Computer won't turn on after trying to plug in
  • 32,281 Answers
You never plug anything into the expansion slot whilr the computer is turned on and running. This is a sure way of damaging the motherboard.
Turn off the computer and remove the wireless adapter and then boot up your computer, if it still does not boot up then the motherboard most likely been damaged.
I suggest you take it to a computer repair shop to assess the damage and give you a repair quote.
Posted on Jan 03, 2013
  • mmafighter19
    mmafighter19 Jan 03, 2013
    When I turn it on the fans come on for a couple seconds and then it just dies. So I guess. My mother board is done.
oldnovii
  • 667 Answers
SOURCE: we have just purchased a
Have you opened the computer or just looked at the back and found a couple of blank silver strips. If you have not opened it these strips are just slot covers.Shut down the pc.Unplug it. Open the pc and touch part of the metal frame to ground yourself and discharge any static electricity.There will be one screw holding the slot cover in place. Pick a PCI slot that you want to use and remove the cover from that slot. Insert the card and use the same screw to hold your card in place. Then close the case.Plug the pc in and power up. Windows will say found new hardware and installing.If this what you meant and this fixed your problem please rate this as fixed. If you meant something else or need help opening the pc, please add a comment and let me know. I'm more than happy to help you further. Thanks.
Posted on Apr 19, 2008
var-pun
  • 331 Answers
SOURCE: turn on computer fans run a second shut off i unplug cpu power supply then run
may be the connection to the smps is not right
or may be the fan blew out
Posted on Sep 06, 2008
preachw996
  • 1179 Answers
SOURCE: Unsure if my wireless PCI adapter will fit in my dimension 2400?
You can get your systems exact specs on the Dell website under the support page. Hope this helps.
Posted on Jan 10, 2009
cpenzes
  • 1102 Answers
SOURCE: computer tower started beeping
If you added more memory this may make your tower beep.
If so I WOULD REMOVE THE ADDED MEMORY AND THEN RESTART
Posted on Jan 12, 2009
ODCaloney
  • 260 Answers
SOURCE: dell dimension 4700 computer keeps shutting down at start up
That's pointing to the memory. Try re-seating the RAM.
Posted on Mar 19, 2009
Where do you plug in the adaptor on the e machine for wifi
Depends on what kind of Wireless Adapter you are using
There's the Wireless Adapter Card
Comes in three styles of connection,
1) PCI Wireless Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4389486&CatId=2701
2) And PCI-Express x1 Wireless Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1068811&CatId=2688
PCI-Express x4 style may be out there too.
(I've never bothered to look. I use the USB style)
A Wireless Adapter Card based on the PCI technology, goes in a PCI slot. Generally White in color, but NOT always,
http://en.wikipedia.org/wiki/PCI_local_bus
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
A Wireless Adapter Card based on the PCI Express technology, is used in a PCI-Express x1 slot,
http://en.wikipedia.org/wiki/PCI_Express
http://en.wikipedia.org/wiki/File:PCIExpress.jpg
Top example is a PCI-Express x4 slot.
Moving down, next is a PCI-E x16 slot
Next, PCI-E x1 slot
Next is a PCI-E x16 slot,
and the last one at the bottom is a PCI slot.
Notice they are all Yellow.
Color of connector does NOT matter.
What the expansion slot is, does........
Also there is a USB Wireless Adapter,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3970955&CatId=2704
This type of Wireless Adapter, plugs into any available USB port on the computer.
Front or back of an eMachines desktop computer, in any available USB port.
Any available open USB port, on an eMachines laptop.
(Or any computer manufacturer)
What is the model number of the eMachines Desktop PC?
Examples, T1090, T2460, W4685, D2246, etc.
I should be able to tell you what motherboard is used inside, and may have access to a link, to the Motherboard Manual.
Post back in a Comment.
Regards,
joecoolvette
Apr 14, 2013 | E-Machines eMachines Desktop PC
How to add usb ports to Dell 530
Suggest use a USB adapter card.
More specifically a PCI USB adapter card.
Dell Support > Inspiron 530 Series Desktop PC > Owner's Manual,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In the list click on - Removing and Installing parts
1) Unplug the computer from power.
[Unplug FROM the surge protector, not the back of the computer. (Power Supply)
Unplugging from the back could lead to a power surge ]
2) Computer on a table open the computer case,
Click on - Removing the Computer Cover - in the list.
3) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware inside the computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
4) http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/parts.htm#wp1184332
Here you see an illustration of your motherboard. Oriented as it is in your computer case. (Just no hardware components, nor cables are attached)
At the bottom of the motherboard are 2 White long expansion slots.
