Question about Microsoft Excel for PC
I am unable to define values between the words
Hi sir i am mukesh kumar
i am trying to get value between the words like
sandeep22mohan
sam26jammy
like this sequnce many words are
plz help me if possible
    Sniper:
  • 70 Answers
Hmm interesting one...assuming all the words are all listed in colum A, I would recommend using a combination of ISNUMBER, CONCATENATE & multiple MID.
As I found it hard to describe the 3 formula sets, I decided to post a dummy file with an example here using some of the words you suggested (click in the download file button, the XLS file should load inmediatly).
Note: I made the example valid only for word up to a maximum of 20 characters long, but if you have longer words, just repeat on more columns.
If the solution works for you, please rate my response :)
Cheers,
Ed
Posted on Oct 24, 2009
Program that will compute the volume of a cone
Volume of right circular cone is (1/3)*PI*(r^2)*H
Define real variables r, h
Define constant PI or use built in name.
Prompt for input r=?
Read value and store in r
Prompt for height H=?
Read value and store in H.
Print Volume =, (1/3)PI*r^2*H, unit^3
Dec 27, 2013 | Computers & Internet
Whats a median
The median of a finite list of numbers can be found by arranging all the observations from lowest value to highest value and picking the middle one (e.g., the median of {3, 5, 9} is 5). If there is an even number of observations, then there is no single middle value; the median is then usually defined to be the mean of the two middle values. It is similar to an average. or a root mean square value (RMS).
Nov 30, 2013 | Computers & Internet
Puk no of uninor
Hi sir this is RAVI KUMAR my uninor sim has been block and sim ask for PUK no so plz send me puk no. sim no-89918191114000235015 and cont no-8885729390
Jun 09, 2013 | Samsung SGH-t329 Cellular Phone
Declare 2 arrays with 5 as index value of each. the user will input values to the first array(user-defined). Transfer value of the first array to the second array.Get the sum of the second...
You could do this by creating two arrays as such:
int firstArray[5]; int secondArray[5]
and then the sum variable:
int sum = 0;
then you could do a for loop to find the sum of the second array:
Feb 22, 2011 | Microsoft Visual C++ Professional Edition...
Plz tell me Sir/Madam. what is Hlookup And give me example
Hi Geetad11
This is Horizontal lookup , used to look up value in a 2 dimensional table .It searches for a value in the top row of a table or an array of values, and then returns a value in the same column from a row you specify in the table or array. Use HLOOKUP when your comparison values are located in a row across the top of a table of data, and you want to look down a specified number of rows. The H in HLOOKUP stands for "Horizontal."
Formulae Syntax
HLOOKUP(lookup_value,table_array,row_index_num,range_lookup)
Lookup_value is the value to be found in the first row of the table. Lookup_value can be a value, a reference, or a text string.
Table_array is a table of information in which data is looked up. Use a reference to a range or a range name.
  • The values in the first row of table_array can be text, numbers, or logical values.
  • If range_lookup is TRUE, the values in the first row of table_array must be placed in ascending order: ...-2, -1, 0, 1, 2,... , A-Z, FALSE, TRUE; otherwise, HLOOKUP may not give the correct value. If range_lookup is FALSE, table_array does not need to be sorted.
  • Uppercase and lowercase text are equivalent.
  • You can put values in ascending order, left to right, by selecting the values and then clicking Sort on the Data menu. Click Options, click Sort left to right, and then click OK. Under Sort by, click the row in the list, and then click Ascending.
Row_index_num is the row number in table_array from which the matching value will be returned. A row_index_num of 1 returns the first row value in table_array, a row_index_num of 2 returns the second row value in table_array, and so on. If row_index_num is less than 1, HLOOKUP returns the #VALUE! error value; if row_index_num is greater than the number of rows on table_array, HLOOKUP returns the #REF! error value.
Range_lookup is a logical value that specifies whether you want HLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, HLOOKUP will find an exact match. If one is not found, the error value #N/A is returned.
Remarks
  • If HLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than lookup_value.
  • If lookup_value is smaller than the smallest value in the first row of table_array, HLOOKUP returns the #N/A error value.
Example
The example may be easier to understand if you copy it to a blank worksheet.ramsoft.jpg
Oct 06, 2010 | Microsoft Excel for PC
C++
http://www.cplusplus.com/doc/tutorial/
May 01, 2009 | Computers & Internet
Circle circumfrance how can define pi valu 22/7
Entire books have been written on this topic; it's far beyond the scope of a single post. I would recommend the book "The History of pi" by Petr Beckmann for a readable, non-technical introduction.
Jul 17, 2008 | Office Equipment & Supplies
Trying to update pass word this return status indicate that the value provided as the current pass word is not correct.
Maybe you entered the value that the windows cannot accept it. For example the *, or / try to put a password in a plain word only
Apr 16, 2008 | Computers & Internet
DCT4 UP DATE
hi i am mukesh kumar i want to how i repair moblie phone
please tell me .
thanks
Dec 24, 2007 | Nokia 6600
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
