Question about Seagate EXPANSION EXTERNAL DESKTOP DRIVE 3TB USB 3.0 STBV3000300
Seagate stbv3000300 srd00f2 wont work on tv
I connect the drive to the usb port on my tv but the tv tells me that there is a problem with the drive. files are working on laptop
    New Friend:
You shud check the specs of ur tv. Most of dem don't support mass storage devices. To run hardisk u need to buy a media players which supports storage device upto 1 tb.
If u want to run it so badly reformat the hardrive to FAT format from NTFC.
Dis shud solve ur problem
Posted on Jan 21, 2013
2 Suggested Answers
  • 16 Answers
SOURCE: I recently added a Seagate
Hi!
I think I would run the setup application and see if it helps. You're relying on the Windows drivers for the drive and who knows how well they work.
1. Turn the computer off completely.
2. Disconnect the USB drive and any other USB devices (for the time being).
3. Turn the computer back on, put the installation disk in and follow the instructions. Don't connect the USB drive until you are asked! Having it connected before asked may not allow the installation process to work as it should.
4. When everything is installed, hook your other USB devices back up and see what happens.
If this doesn't work, go to the Seagate site and try out their external HD troubleshooter.
Hope that helps! Remember to rate the solutions!
Posted on Aug 10, 2009
Windows has stopped this device because it has reported problems. Code 43 This message pops up in when i plug in my SeaGate Free Agent GoFlex hard disk.
Try this as a possible fix.
This trick can quickly fix many mysterious hardware failures
The other thing I've heard of happening is a few of the USB 3.0 ports having problems with USB 2.0 equipment. I know it should be back compatible, but Windows can have problems. Try another USB port to see if that helps.
Does the SeaGate cable have 1 or 2 connections to the computer? Unfortunately, most external hard drives need to connect to 2 USB ports to get enough power.
I just looked up this problem on Seagate's website, and they pretty much come up with the same answers. Uninstall and re-install the USB drivers with the SeaGate connected. Or use other USB ports. The other suggestions they have don't make sense, if you can't talk to the thing, how do you run Seatools or checkdisk?
Fixya doesn't allow me to put in another link at this point, so you'll have to copy and drop this into your address bar.
http://knowledge.seagate.com/ka030000000tmkPAAQ
Here's another write-up on fixing the code 43, I wouldn't do number 6.Update BIOS though, USB is working fine with everything else, it's NOT the BIOS that's having a problem.
http://pcsupport.about.com/od/errorc/a/code-43-error.htm
Jul 26, 2016 | Seagate 500GB FreeAgent GoFlex Hard Drive
Does the Seagate SRD00F2 have a power light?
http://www.seagate.com/files/staticfiles/support/seagate_external/Seagate_External_Desktop_Drv_QSG.pdf
Jun 19, 2014 | Seagate 3TB Expansion External Desktop USB...
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
Segate SRD00F2
Usually indicates the HDD has died
Nov 27, 2013 | Seagate 3TB Expansion External Desktop USB...
I HAVE LOST MY POWER ADAPTER FOR SEAGATE HARD DIK 3TB MODELLED SRD0072, I HAVE MY WESTERN DIGITAL POWER ADAPTER, CAN I USE IT WITH SEAGATE......
If the wattage is the same as the WD charger, and it fits then yes you can. You can order a replacement from Seagate directly @
(1.800.732.4283)
1.405.324.4700
8am - 6pm CT
Monday - Friday
Oct 20, 2013 | Seagate EXPANSION EXTERNAL DESKTOP DRIVE...
As a beginner, i would like to connect seagate external drive to tv and use as a recorder
You can't connect a hard drive to a tv and record to it even if you have a usb port on the tv. The tv will read from the usb port pictures and music but it will not record to it. The tv does not have any software built into it that will let you use the usb port as a personal video recorder. It won't work.
Jul 16, 2011 | Televison & Video
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate EXPANSION EXTERNAL DESKTOP DRIVE 3TB USB 3.0 STBV3000300 Logo
660 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
