Question about Water Heaters
How do i turn up the water heater to get the water hotter
  • Water Heaters Master
  • 5,089 Answers
1) Copy following link for tank-type water heater.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Add comment and say which type heater you have
Posted on Jan 03, 2013
I have a Rheem 81SV-40D water heater, water is hotter in the morning and only warm at night. I don't see a time or anything. Can you please help me to figure out what's wrong? thanks
Dear Chu,
I think I am hearing you say the water is hotter if the water heater has sat all night without the usage of any hot water, and otherwise, it is not hot.
I should suspect one of your heating elements is not good any more.
Look and see if there are 2 removable covers on the side of the water heater, an upper and a lower.
Take a test instrument and, with the water heater unhooked from the power source, see if you have one element that shows no continuity with an ohm meter /resistance test.
That element can be replaced, sometimes you must drain the water heater water to do so.
God bless your efforts.
Feb 17, 2017 | Rheem Water Heaters
Heat will not shut down, continues to get hotter
there might be a broken hot water pipe somewhere and so that might be causing the heater to stay on as its not getting to temperature.
Sep 26, 2016 | Water Water Heaters
Patricia bailey the product I asked question about is a inter therm 40 gal hot water heater model HSE-40F-240S
call a plumber to have the valve replaced is all you can do dear!!!!! to make hotter water you need to turn the thermostats up they are behind metal plates where the elements are .doing so will cost more money on electric bill
Feb 17, 2015 | Water Water Heaters
How do I just the water heater to make the water hotter
To make the water hotter, u may constrict the water flow that goes through the tap, shower etc. With the water flows slowly, the heater has more time to heat the water in it and then the water will be hotter although it won't be boiling hot(100 degrees Celcius) because the water heater is not designated to heat water up to that temperature
Apr 09, 2013 | Water Heaters
PRESUER VALVE KEEP LIFTING WHENWATER HEATER IS RUNNING
If water is exceptionally hot, the TP will release water.
Is water hotter than normal?
Or TP will release water when TP has gone bad.
Replace TP and see what happens.
http://waterheatertimer.org/How-to-replace-TP-valve.html
Sep 17, 2012 | RTO Atwood DSI-RV Water Heater-6 Gallon
Gas flame doesnt want to get bigger when i turn it up?
That is normal. The flame stays the same but will burn longer making the water hotter.
Feb 10, 2011 | Bosch & Tankless LP Hot Water Heater
How do you turn up the temp rheem 40 gal warror class
remove access panels on side of water heater and the thermostat has a dail to adjust to a hotter setting.
Mar 30, 2010 | Rheem Water Heaters
GE Hot Water heater about 2 months old - today no hot water -
Turn dial from vacation to higher setting liker warmer if not hotter if not already there. If this does not work let me know. Please rate. jj505
Mar 29, 2009 | General Electric GE SmartWater Household...
Low amount of hot water
You say a very new water heater. You won't get 40 gallons of hot water from a 40 gallon water heater because the continuing influx of cold water will cool your hot water down. However, it appears that your bottom water heater element needs replacing. If the top element is bad, you'll get no hot water. If your bottom element is bad, you'll get "some" hot water. Try replacing the bottom element. DON'T FORGET to turn off the electricity AND water first (closeby towels are also handy)!
Mar 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
21 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
