any time to cancel the broadcast.
If you need further instruction on how to setup group or speed dial numbers, Brother provides the user manual online.
Hope this helps!
May 15, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Multiple faxes
you can send it seperat only
Sep 19, 2007 | Canon LaserClass 2050 Plain Paper Fax
Brother IntelliFax-2820 Laser Fax Logo
258 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
