Question about Canon PIXMA MP470 All-in-One Printer
Error 5100 on PIXMA MP470
Irish Druid (staff) said this is obstruction. My printer is brand new. Error showed first time I switched on. Irish Druid gave routine for testing; he/she stated "press resume button" - which is that?
  • shorts11 Jan 23, 2009
    where is the resume button on the mp470??
    President:
  • 8,637 Answers
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Canon pixma mp470service error 5100
Hi ahareas,
This error 5100 that you are getting could be as simple as a loose cartridge. Take the cartridges out and put them back in making sure they snap in. There's also a possibility that there's something inside that is obstructing your print cartridge. To take a look on this, took the back off with three screws, then the side panel. You have to take the trim off, there's one screw. Look for the little arrows that show where the tabs are that slide into the side of the printer itself. Use a screwdriver to unsnap them. Tip your printer side ways and check if there's any obstruction in there. Remove it and put your printer back together.
Hope it helps.
Thank you for using FixYa.
May 04, 2011 | Canon PIXMA MP470 All-in-One Printer
Error code5100
HI:
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or in my case popcorn. There was even some paper caught underneath the rollers that I had to jiggle around to even see. Check VERY thoroughly.
Apr 20, 2011 | Canon PIXMA MP470 All-in-One Printer
Showing error code 5100
torn paper in rollers etc
Also make sure all ink cartridges are seated correctly
Please rate my help++++Thanks for using FIXYA
Nov 27, 2009 | Canon PIXMA MP470 All-in-One Printer
Error 5100
- Carriage unit
- Timing **** strip film
- Logic board ***'y
- Carriage motor problem
Sep 13, 2009 | Canon PIXMA MP470 All-in-One Printer
Error 5100 canon mp470 my screen is showing error code 5100. i cant find the manual to my machine can you help? what exactly does the error mean?
Hi You can Try
Error Code 5100 Seen this many times
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Mar 24, 2009 | Canon PIXMA MP470 All-in-One Printer
I get error code 5100 on my canon mp470 printer?
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Mar 17, 2009 | Canon PIXMA MP470 All-in-One Printer
Printer error on a canon mp 470
How I can fix the U051 problem with my conno : MP470 printer ? It says the print head is not installed. Install the print head. Where is the it , and how I can fix it?
please e-mail to atvandparts@gmail.com
Jul 26, 2008 | Canon PIXMA MP470 All-in-One Printer
Download
No drivers are available for the printer for Windows ME. It may be time to upgrade your computer if you want to make use of newer printers and hardware.
Mar 30, 2008 | Canon PIXMA MP470 All-in-One Printer
Need a help for Canon PIXMA® MP470 Printer
My printer wont print. It flashes Error 5100 and the orange light flashes twice. There are no answers in the book.
Feb 19, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
Canon PIXMA MP470 All-in-One Printer Logo
59 people viewed this question
old marine
old marine
