Question about Power Acoustik GOTHIC OV2-1600 Car Audio Amplifier
Hot Amp!!! I recently upgraded to the Power Acoustik OV2-1600 amp. I have 2 5x7s and 2 1" tweeters that are running off of it. The speakers are wired into the factory wires and then I jumped off of the factory wires in the back to the amp inorder to get them to come on. So I only have one positive and one negative wire for all four speakers that are bridged on the amp. Could this be whats causing it to get so hot? Or could it be that the ground wire isnt large enough. My entire set up goes something like this...battery to cap, pos from cap to nonfused power block, from block to 2 amps(the first one I named and a 3000 watt mono), the negative goes from cap to chassis, then out of the second terminal the ground runs into a distribution block and then into both grounds of the amps. In otherwords the amps arent grounded to the chassis, they are grounded through the amp. The mono amp isnt getting hot right now, but I dont have my subs hooked up to it either. Please help!
  • 2 more comments
  • Chris Plummer Jun 27, 2007
    The one set of wires comes into play like this: speakers and tweeters are all wired into the existing factory door wires. In the back in the trunk where the factory wires used to run into the factory amps, I only found 2 wires that allowed the front speakers to come back on. So what I did was splice speaker wire on to each of them and run them to the amp...walla speakers came on, didnt think it was a problem until now. Also, the tweeters say they have built in crossovers, so do I still need them for the rewiring job?
    Its a 2004 Mustang Mach 1 and came with the Mach 460 stereo system. Have since replaced the factory head unit with a Kenwood flip screen receiver...if I remember correctly the factory wires Im jumping off of right now in the back are green and purple, if that helps any. But all the wires in my doors are different colors...I dont know what they were thinking on the wiring job but its complex as hell.
    Ok....Ive taken everyones advice, you both and all the Monday morning quarterbacks at work. Ive ran 2 new speaker wires from each 5x7 to the amp on seperate channels and have tied in the tweeters with new wire(nothing factory)into the wires running to the amp. Everything came on but my L and R were reversed so Ive switched them and hopefully that put the world back upright. So in short the wiring goes something like this: from 2 channels, one to the left and one to the right, at the splice I have the 5x7 and the tweeter wired in...same on both sides. Oh and before you ask, I routed the speaker wires down the opposite side of the power wire to avoid distortion...knew that one ahead of time. Hopefully this solves my delema, thanks for all your great advice. Only thing I havent done yet is ground both amps to the chassis, they are still currently grounded through the cap(yeah I meant cap last time). Does this matter or would it be better if I grounded them to the chassis?
  • Chris Plummer Jul 02, 2007
    Well guys I rewired the speakers as you suggested and described how above. But the amp still seems to be getting hot, not as hot as it was but too hot for my taste. From reading the manual theres no internal fan. So hopefully to fix the problem, I have ordered 2 small fans that will hopefully cool it down while its running. Any more suggestions?
    President:
  • 3,130 Answers
Not really complex my friend. You cannot use the factory wiring in most vehicles as they use the ground as a common between the two rear speakers. Run two separate pairs of wires from the amp to the speakers and this should take care of the problem your having. Good Luck
Posted on Jun 27, 2007
  • 1 more comment
  • Larry  Dillon
    Larry Dillon Jun 27, 2007
    Oh this goes for the front speakers too! And you must also disconnect the original wiring. Now if your running all four speakers on one amp? This could also be a problem, unless the amp has four separate outputs for each speaker. You also may be overloading the impedance of the amp by hooking the front wires with the rear wires.
  • Larry  Dillon
    Larry Dillon Jun 29, 2007
    You can simply add a wire lug to the ground wire and where you bolt the amp to the car, ground the wire there.
  • Larry  Dillon
    Larry Dillon Jul 01, 2007
    Did it fix it ?
  • 156 Answers
I'm having trouble visualizing exactly how you have it set up. You said that the amps are "grounded through the amp" but I think you meant they're grounded through the cap. I don't think that's the cause of your problem, but the cap and amplifiers really should be grounded separately. There's no reason to run the grounds to the cap instead of directly to the chassis. It seems more likely to me that the problem is related to your speaker wiring. I'm not clear on how your speakers are wired either; I can see that you've kept the speakers on factory wiring, and connected the amp to the factory wires. But I don't understand how that translates to having only one set of wires for both speaker sets. We'll leave the tweeters out of it; if they're wired through a crossover, then they don't have a serious effect on the impedance. However, any way you look at it, you've got two 4-ohm speakers wired together to a bridged amplifier. Most 2-channel amps aren't designed to be connected to load impedance under 4 ohms when they're in bridged mode. If your speakers are wired in parallel, then the load impedance at the amp is 2 ohms. Having too low a load impedance is the most common cause of amplifier overheating. My advice is to re-wire the speakers so that one 5x7 and one tweeter (together with a crossover) is connected to each amplifier channel. Don't run the amp in bridged mode. Even in this configuration, I'd be amazed if your 5x7" speakers are really rated to handle 310 watts RMS, which is the per-channel power rating of your amp in 2-channel, 4-ohm mode. It sounds to me like you've got too big of an amp for the job.
Posted on Jun 26, 2007
  • 3 more comments
  • Brian Neathery
    Brian Neathery Jun 27, 2007
    If the tweeters have built-in crossovers, then they're fine; you don't need to add anything external.
    If the original factory wiring goes to left and right speakers, then there has to be separate (+) and (-) wires for each side. Each side's tweeter and woofer may be combined into one set of wires, but there's no way they'd have left and right running off the same amp channel.