In the illustration they are labeled by the numbers 21 and 22.
If one of these slots is open, and not being used, you can install a PCI USB adapter card.
This is one example of a PCI USB adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&Sku=S262-2744
At the back of the computer, located towards the bottom, are the Expansion Slots.
Four horizontal slots.
If there isn't some sort of add-on adapter card already installed, all of the expansion slots will be covered with an Expansion Slot Cover.
If there is an add-on adapter card installed of course, one of the expansion slot covers will be removed.
Line up the PCI USB adapter card with the open PCI slot, you have chosen.
Now look at the expansion slots at the rear of the computer.
Notice what expansion slot that the PCI USB card's bracket, lines up with.
Go to the back of the computer, and view the small metal bracket on the bottom right. Loosen the Thumbscrew, and swing the bracket out. (Thumbscrew is supposed to just loosen, not come out)
Remove the expansion slot cover for your PCI slot choice.
Install the PCI USB adapter card.
Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Line them up, then push the PCI USB card straight down into the PCI slot.
Also watch the metal bracket on the back of the PCI USB card.
The 'tang' at the Bottom, slides down in-between the framework.
The top of the bracket has a half-moon notch, that lines up with a small 'dowel' on the computer case framework.
Make sure it is aligned, and the bracket is aligned.
What I am referring to will become readily apparent, as you go to install the PCI USB card.
If there are any other add-on adapter cards, they may try to fall out, when you go to install the new add-on card.
You just have to line them up, so their bracket notches are all on the 'dowels', and hold them in place. Then swing the 'door' closed. Tighten the thumbscrew.
If you have an Add-on card in the way, and by moving it to the other PCI slot, will allow you to install the PCI USB card, go ahead, and move it.
Doesn't matter. BIOS will find it, and assign an Interrupt Request.
There are two other expansion slots above the 2 white PCI slots.
The expansion slot right above the top PCI slot, is a PCI-Express x1 slot.
If this slot is open, OR the only one available, you can use a PCI-Express USB adapter card.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606149&CatId=511
The last expansion slot you have is above the PCI-Express x1 slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer...
What Wireless card to buy
A version that is Wireless N.
You can install a Wireless N adapter card in any available (Open)
white PCI slot, or use a Wireless N adapter that plugs into any available USB port.
1) Dell Support > Studio XPS 8100 Desktop PC > Service Manual,
http://support.dell.com/support/edocs/systems/studio8100/en/sm/index.htm
I would like you to click on - Technical Overview
Now on System Board Components
The number 23 points to the white PCI slot.
The numbers 24 and 26 point to a PCI-Express x1 slot.
You can buy a Wireless N adapter card to fit either a PCI slot, or a PCI-Express x1 slot.
{NOTE* Number 27 points to a PCI-Express x16 slot.
This = NO.
This expansion slot is used for a graphics card, ONLY }
Examples of a Wireless N adapter card for a PCI slot, and a PCI-Express x1 slot,
A) PCI: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4389486&CatId=2701
B) PCI-Express x1:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=788312&CatId=2702
C) USB:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5079829&CatId=2688
Why use anything but a USB Wireless N adapter?
I don't know. They allow me to toot the whistle, but not drive the train.
Information on PCI, and PCI-Express;
PCI:
PCI-Express:
Regards,
joecoolvette
Feb 11, 2012 | Dell Studio Xps 8100 Desktop Computer
Are pci and pci-e cards the same
No the cards are not the same. One has 62 pins on each side of the card (minus a cutout for a key with the slot) and the other has 32 pins (PCIe 16x) or fewer. They have different power requirements and won't fit directly in the other slot. There are adapters for PCI-e 1x cards to use them in a PCI slot and adapters to put a PCI card in a PCI-e 1x slot. See any of the component vendors for details.
Make sure to order a card that will fit in your computer's slots. It will save you trying to determine if the card, slot or adapter has failed.
I hope this helps.
Oct 27, 2011 | Lenovo IBM ThinkCentre A30 8199 (8199XX2)...
Dell optiplex GX620 desktop has an ethernet port on it, that is not an adapter, I cannot connect to the internet, I downloaded and installed a driver for a wireless ethernet adapter, but that has not...
Okay,..........
1) You can download a wireless Ethernet adapter driver all day, but if you Do Not have a wireless adapter card installed in your computer, the drivers do you no good.
Or if you do not have a wireless USB adapter plugged into a USB port.
