Question about Zanussi WDA1055W Front Load Washer / Dryer
My washing machine will not spin( zanussi wda1055w)
  • Anonymous Apr 06, 2009
    My washing machine will not spin, there is just a slight buzzing sound and no movement
  • Zanussi Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinemy washing machine will not - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 25, 2010
Where would I find a replacement detergent drawer for a Zanussi 1055W washer/dryer?
http://www.ebay.co.uk/itm/Zanussi-Washing-Machine-Washer-Dryer-WDA1055W-Soap-Tablet-Detergent-Drawer/162547763876?hash=item25d89a0aa4:g:fsAAAOSwuxFYzP3t
Nov 06, 2017 | Zanussi WDA1055W Front Load Washer / Dryer
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
I have a problem with the performance of the dryer on my Zanussi WD1272. the clothes get hot but at the end of the cycle are still wet. No problems with washing. Please help
Could be condenser or water solonoid valve fact that s hot says heater ok.fact that its wet perhaps not cooling down to water and pumping out fully, also check that the filter is clean....
Nov 26, 2010 | Zanussi WDA1055W Front Load Washer / Dryer
I have a zanussi washer dryer ZWD 14270w and the dryer is taking hours and hours to dry anything..help!
Not sure how full the drum is when you are using the dryer, but I have this appliance and it works best if the drum is half full. If the drum is full, things don't dry properly because the air can't circulate.
If that doesn't work I'm out of ideas!
Oct 24, 2010 | Zanussi WDA1055W Front Load Washer / Dryer
Zanussi washing machine, conditioner doesn't empty
Washing Machine2_bing.gif does not Pump or Spin
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
May 14, 2009 | Zanussi ZWF1430W Front Load Washer
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Jan 21, 2009 | Zanussi WDA1055W Front Load Washer / Dryer
Washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WDA1055W Front Load Washer / Dryer Logo
160 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