    What kind of vehicle is this?
  • Brian Neathery
    Ah, the Mustang Mach. Basically the door 6x8" speakers are "bass" speakers in that system, and they were run by a different amplifier than the tweeters. The factory amplifier ran the 6x8" as a mono system, so that's why there's only one set of wires for both speakers. However, if you want to run the speakers full-range and have separate right and left channels, then you'll need to wire them differently. It might very difficult to run new wiring into the doors, but you should be able to catch the wires in the kick panels and run new wires to the amplifier from each speaker. Alternately, you should be able to find the factory tweeter wiring behind the deck. You might find it easier to tap into those wires in the doors than the bass speaker wires.
    I still think your overheating problem is being caused by having both speakers wired in parallel to the bridged amplifier, so re-wiring the speakers in stereo mode should fix it.
  • Brian Neathery
    Should have guessed the car by your screen name. :)
  • Brian Neathery
    It probably won't make a whole lot of difference, but generally the shortest ground path to the chassis is preferable. There's no reason to go through the cap, and the extra connections at the capacitor can only add resistance. So it's not urgent, but I'd re-wire the grounds separately from the cap.
  • Brian Neathery
    Brian Neathery Jul 02, 2007
    The only option I can suggest, other than making sure it's mounted in a spot with plenty of ventilation, is that if there are cooling "fins" or ridges on the amp it should be placed so they run vertically.
    The fact is that getting hot is just something that all amps do. Amps like yours are generally considered to be about 50-60% efficient. That means that of all the power it draws from the battery/charging system, only about 60% of it turns into power going to your speakers; the rest becomes heat. If it's not shutting down, and you don't smell anything burning, then chances are you don't have to worry about it much.
SOURCE:
Speaker wire leads
i simply used my brain and hooked the copper wire to positive(red), and the silver wire to negative(black), being that the colors are similar. works fine.
Dec 13, 2009 | Power Acoustik NB-2 Car Tweeter
No sound out of tweeters, highs out of woofers?
it does sound like you shorted out your crossover which can be fixed if you know what you are doing, but in the long run i would try to get another one i know that raidoshack sells some small ones and is also cheap, if your positive that you didnt short out the crossover se if it needs power, see if you can cross your woffers and tweeters on the crossover, if not is there any settings that u can change on the crossover? hope i helped :)
Apr 28, 2009 | Jl Audio VR650-CSi Car Component System
Will a sony 1000 watt amp model # xm-1652z run 2 dvc 800 watt rms subs?if so,whats the best way to wire them to this amp?thx
personally i wouldnt use a sony amp for powering anything but,however if your going run it what i would recommend is if the speakers are at 4 ohms then run in series per speaker then put the speakers in series as well so you will keep your 4 ohms then run the amp in mono,however just to let you know that amp will not push fubars enough to really make them thump my advice is to goto http://www.sonicelectronix.com  if you have 200 dollars you can get a nice  Hifonics TXi 1508D that will push those monsters quite well thats 1 ohm stable and will barley get warm even after hours of thumpage,also if your running subs monoblocks are the way to go hope this helps you out.
Feb 21, 2009 | Power Acoustik Power-Acoustik FUBAR-12W...
Speakers are thumping and cracking when powered up...why?
you are better off setting your deck speakers amp to a high pass filter setting on the amp. Adjust gains to increase desired bass and clarity. Turn off loud button if you have one, that will distort your deck speakers.
Feb 13, 2009 | Power Acoustik PTID-8960 Car Video Player
Eon 15-g2 upper part of my jbl is getting hot
The tweeter is not the problem. The Eons use the vents below the tweeter to cool the amp and woofer. Sounds to me like you have a power supply problem in the amp, possibly a bad capacitor or diode. You have to check the amp for proper operation.
Feb 10, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Metrik mac-505
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
May 08, 2008 | Power Acoustik LT-980/2 Car Audio...
Amp getting really hot
well it is getting hot due to the amp drawing and pushing alot of current. try getting lower gage wiring for power to the amp and lower gage speaker wire.
Apr 20, 2008 | Power Acoustik PS2-1200 Car Audio...
Disconnect the speaker wires and the RCA jacks from the amp.
If it still gets hot, the amp needs to be repaired.
If it doesn't get hot, check the impedance of the speakers and make sure they're wired properly.
If they are wired for the proper impedance, check each voice coil with an ohm meter to make sure none of the voice coils are shorted.
Apr 11, 2008 | Power Acoustik PS2-1600 Car Audio...
Hooking up speakers to amp
YES ! This is usually ok, the speaker cabinet should contain a high pass filter or crossover on the tweeter to decouple it from the low frequency signals. My Linn Index speakers are wired like this.
Sep 07, 2007 | Audio Players & Recorders
Won't turn on
Make sure you check to see that the power wire going to the amp dosent have a bad connector on it or the wires is a dedicated for the amp. At the power wire measure for 12.5 to 13volts at the amp while the cars running and then if alls ok there remove the speaker wires and the input wires WHILE THE AMP IS OFF. then turn back on the amp is the light brighter??? if not again turn off the amp and measure the currant draw at the amp without and speakers or input. If its over a few amps the amp needs serviceing. If not then check and make sure all your speakers are good and that ones not shorted as well. Dont forget to check the crossovers too>> You didnt say if they were passive or active types
Mar 21, 2006 | Power Acoustik PS2-820 Car Audio Amplifier
Power Acoustik GOTHIC OV2-1600 Car Audio Amplifier Logo
80 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
