Question about Nintendo Wii Console
Wii remote issues
I was away and didn't use my Wii for a while came back and had to change the batteries on the controllers, which let me enter by pressing A to start and I can use the home button but it doesn't let me do anything else i can see it on the screen HELP
  • 26 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Apr 07, 2009
Wii fix guide
Try this link it may help. If not there may be an issue with the console or controllers. Try the controllers on a different wii. Try a different controller with your wii. Wii Remote Not Working or Syncing Correctly Wii and Wii mini Nintendo...
Aug 21, 2014 | Nintendo Wii Remote Controller
Remote wii not working
First check your batteries level and if is nothing covering the sensor bar... Next press 1 and 2 button simultaneously.
If still didn't work press red connection button at back of wii remote near the batteries e press the same button on wii console.
Oct 10, 2011 | Nintendo Wii Console
I have 3 wii remotes was using one that had batteries it died so i replaced all remotes with new batteries and now none of them will sync or work they just turn off right away
After replacing the batteries, you may have to do a hard sync by pressing the sync button beside the SD slot on the Wii and the sync button on the back of the Wiimote underneath the battery cover. Both buttons are a kind of dark reddish-brown colour.
Mar 25, 2011 | Nintendo Wii Console
Bought nintendo wii last xmas and had played quite frequently. then after a break in play of a few mths the remote controls dont seem to be being picked up by the sensor. i chenged the batteries and still...
Hello there
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
Oct 01, 2010 | Nintendo Wii Console
My wii controller cannot connect. i tried cene765`s advice, but it didn`t work.
try pressing the red button that says ___ inside of the wii remote battery cover
if that doesnt work, try buying a different sensor bar, or a different wii remote
Nov 30, 2009 | Nintendo Wii Console
My ******* wii remote wont work. It's synced and everything. I can enter the wii menu, but the hands wont show up on the screen. I am 4 ft. away from the sensor. I have no other infrared things and the...
youo may have a defective Wii remote, and you should take it somewhere like GameStop and have it looked at, or you should take it back to the store and exchange it for a new one.
Nov 14, 2009 | Nintendo Wii Remote Controller
I am attempting to adjust my wii remote sensitivity. The minus button will not work. it is currently set at 5...when I press the plus button it beeps as if I am adjusting in the positive, however when I...
Here are few Home remedies that should help you fix the issue.If you still face any problems then it is an internal issue with your remote and you will have to contact the nintendo support.
  1. Clean the Wii remote pointer lens. Use a soft cloth to remove any sticky substances. Wii remote jackets, stickers or other objects should not block the remote pointer lens, as it will cause characters to move erratically, disappear or remain off-center.
  2. Operate the Wii remote between three to eight feet away from the sensor. Otherwise, it will not perform properly.
  3. Note that infra-red lights from candles, toys, appliances, fireplaces and even sunlight may effect how the Wii remote performs. Try to remove or reduce infra-red interference from these sources when possible.
  4. Turn off or move wireless devices located near the Wii console. You may be experiencing radio frequency interference from other wireless devices.
  5. Check to see if anything is blocking the sensor. Clear objects away from the sensor and console to enable the remote to send a clear signal to the Wii system.
  6. Center the sensor bar directly below or above your television. Having the sensor off-center may cause the Wii remote to perform poorly.
Re-sync the Wii remote to the Wii system:
  1. Completely turn off the Wii system. Remove the batteries from the remote. Turn the power off on the Wii console. Unplug the unit from the wall. Wait five seconds and then replug the unit into the wall.
  2. Push the power button to turn on the Wii console. After the health and safety screen appears, open the small door on the front of the Wii console. Locate the red SYNC button. Push down on the SYNC button for fifteen seconds. This resets all previous SYNCS on the Wii system.
  3. Re-sync the Wii remote. Locate the red button on the remote control under the battery cover. Push and release this red button. The Wii remote should respond with blinking blue lights.
  4. Push and release the red SYNC button on the Wii console. Place the batteries back in the remote. When the remote is successfully re-synced, the LED light will remain lit.
  5. Repeat the re-syncing process with all other Wii remotes on this system.
Thank You
Oct 19, 2009 | Nintendo Wii Console
Wii Controllers commplety shut down
Try changing batteries or pressing the sync button on both your Wii and Wii remote.
Jul 12, 2009 | Nintendo Wii Remote Controller
Wii Remotes
Could it be an issue with your sensor bar on top of the TV? That could explain why you'd be having the issue with more than one remote all of a sudden.
Jun 29, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
66 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
