Question about Moore Medical MooreBrand TRUEbalance Blood Glucose Monitor - Meter - Model 88480 - Each
I am getting E3 reading on my glucose meter when i insert the test strips
    Problem Solver:
  • 11 Answers
I had this trouble after 3 or four rainy days..i believe that it is moisture detected in your strips. a pinch of rice in the plastic vial will absorb the water-worked for mine.
Posted on May 16, 2013
Accu Check Active showing Trouble E-1
The electronic error code refers to either
  1. your glucose level may be extremely high or a meter or a test strip error has occurred.due to insufficient blood sample on the test strip.
  2. A used test strip was removed and reinserted.
  3. The test strip may be damaged or not properly inserted
Try turning the meter off and on or take the battery out for a few seconds and try testing glucose levels again. In any event, check your meter's manual; if unavailable- you can download an electronic version of the manual from the manufacturer's web site; or some meters you can browse the info from your meter's screen menu.
Other options, replace the battery with a new one or perhaps your meter has met its end-of-life usage.
Be well!
Feb 12, 2017 | Active Health & Beauty
Why inconsistent results
Not sure but try doing two tests using different blood samples taken at same time. Note that there is always a small difference in sample results
Jun 06, 2014 | Bayer Contour Next EZ Glucose Meter Kit...
What are the error codes for Accu-Check Glucometers
E5 codekey expired which means that the test strips or out of date and no longer any good. You get a new codekey with a new can of test strips. A pain, I know.
E1 Re Insert test strip
E2 Incorrect code key
E3 Extremely high reading
E4 Not enough blood on test strip
E6 Control Solution too soon?
E7 Electronic error
E8 Temperature too high
E9 Change Battery.
May 13, 2014 | Accu Chek ACCU-CHEK Aviva Meter
My easy touch meter is reading way to high how do I fix it?
How do you know it is reading watch too high is my first question..MAKE SURE IT IS NOT YOUR GLUCOSE THAT IS READING HIGH..the tester should have a small bottle of testing accuracy with it..there are number scales on the side of the strip container and on the test bottle use a strip and test it..if it reads on or between the numbers the strips and tester is ok..if it does not, try another from another strip from different container..if it still reads wrong..your tester is faulty..good luck..
Apr 23, 2014 | Easy Touch No Coding Glucose Monitoring...
It does not show the glucose level
Not sure, but try the help line or contact either the place you got machine from or the manufacturer
Jan 23, 2014 | Bayer Contour Next EZ Glucose Meter Kit...
Meter shows e 9 and cuts off when I INSERT A TEST STRIP
Your batteries are almost out of power, replace straight away
Jan 09, 2014 | Accu-Chek Nano Nano SmartView Blood...
ERROR
Read instruction booklet, all error codes shouild be in it somewhere, uually towards the back of each language section.
Dec 09, 2013 | Arkray USA Pocketchem Ez Blood Glucose...
User guide for optium EZ blood glucose tester
set of instructions should be in box, or read machine instructions
Oct 24, 2013 | Medline Abbott Diabetes Care Glucose...
How do i also clear off all of these dangerously high blood sugar readings from the glucocard vital blood glucose meter?
Directions should say.try taking the battery out eat more veggies and exercise I've had it 41 years. God bless
Feb 25, 2013 | Arkray GlucoCard Vital Sensor Blood...
Freestyle freedom meter reads error 4 what does it mean
goto the following to get online manual: abbottdiabetescare.co.uk
Jan 25, 2013 | Abbott Diabetes Care Freestyle Freedom...
Moore Medical MooreBrand TRUEbalance Blood Glucose Monitor - Meter - Model 88480 - Each Logo
951 people viewed this question
Top Moore Medical Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Moore Medical Health and Beauty Expert? Answer questions, earn points and help others
