Question about Exercise & Fitness
Should I buy a beaded rope? - Exercise & Fitness
    New Friend:
A beaded rope is one made out of nylon with plastic beads along it. It can be used on any surface including concrete and it won't destroy the rope. I just started jump roping recently and got one of these because it doesn't get tangled. Also I can hear the beads hitting the ground which helps me keep my rhythm.
Posted on Jan 03, 2013
What are the different types of Jewellery Chains?
There are various types of jewellery chains. Here is list of jewellery chains.
  1. Anchor / Mariner or Rambo
  2. Belcher or Rolo
  3. Bead or Ball
  4. Box
  5. Curb
  6. Figaro
  7. Gucci
  8. Rope
  9. Snake
  10. Spiga / Wheat
Hope it helps.
Aug 23, 2017 | Clothing Accessories
Tip
Seal bead on flat tire to refill with air
Most lawn tractor tires are now tubeless and when they go flat the seal of the tire bead and rim are lost. It is very difficult to restore the seal in order to refill the tire and determine what caused the flat. Here is my tip to seal the bead, & fill the tire, without having to remove the wheel from the tractor. Wrap a length of heavy rope, or a fabric hold down strap centered around the outer circumference of the tire tread and secure with minimum slack. Place a bar, long box wrench etc. between the rope and tire and turn in whatever direction you choose keeping the ends of bar above the rope. As you turn the rope will begin to twist and cinch and collapse the center of the tire causing the bead to evenly seal against the rim.
Add air until you feel pressure building then back off cinch as you fill until you are sure bead will hold on its own. This works great on wheel barrow tires as well.
Good Luck
on Apr 02, 2015 | Garden
I just bought the Weider Beaded Jump Rope and it is too long for me is there a way to shorten it without ruining it?
if you're careful and crafty you can try to take the beads off the rope and use a scissor to cut the rope to your ideal height, If the jump rope isn't constructed to be disassembled or you don't wanna take the risk, try tying a knot on both end of the handles to shorten the rope. btw you probably know this already, but when trying to determine the length of a jump rope you should stand on the center of the rope and make sure each end of the handle reaches your armpit or at least your chest
Jan 16, 2013 | Weider Jump Rope, Beaded, 1 rope
I have just started making my own jewelry using beads. How do I stop the beads wearing against the thread?
If you are using beads with rough edges, it's more likely to wear the thread away. You can buy a bead reamer which is tool used to smooth down edges around the holes of the bead.
Jan 10, 2013 | Crafts & Hobbies
Are there different types of jump ropes? What is the difference between them?
There are speed ropes, cloth ropes, and beaded ropes.
speed are a cost effective and easy to adjust style of jump rope, Beaded ropes are the most durable jump rope style suitable for any environment but they are the best rope for outdoor and colder weather use. Cloth en cloth ropes are the finest quality ropes on the market.
Jan 03, 2013 | Exercise & Fitness
I want to buy some toys for my African grey and I was wondering what they like more: ropes or maybe dolls or balls?
Personally I prefer the toys that also have ropes in them. Ihave 4 African greys and they are fascinated by the ropes, pulling them andplaying with them. It keeps them occupied for hours...You can also get a toy that combines ropes and otherfeatures like beads and balls.
May 14, 2012 | Birds
Own a MTD yard machine snowblower and am having problems inflating the tires as they won't seal for me to fill them with air
i have tied a rope around the middle of tire to help push out on beads al the way around
Dec 16, 2010 | Garden
Can't get a bead on tire
Hey mate,
The problem in you are not getting enough air flow past the valve its restricting all the flow into the tyre!!!
With your valve stem, remove the valve with a valve removal tool, then you will get no restriction of air flow also use a hand air gun instead of tyre inflator this should pop the bead on then it will go down again, reinstall the valve (you can put some spit/saliva on the valve for a good seal) then use a tyre inflator and pump it up to the desired pressure...
Regards
Brad:)
Sep 22, 2009 | SK Garden
Want to replace a broken winshield on 74 volkswagom bus
there are two types of seals on these busses. if it the american type it has a bead pushed in around the outside, sometime chrome coloured. if it has, pull the bead out.
If not you have saved a step.
From the inside of the bus gently and evenly push the screen out. Have somone with a blanket to recieve the glass "be aware the old original screens are not laminated so you have green house glass coming out so yake care" once out, peal out the ols seal and put with the glass (in the bin).
Get your new seal and fit around your new glass. with the seam at the top.
now is a good time to check the bus for rust, its a common problem to have rust around the windscreen. if there is sort it befor you get leaks. and remove shorp edges to prevent damaging your new seel.
you will need some strong thin rope. about 5mm diameter is good.
with washing up liquid, put the rope around the seel where the metal on the bus will sit. tuck the rope in all the way around and cross over at the bottom of the screen.
you will need you mates again now
if you hold the screen up against the bus and rest the bottom of the seel against the bus. you now use the two ends of the rope.as you pull them the seal lip will lift over the metal of the bus. pull the rope round slowly using a rounded spoon handle to lift over any bits of seel which slip off.
you mates will be out sie persuading the windscreen in by applying even presure down and inwards. when the seel is all the way round you may need to tap the outside of the screen round the outside with your hands to settle the screen in to its new position.
job done
easy
Jul 26, 2008 | 2005 Volkswagen Microbus
Exercise & Fitness Logo
70 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
