Question about Microsoft Windows XP Home Edition
Computer very slow
Cpu 100% nothing open, config sys brings up 14 folders
  • 1 more comment
  • Anonymous Jan 20, 2009
    thank you,
    spoolsv.exe keeps ou fluctuating between 35-95 ( system)
    firefox.exebetween 0-57 (dave)
    taskmgr.exe 0-5 (dave)
    regards
    Dave
  • Justin Wolery May 11, 2010
    I would also select the "User" tab in task manager and see which processes are running under your user account, if you see more then 2 or 3 instances of "rundll32" under you user account or any filenames that look like random letters or gibberish you may have a virus infection. Also you should Run> msconfig and check to see what is loading in the startup tab, uncheck anything that isnt necesarry for the pc's hardware to work correctly, then save and reboot.
    If that doesnt improve it i would recomment taking the pc to a local repair shop.
  • BOZAPE
    BOZAPE May 11, 2010
    Open the taskmanager (Right click on the task bar and select Taskmanager).
    Select the PROCESS windows.
    Order by CPU.
    Which process are using the 100% or high cpu utilization?
  • 139 Answers
Scan your system with sav32cli search in google open up the 3rd result in google and you have a solution in hand. Due to work pressure I can't give a direct link sorry
Posted on Jan 20, 2009
Sys config: 80gb hd 2gb ram os:win7 animation are
Is everything quite slow? Sounds to me that your hard disk is almost full - check to see that there is 8gb (10%) free space The other possibility is that you have too much on the desktop (file size not number of files).
Oct 04, 2013 | Dell Computers & Internet
Tip
Computer CPU/Processor maxed 100%
Is your computer experiencing a CPU that is running at 100% Is your computer experiencing slow performance?
You can view your CPU utilization and other performance stats using Windows Task Manager. Press Ctrl + Alt + Delete and bring up Task Manager. Go to the performance tab.
The top of this screen should show your CPU stats.
In Linux you can use the TOP command,
Type the top command:
$ top
A CPU that is running at 100% utilization is not necessarily a problem. When the computer is booting up, or coming out of sleep mode, it may max out the CPU which is normal. The CPU will be utilized fully in order to bring the computer up as fast as possible. Some computers will even utilize the CPU while it is idle, to complete background task such as disk cleanup and file reallocation.
A problem will occur if the CPU stays maxed out. If it stays at 100% for more than a couple of minutes, you may be experiencing degraded computer performance.
Steps to reduce performance degradation.
-In a limited number of cases, software bugs can cause CPU utilization to spike. You will know this is the case if you are using a computer program(that is not hardware intensive like photo/video editors) and notice degraded computer performance. Check your CPU stats while running the program. If this is the case, check online for solutions and possible upgrades which resolve bugs in the software.
-You can reduce Windows start up programs, which will speed up the boot/wakeup process. You can do this from the MSCONFIG window. Go to Start > and in the run box type "msconfig". Go to the "startup" tab and you can uncheck which programs you do not want to start with Windows.
-A majority of the time a computer will get to a point were the hardware will need to be upgraded in order to handle the work you are doing. Common computer upgrades are memory, cpu, motherboard and hard drive.
-G33k
on May 15, 2011 | Computers & Internet
Sys fan nor cpu fan working and black screen
Try a known , good working PS. If that does not do it, you have serious mo bo issues.
Mar 27, 2017 | ASUS PTGD1-LA Motherboard
Stack overflow at line 598
Stacks are reserved memory that programs use to process hardware events. A stack overflow occurs when there is not enough space in memory to run the hardware interrupt routines. To resolve these behaviors, you can modify the "STACKS=" line in the Config.sys file, eliminate terminate-and-stay-resident program (TSRs), and eliminate hardware conflicts.
When Windows delivers an error message that is related to an internal stack overflow, there is not enough space in memory either set aside or available to handle the calls that are made to the computer hardware. There are several things to consider when you troubleshoot this behavior:
  1. The Config.sys startup file may not be properly configured for the Windows installation. Use the following values: STACKS=64,512 ;(this is the maximum allowed)
    FILES=60
    BUFFERS=40 If you are using the dual-boot capabilities in Windows, the Config.sys and Autoexec.bat files may not contain the correct configuration to run Windows. When you are dual-booting between Windows 3.x and Windows, these files may not have been renamed back to Config.dos and Autoexec.dos.