Example of a wireless adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4695358&CatId=2692
Example of a wireless USB device,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6367137&CatId=2692
Example of an Ethernet adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
If you are just going to hardwire the computer, just buy an Ethernet adapter card, (PCI version), and install it in your computer, (On the motherboard), in any available white PCI slot.
IF it is the Mini Tower model.
The Desktop, Small Form Factor (SFF), and Ultra Small Form Factor (SFF) computers, are too small in width for a regular size Ethernet adapter card.
They need a Low-Profile Ethernet adapter card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833114034
This is for a Dell Optiplex GX620 Mini-Tower computer,
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtabout0.htm#wp1051997
Scroll the page down until you come to the bold blue heading - System Board Components
This is an illustration of a Top view of the Mini-Tower's motherboard.
16 and 17 point to two PCI slots.
This is where an Ethernet adapter card that is the PCI version, will plug into.
PCI slots are White in color.
An example of a basic PCI slot, ( 3 are shown),
If you do decide to go wireless;
1) Wireless networking operates at half of the speed of wired networking.
A computer that is wired directly to an Ethernet adapter card, is twice as fast on the internet, as a computer that is connected wireless.
2) Make sure your Router is capable of wireless.
Make sure the wireless router has a built-in Modem, or that you have a separate Modem.
[ For DSL.
Phone line connects to Filter. Filter has a place for a telephone cable, and an Ethernet cable.
Ethernet cable connects to Filter, and other end connects to Modem.
Ethernet cable goes from Modem to Wireless router that does not have a built-in Modem.
OR,
Phone line connects to Filter. Ethernet cable from Filter goes directly to wireless router, that has a built-in Modem.
Computer has to have a USB wireless device, or a wireless adapter card, installed.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page, blue Comment)
Regards,
joecoolvette
Sep 16, 2011 | Dell OptiPlex GX620 PC Desktop
The windows doesn't find the hardware "3com wireless PCI 3CRDAG675B" so I can't even use the driver I downloaded from 3com site for windows7 32-bit compatibility
be sure not to plug-in the pci adapter before installing the driver, here try this install first the driver of the said pci adapter then if ask to restart the computer restart it, then turn it off, now install the pci adapter then turn on the computer it will now detect the adapter then follow instruction on the screen, thanks
Aug 09, 2011 | 3Com 3CRDAG675B Wireless LAN PCI Adapter
I purchased an HP A4327C desktop computer and wanted to convert it to wireless. I purchased a Level One11g Wireless PCI card and the card will not fit into the slot inside of the computer. Is it the wrong...
HI,
On your computers motherboard, you have three slots
  • PCI slot
  • 1 PCI express slot 16
  • 2 PCI express slot 1
You would require a PCI express 1 ex wireless card for the system
Thanks
Proton
May 11, 2010 | HP (EA118AA) 802.11a/g/b Wireless Adapter
I am trying to connect to a wireless internet network
If you have Wireless networks available, and you just need a network adapter for the system, here is a good suggestion:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833130111
The adapter connects to the system via USB, and setup is pretty simple
Sep 30, 2009 | Dell OptiPlex GX260 PC Desktop
Need to know where I can get driver download.
Possible causes:
1)The Operating System on the computer might not support the Plug & Play feature or need latest system updates.
2)The USB port or PCI slot on the computer might be faulty.
3)Extension cable (if being used) that connects the USB adapter and the computer might be faulty.
4)There is no driver support for the Operating system.
Symptoms:
1)LED will not light up on the adapter.
2)Found New Hardware Wizard does not come up.
Resolutions:
1) Make sure you meet the minimum system requirements for the adapter and have the latest updates on the computer.
2)Use the latest driver for the adapter. Latest drivers link is mentioned below.
3)Try a different USB port or PCI slot on the computer.
4)Try another device and check if it gets detected.
5)Try to connect the adapter directly to the computer without using an extension cable.
6)Try restarting the computer or try adapter on a different computer.
Open the below link and try to download the latest version of the driver http://kb.netgear.com/app/answers/detail/a_id/747
May 18, 2009 | NetGear WG311T 802.11g/b (wg311tge)...
Computer does not detect new 802.11n pci wireless adapter..also used cd to put drivers on...but main problem is it seems that the computer doesnt even power on the LED light to the adapter.....HELP PLZ!!
try moving the PCI card to another PCI slot in the computer. Sometimes individual PCI slots stop working properly. If you put the card into multiple PCI slots and it never recognizes it or lights up, your card may be defective.
May 14, 2009 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
