Question about Refrigerators
How to remove ice maker unit of Mitsubishi fridge freezer
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
  • 3 Answers
SOURCE: Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
Posted on Jan 14, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Posted on Apr 28, 2009
projdoc
  • 2236 Answers
SOURCE: 2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Posted on Aug 28, 2009
SOURCE: sub zero fridge model 561 not making ice
Thanks to everyone for the help.We did get it moving and working finally. My husband took the ice drawer out. Reached up to where the ice drops out and poked around a bit. He said he didn't move anything but I heard a piece of ice move. We then shut the power off at the breaker switch, waited 10 seconds or so then turned back on. An hour or so later, we heard ice drop and it's still making ice. What a relief. I
could tell there had been a power failure as the clocks all needed resetting. So as someone suggested, we just had to reboot the thing.
We tried everything after reading 50 plus pages of questions and answers and finally got it. Thanks so much!
Posted on Jan 08, 2010
I get an Error code Er if on my LG refrigerator, what can I do?
Hello Janet;
My name is Peter. I am a retired field service refrigeration technician.
Based on your problem I do not need your model number. This is a high maintenance unit. You have a bottom freezer with the ice maker and bucket on the fresh food section door.
The error code IF is the ice maker fan. You have two fans, one for the freezer and one for the ice maker.
First, ice makers and ice buckets belong in the freezer section. When they are on the door they are exposed to the warm room air temperature and condensate forms freezing the ice cubs together. Then you open and close the fresh food section door you force warm air down the air vents to your ice maker fan and your ice maker fan freezes up and burns out trying to start.
Part #: 5209JA1044A Cost: $75.00
You can purchase it over the internet for a lot less.
Base on what you described, I suspect your ice maker fan over loaded your control board and damaged it.
Part #: EBR41956418 Cost: $125.00 You can get this over the internet for about $80.00 or less.
Now, how do you want to do this?
1.) You can pay for a $400.00-$450.00 service call?
2.) Or do it dirty. Kill the power to the ice maker fan and purchase ice cube trays and put them in your freezer.
a.) Purchase a new control board.
b.) Take the bottom kick plate off the front of the unit. You will need to pull the bottom freezer door out to do this. There are two fillips head screws holding this on. Remove the screws and the kicker plate, also called the toe plate.
c.) In the front there are 2 leveling screws. One on each side. These are hard to raise, you do not have much to grab on. I use channel locks. Turn counter clockwise to raise and clear the floor.
d.) Pull your unit out so you can get behind it.
e.) Behind the unit unplug the unit.
f.) On the left side there is a metal cover plate over your main control board.
g.) GROUND YOURSELF BY TOUCHING SOMETHING THAT IS BARE METAL. STATIC ELECTRICITY WILL KNOCK OUT YOU NEW CONTROL BOARD.
h.) Remove the metal cover - unscrew.
I.) There are several white pins holding the board on. There is a small leg on each pin that must be pressed in to release the board.
j.) Systematically go around the control board disconnecting one connector at a time and connecting to the new board. Each connector has a tab to squeeze to release.
k.) Push the board back onto the white retaining pins.
l.) Now we are going to disconnect the freezer fan. On the control board each connector is marked with a number below it. Look for, "CON 7". You are going to cut the two wires to disconnect power to your ice maker fan.
j.) On the Con 7, on the left cut the yellow wire with the black stripe and the solid blue wire. CUT THESE WIRES ABOUT 2" AWAY FROM THE CONNECTOR IN THE EVENT YOU WISH TO REPLACE THE ICE MAKER FAN IN THE FUTURE.
I would have thought with all of the recalls under warrantee that LG has had on this model that they would have stopped manufacture.
Where in the mountains is your unit?
May 05, 2015 | LG Refrigerators
How do I find out the model number of my Kenmore elite Fridge
Since the freezer is icing up there could be many different problems a blockage or a problem with the defrost or timer of the unit if u greeting unit number is should be on inside of the door or back by the condenser best bet from what I see is get a tech to fix it they will find all those numbers that u need
Dec 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
FRIDGE TO WARM MODEL ED22DWXTNOO
It's a circulation problem so either the fan in the back of the freezer(circulates freezer and blows cold into fridge) or the defrost element. If the element is faulty the rear ices up and air won't flow. If fan is faulty it's not blowing the cold air. Remove rear panel if no ice it's the fan if its full of ice it needs the defrost element(usually get termination sensor also depending on type) If you open the freezer door and hold in the doorswitch you should hear the fan running if its working.
Jul 08, 2013 | Kenmore Ice Maker Kit For Sears Whirlpool...
My GE Profile Artica ice maker is making ice, but when I open my freezer, there are icicles from the ice compartment one the food below the ice maker and dripping down the inside of the freezer. The ice...
Hi!!
The Ice Maker and the Freezer/Fridge part of the unit work separate, that's why you get the ice made but the freezer can't keep it frozen.
Most likely the condenser, located in the back of the freezer is all frozen and covered with ice pluggin up the air ducts to the fridge, preventing it from cooling.
One quick solution will be unplugging the refrigerator and allowing it to defrost on it’s own or remove the freezer's back panel and using a heat gun or hair dryer to melt the ice, this will take about 20 to 30 min..
There are various reasons this type of problem:
The temp. controls are not set properly. Set controls according to manufacturer recomendation.
The small fan in the freezer is not working,
The defros timer is not working or,
The defrost heater coil is busted.
Once the ice is melted, plug unit back in and check for unit reactions. You should be able to hear the freezer fan working. Also, you'll hear about 4 to 6 times a day the defrost heater melting the ice in the back of the freezer, if NOT, check heater coil for continuity.
Don't forget to rate this post. Good Luck.
Jun 07, 2010 | GE Profile Arctica Stainless Steel Top...
Ice maker not working in sub zero 561 model
you need to make sure that the unit has the water supply turned on. if you have a water dispensor on the front door and you are getting water then the water supply is on.
This ice maker is located in tight spot and has to be removed to cycle it manualy. so im going to give you a different way of doing a test.
first i want you to try to put your finger in the ice maker to see if you have any water or ice in it.
If it is empty then follow this step : try to get water in it without removing the ice maker. Do not fill it to the rim, just about halfway. This wont be easy, but if you do that you can check it the next day and see if it droped ice. if it did then your water valve is bad.
If it has ice in it then the ice maker in mostlikey bad.
or the switch for on and off is bad. (not common)
The freezer has to be under 14 F for most ice makers to operate.
Jan 07, 2010 | Sub-Zero 561 / F
Neff K3990 American style fridge ice maker is not producing ice
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 04, 2010 | Refrigerators
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Replacing Defrost Heater and Bracket in Freezer Section of Fridge
I ended up having to remove things in this order: all shelves, ice maker insert, ice maker top ice tray, ice maker lower motor housing, shelving support rails (2), rear evaporator coil cover. This exposed the evaporator coils (which were already dry since the fridge had been off for two days) and most importantly, the defrost heater element below the coils. The heater element was easily unplugged from it's two connectors. I tested the unit with an ohm meter and it indicated it was open (infinity resistance). I then knew it was bad. I replaced it with a new unit and put everything back together in reverse order taking care to use the same screws. The fridge appears to be back in working order.
Oct 18, 2009 | GE Refrigerators
SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