    Examine the Config.sys file to determine if files such as Himem.sys or Emm386.exe are loaded from a folder other than the Windows folder. If so, boot Windows by using the Safe Mode Command Prompt Only option. Rename the Config.sys file to Config.dos and the Autoexec.bat file to Autoexec.dos, and then restart your computer.
  2. Some TSRs may be interfering with Windows. Disable any non-boot device drivers in the Config.sys and Autoexec.bat files. If you install from Windows 3.x and you receive a stack overflow error message, check the Win.ini and System.ini files for non-Windows-based programs or drivers that are loading.
  3. There may be an incompatible hardware configuration. Check the port and IRQ settings of the network adapter, sound card, and modem. Make sure that there are no COM2/COM4 or COM1/COM3 conflicts and that no devices are sharing IRQs. Disable or remove conflicting devices.
  4. The computer may need a BIOS upgrade. Check the BIOS version and contact the manufacturer of your computer for information about a BIOS upgrade.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 28, 2010 | Microsoft Computers & Internet
I have pictures on the card that show up on my
Keep the memory card in your camera....plug your camera into the computer and then turn your camera on...options should start to appear on the screen...follow the questions to get your solution...
Nov 08, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
My laptop is running very slowly. HELP !
This issue can be caused by any of the below possibilities.
Hard disk drive is short on available disk space.
Several software programs have been installed/uninstalled leaving behind bad files and/or confusing the software.
Data Corruption.
Computer is overheating.
Bad Hardware.
Additional information:
If your Internet is slow this document does not contain information about this issue. See document CH000986 for additional information about why your Internet connection may be slow.
PC Solution:
Below are steps for Microsoft Windows that should help speed up the computer or determine why the computer is running slow.
Not enough hard disk drive space
If you have a hard disk drive that is 10GB or smaller, ensure that there is at least 200MB of hard disk drive space free. If you have a hard drive larger than this size, verify that there is at least 500MB of free hard disk space. This available space allows the computer to have room for the swap file to increase in size as well as room for temporary files.
Hard drive corrupted or fragmented
Run Scandisk or something equivalent to help ensure that there is nothing physically wrong with the computer hard disk drive.
Run Defrag to help ensure that data is arranged in the best possible order.
Background programs
Remove or disable any TSRs or programs that automatically start each time the computer boots. .
Hardware conflicts
Verify that the Device Manager has no conflicts, but if conflicts are present, resolve them.
Issues with Windows XP prefetch
If you have Windows XP try deleting all files in the prefetch directory. These are prefetch files and can lower system resources if loading programs no longer being used. See our prefetch definition for additional information about prefetch.
Issues in Windows 95 / 98 autoexec.bat / config.sys
If you are using Microsoft Windows 95 or Windows 98 and do not plan on running any MS-DOS programs from MS-DOS follow the below steps.
Click Start, Run and type command and press enter.
In the MS-DOS window type cd\ to get to C:\> and then type ren autoexec.bat autoexec.ch and ren config.sys config.ch
This will rename your autoexec.bat and config.sys and help make sure memory is being optimized through Windows.
Computer or processor is overheating
Make sure your computer and processor is not overheating, excessive heat can cause a significant decrease in computer performance some processors will even lower the speed of the processor automatically to help compensate for the heat related issues. .
Specific operating system basic troubleshooting
Try running through the basic troubleshooting steps for your operating system.
Erase computer and start over
Virus Problem
Be sure that your computer is not virus or spyware infected
Run antivirus program
Finally, if none of the above solutions resolve your issues, it is recommended that you either reinstall Windows and/or erase everything and then start over.
Hardware issues
If your computer continues to be slow after going over each of the above recommendations it's possible that your computer is experiencing a more serious hardware related issue such as a failing component in the computer. This could be a failing or bad CPU, RAM, Motherboard, or other component.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Gateway Computers & Internet
I'm using windows 98 SE. Two weeks ago my computer started to slow down when I open folders looking for files. But when i'm using a software or navigation on the web it works normally. I tried to make a...
