Question about Boating
1976 evinrude 135hp. I need to replace the gear box with the one I have off another motor, is it a simple case of sliding the old one out and the new one in? Any help greatly appreciated.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
If your talking about the lower unit then yes, its fairly simple. You detach shift linkage and the "foot" should pull off strait down after removing the four bolts on the bottom.
Posted on Jan 12, 2013
4 Suggested Answers
  • 2692 Answers
SOURCE: gear box oil leak
Here is a website where a manual for you outboard may be purchased.  Outboard Marine went out of buisness in 2000 and thus no parts of origial manufacture are support is available . Therir are secondary markets .    THe Lower case splits in half and their is a seal around the prop shiftm which is pressed in. The seal between the cases are cut o-rings which are placed and glued into place with gasket seal.
The water pump is located where the case splits a little bit higher. You must open the little port on the side and take out one of the screws to the connecting shift linkage to split the case. After splitting the case the drive shaft and water pickup tube(s) wil come out of the powwer head or the tubs may stick into the power head which is ok. Place the lower skag into a vice and remove the 4 or 5 screws to the water pump housing. Remove and replace impellor and impellor plate if available. If part(pieces) of the rubber impellor is missing flush out the tubes and the power head to remove them.   When reinstalling the lower unit use a flash light to make sure that the tubes return  to the proper place in the power head and the shift lever is resecured. If you need more assistance, just write back. I was an Outboard motor mechanic for five years about the time of your motor.
Posted on Dec 23, 2008
  • 5546 Answers
SOURCE: Can't get lower unit off a 1976 evinrude 135hp
Several things I would look at would be the Sacrificial Anodes may hold the 2 parts together and then look at the water intake ports. There may be extra bolts behind the water inlets.
You may want to remove the engine from the housing to cut the weight when wrestling with this. You may be able to pull the driveshaft with the engine and get the linkage and water tube out of the way. Sometimes there is just a slip together joint on the driveshaft. If you cut the shaft you may have to open the gearbox to replace it. $$$$
There are some Salvagers on the Net. You will need them to replace what you break. You could contact them on the secrets to getting this apart. Hopefully you will find a hidden bolt to solve all of your problems.
Posted on May 10, 2010
  • 46318 Answers
SOURCE: i need a picture of how the sping fits in between
the small wire that might be considered a spring loop slips over the end of the needle and the other end slides uver the float arm . float level needs to be set then , with a float gauge
Posted on Oct 30, 2010
What parts are needed to make manuel start outboard to electric? Evinrude 30 hp.1986 mod#E30RCD
Evinrude MIGHT sell a conversion kit call a reputable dealer.
Jul 24, 2017 | Boating
How to remove the twist grip on 15hp evinrude outboard motor?
Fix Tiller Handle on 15hp Evinrude - YouTube
? 2:02
www.youtube.com/watch?v=dl0b7WFKsjc
Mar 30, 2011 - Uploaded by Budnipper82 Evinrude 15 HP gear removal - Duration: 9:11. by kodibass 7,404 views. 9:11. Repairing an Evinrude 9.9 ..
Nov 01, 2015 | Boating
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
Can't get 1976 evinrude 6hp to pump water I changed water pump
have you changed the impeller inside the lower unit.
There is copper pipe to redirect water up into the engine.
When you replaced the impeller make the copper pipe is insert onto the engine.
Jul 31, 2012 | Light Outboard Motor Boat Bass Fishing...
I need to change the water pump on my 1976 115hp evinrude and i cant drop the lower unit.where can i get fast and free information online to help me?
There is 2 things.The gearbox linkage has a plate on the side of the leg to undo.The other is the splines on the end of the g/box,that goes into the crankshaft,are seized.Your motor being a 76 might have seized splines.Hope it isn't,but hope this helps
Feb 20, 2011 | Boating
I need a picture of how the sping fits in between the float and needle vavle on a 1976 35hp evinrude motor.
Oct 02, 2010 | Boating
How do I drop off the lower unit on my 70 hp evinrude engine? I believe the shifter fork is worn.
below the carbs is the shift rod and take the small pin out , then remove all bolts that hold the gear case to the leg then drop the unit and place in a vice to hold by the skeg fin below the prop ! normally its the edges of the gears and the central slide clutch that wear, remove and have re cut at machine shop ! saves buyin new gear set !! check all linkages ok for wear FIRST though !!
May 15, 2010 | Light Outboard Motor Boat Bass Fishing...
May 07, 2010 | Boating
Boating Logo
60 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
