Question about Panasonic Viera TH-42PZ80U Plasma TV
Acoustic solutions lcd32761hdf screw hole size for wall mount
eagle338
  • 4889 Answers
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Posted on Mar 01, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
  • 298 Answers
SOURCE: Im looking to mount my TV to my wall and wanted to
This will depend on what type of wall you are fixing it to. It's a pretty big TV so for a solid timber brick or cement block wall I would suggest M5 or M6 x 50mm
If it's a hollow stud-work wall you will need to use specialist hollow wall fixings such as toggle bolts. again M5 or M6 thickness would be appropriate but you would be well advised to try to screw into the actual stud-work rather than just rely on plasterboard to support such a weight. You can buy an electronic stud detecting tool from DIY stores relatively cheaply.
Posted on Feb 25, 2011
budmrtn
  • 11361 Answers
SOURCE: I need the screw size to be able to wall mount
Metric M5 or M6, you can get them from HD, or Lowe's for about 25 cents each. The length will depend on the thickness of the bracket and the depth of the screw's holes.
When you buy the mounting bracket, it should come with a bag of Metric screws for you to use for mounting.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 14, 2011
  • 25 Answers
SOURCE: how do i mount my panasonic tx-l26x10b on the wall. no fixing holes
drill holes put in wall plugs fix bracket insert and tighten screws
Posted on Aug 07, 2012
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
Moen 3836...lost installation manual...what size drill bit for the hand held brkt.
There is no single answer that I can give you because it will vary due to material you are mounting to. If you are going to be mounting on ceramic tile or fiberglass shower wall I would recommend you use the plastic anchors that come with the bracket and mounting screws. Use drill size 3/16 drill holes and insert anchors. Mount bracket and screw in place. If you have hollow wall with nothing but sheetrock to hold the bracket I would get small butterfly anchors from hardware store and drill hole slightly larger than the wings on fastener when they are folded back along side the screws.If you have a wood backer board behind shower wall then drill holes with 1/8 inch bit and use screws long enough to reach through shower wall and sheet rock and mount bracket. Hope this helps you. Thanks P.S. If you have to drill thru ceramic tile you will need a carbide tipped bit.
Nov 26, 2010 | Moen Plumbing
I have a Samsung B2330HD TV with universal wall mount. The screws with the wall mount do not match the hole size on the tv. It seems as though this is a common problem. Any idea what the screw size I...
I'm told you have to force the M4 screws to fit. This is a computer monitor with a TV Tuner not a TV with a computer input. It was not designed for wall mounting.
Nov 04, 2010 | Samsung Televison & Video
I need to know the size of screws i neddto wall mount my tv
First you need a tv wall bracket made for that tv's weight and size to have a safe tv on your wall. The tv must be secured properly or it might fall. So the screws would come with this mounting kit and if they didn't I would fined out were they are. You must mount to a strong structure, like a stud in the wall or a metal frame built for it. The screws that I would use if might mounting kit did not have them would be as big as they would fit in the mounting bracket holes and that all the mounting holes wear being used and long enough to not be pulled out and in the stud about 3/4 of the way through the stud. They would be a good metal screw with a washer and the right threads for what ever material you are mounting it to. Thanks
Oct 05, 2010 | Televison & Video
How do i access hdmi 2 on my lcd32761hdf tv. i have cable (virgin) in hdmi1, dvd in ext 1 & the wii in ext 2. i now have a ps3 i would like to set up.
You can't access it simply because it doesn't exist - your tv has only one HDMI jack.
Your only option is to use a HDMI switch, one like
http://www.amazon.com/HM-501-5-PORT-HDMI-control-cable/dp/B000FHQMFK
Jun 05, 2010 | Acoustic Solutions M 100 Main / Stereo...
Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Apr 10, 2009 | Insignia IS-LCDTV32 32 in. Television
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
How to Install Towel Bar?
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
Aug 27, 2008 | Grohe 40.344.000 Essentials Bathroom...
Panasonic Viera TH-42PZ80U Plasma TV Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
