Question about Sony Televison & Video
Sony DVD recorder RDR HXD870 sticks in Update mode
Recorder often does not switch off after the regular UPDATE sessions
The updates in my sony HXD870 will not turn off?
Posted on Jul 21, 2013
SOURCE: sony rdr-hxd870 - how to record onto hard drive?
JUst press Record either on the remote control or on the main unit!
Seriously, how retarded can you get!!
Posted on Aug 31, 2008
  • 6 Answers
SOURCE: Can't record onto disc
press dub on your remote, it will open the menu choose your programme you want record then click on hdd to disc.
Posted on Mar 31, 2008
IrishDruid
  • 2712 Answers
SOURCE: sony dvd recorder rdr-gxd310
To add to Benmiur's solution, there are actually a few more steps involved with the OFA (One-For-All)..
Get a One-For-All universal remote that has a DVD key and a
"magic" key, such as the One-For-All-4.
* Select DVD device on OneForAll remote (OFA)
* Hold magic key until double flash on DVD key
* Enter device code 0533
The RDR-GXD500 DVD recorder must be set to command mode
"DVD1", and its own remote set to the same mode like this:
* Switch on recorder and point its own remote at it
* System-Menu -> Setup -> Options -> Command-Mode
* Select DVD1
* Set remote's Command-Mode switch to DVD-1
(it's under the sliding cover)
* Verify that recorder can be switched on and off with
both remotes
Now program function code 189 into button 1 of the OFA
remote like this:
1. Hold magic button until double flash on DVD key
2. Press 994
3. Press magic button (don't hold)
4. Press 189
For some remotes, all of the buttons you need to reprogram need to be prefixed by 00. So 1 would be '00189'
5. Press 1 - double flash indicates success
Advanced OFA remotes such as the Kameleon have five digit
function codes, in which case, press 00189 for step 4 above.
Now program function codes into buttons 2-5 like this:
* Repeat steps 1-3, then 255 2
* Repeat steps 1-3, then 095 3
* Repeat steps 1-3, then 221 4
* Repeat steps 1-3, then 079 5
Now the actual conversion of the RDR-GXD310 DVD recorder to
region-free:
* Put DVD recorder on standby and point OFA remote at it.
* Press 12345 - "TIMER OK" is displayed, and recorder
starts up
* Press 12345 - Recorder goes back to standby
The RDR-GX310 DVD recorder is now multi-region.
Posted on May 24, 2008
sandipmistry
  • 56 Answers
SOURCE: Region Unlock For Sony RDR GX-120 DVD Recorder
GO BACK TO THE PERSON WHO HAS REPAIRED ASK FOR FREE REPAIR AGAIN. IF HE NOT RESPONDING, TELL ME LATER I'LL HELP.
THAT TIME PLEASE MENTION FULL MODEL NO. FOR YOUR SET AND WHICH COUNTRY YOU LIVE?
Posted on Apr 23, 2009
  • 27 Answers
SOURCE: HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
azsnoopy1@cox.net
Posted on Dec 28, 2009
RDR-HXD870 manual
You can download and print the instruction manual for RDR-HXD870 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Jan 02, 2011 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
TV code number
0056 is the code for the LG TV.
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
IrishDruid
May 13, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Sony Remote - Acer LCD TV
hmmm..well..that would be on the acer website, methinks..
check this link and find the acer icon..you may find it in there, under the LCD information(by model)
Mar 25, 2008 | Televison & Video
I lost DVD Sony RDR-HXD 870 insructions. Could you possibly send it to me electronically?
Hi here is a link to Sony manuals downloads
http://support.sony-europe.com/manuals/index.aspx?site=odw_en_GB#m=RDR-HX870
It seems to be only available in Slovenian (probably only produced for that region?)
On right side of page select from drop down box 'home video', second drop down select 'dvd recorder' then in third drop down you should see your model number RDR-HX870 (without D). Download is 3.16mb.
Hope that helps and you can read Slovenian?
Apr 23, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Sony rdr-hxd870 - how to record onto hard drive?
Jul 22, 2008 | Televison & Video
Mar 02, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Graham Keenan
I presume that your TV uses Scart to connect to other devices and on your TV remote there will be a button that has either of these things next to it: 1.A box with an arrow pointing into it. 2.A button that says input. 3.A button that says AV. Turn on your DVD recorder and then push the button that i explained until you find the DVD recorder is coming up on your screen
Dec 11, 2007 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Televison & Video Logo
440 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
