Question about Sony CDX-M630 CD Player
Head Unit problem
I have a sony xplod and the front of the unit was open when power to the unit was cut (lose wire) and it won't let me put the code in to unlock the unit with the facia open and I can't get it to go back to the closed position (operated by motors) any help would be very welcome. Thanks
  • 48 Answers
Go to Sony.com and search out the user manual. Most of these units have a reset button for just these types of issues. The reset button is usually behind a tiny hole that you need to insert a paper clip into. You can also try disconnecting tthe ground from the car battery and reconnecting it. That could cause the radio to reset.
Posted on Jun 29, 2007
My iphone asks for a four digit code to pair as a bluetooth device with my sony xplod, how do i enter the 4 digit code into my sony xplod?
You enter a code on the source device, enter the code again on the head unit (using the remote control is the easiest way to do so), and the two devices connect.
Mar 29, 2011 | Sony XPlod CD Player w/MP3 Playback...
The entire unit will not come on. I changed the battery thing that was it. It was not what could it be?
Have you checked all the connections, especially the "remote" turn on from the stereo? This wire is usually a small gauge "blue" wire coming from your head unit. When you turn on the head unit it will remotely power on the amp.
Sep 24, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
1994 ford thunderbird sony xplode installation?
power wire from batt fused to positive on amp .earth wire eg - to bare metal in car with bolt or screw. remote wire from amp to remote wire on back of head unit mostly blue wire it tells amp when to turn on then you need a set of rca cables to send sound from head unit to amp they go in subout if you wanna use sub or rear or front out for full sound best thing is to buy amp kit cheaper most the time and all you need there
Oct 18, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
No power to front panel but have power to main unit.
You Have constant power (yellow wire) but your Acc wire or switched power wire (RED WIRE) does not have power. Check the connection of this wire. You most likely have a blown fuse in your vehicles fuse panel.
May 19, 2009 | Sony Xplod CD Player w/MP3 Playback...
Wiring problem
Power wires are as follows -
Red = Switched power (ACC)
Yellow = Constant power
Black = Ground
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 19, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony Xplod 1000W workign strangely
need a bigger gauge hot wire going to your amp ,maybe a battery cap. amp isnt getting enough power to perform so it cuting out.
Mar 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony xplod amp xm-1652z high level input connection
First off, if you're using RCA preamp connections from the head unit to the amp, you don't need to put anything into the high level input connector. But if your head unit doesn't have RCA preamp outputs, then connect the front left to the white (+) and white/black stripped (-) wires and the front right to the grey (+) and grey/black stripped (-) wires. There is no need to connect the rear speaker outputs of the head unit to the high level input of the amp.
Apr 17, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
My amp works on tuner but switches off when i change it to cd
The remote turn-on wire from your amplifier is connected to a blue wire behind the head unit. That's a power antenna activation wire, so the amp only turns on when the tuner is on. Switch it to a blue/white wire from the head unit instead; that should be the amp remote turn-on output.
Jun 16, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony CDX-M630 CD Player Logo
129 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