Hello mboisvert,
There are many excellent suggestions to help solve your problem of 'slow opening' folders in W98 & improve the efficiency of the system, but one underlying factor that always should be adhered to - otherwise it can cause the slow opening of all folders throughout the entire Hard Drive - is that within the My Documents folder it's necessary to keep the approx TOTAL number of Folders & Subfolders within it to under 100 ..best even to keep it under 75. The MD's folder has a unique operating structure and in some cases exhibits a flaw where if you place too many folders in it, the effects of that can cause the slow opening of all folders on that drive - and the more folders you open in a session - the slower it will get!
The fix is simple and effective: if you're noticing a slowdown when opening folders anywhere on your drive while you have more than 100 folders in MD's, then simply create another folder on your Desktop, or anywhere, and name it whatever you'd like, then Cut all excess folders out of the MD's folder and then Paste them into your new folder, and reboot. ..you'll see all your folders open normally now if you had the above anomaly.
Regards,
ChancesR
Jul 23, 2008 | Computers & Internet
How do i reboot windows vista. i knwo theres a way to do it not from the CD and it returns it to how u go it out of the box. please let me know thanks
If you are using MS-DOS 6.0 or later, you can use multiple configuration menus or the CHOICE.COM program to configure your system. For more information on using these options under MS-DOS 6.0 or later, type HELP MULTI-CONFIG or HELP CHOICE at the MS-DOS command prompt and then press ENTER. To create the files to automatically restart your computer with the appropriate configuration, do the following:
Create a directory on your hard drive called C:\CONFIGS. Create the CONFIG.SYS and AUTOEXEC.BAT files you need to boot your system for HIMEM.SYS and applications that require it, with the following names: c:\configs\config.dos c:\configs\autoexec.dos Create the CONFIG.SYS and AUTOEXEC.BAT files you need to start your system for the program that conflicts with HIMEM.SYS. Any unique file extension can be used. The following example uses 386: c:\configs\config.386 c:\configs\autoexec.386 The following DEBUG script can be used to create a small executable file called REBOOT.COM. This file, when executed, will cause your system to restart. To create the file, change to the DOS directory, and type the following: debug reboot.comEnter the following information, pressing ENTER key after each line: A 100 ; Debug instruction for assemble MOV AH,0D ; Disk Reset INT 21h ; causes SmartDrv 4.x to write cache MOV AX, 40 ; set up segment addressing MOV DS,AX DS: OR BYTE PTR [17],0C ; equivalent of pressing CTRL+ALT MOV AX,4F53 ; Issue a "DEL" (53h = DEL scan code) INT 15h ; EMM386 sees this & shuts down. DS: MOV WORD PTR [72],1234 ; Set REBOOT flag to Warm-Boot (0=cold) JMP F000:FFF0 ; Execute the internal restart routine <CR> ; This line must be blank (just hit ENTER) R CX 20 ; File size to be written to disk (in hex) N REBOOT.COM ; Filename W ; Write the file to disk Q ; Quit Debug NOTE: The REBOOT.COM file created with this debug script is compatible with SMARTDrive and its write-behind cache feature. The instructions in REBOOT.COM cause SMARTDrive to write (flush) its write-behind cache to disk before the computer is rebooted.
The following commands can be used to copy and rename the configuration files to the root directory of the C drive and restart the computer. To simplify the process, you can put these commands into batch files.
To start your machine for Windows, use the following commands: copy c:\configs\autoexec.dos c:\autoexec.bat copy c:\configs\config.dos c:\config.sys reboot.com To start your machine for the 386 application, use the following commands: copy c:\configs\autoexec.386 c:\autoexec.bat copy c:\configs\config.386 c:\config.sys reboot.com
Apr 29, 2008 | Computers & Internet
CPU Speed too slow
hi
your sys is really so good.
check in task manager identify some unknown proess .
they are virus.
clean all temp files.
disk cleanup run.
scan your sys with avast,quick heal ,symantec one bye obe with update definition in safe mode.
then u get some malware and viruses.
then delete it.
after that run chkdsk utiliity.
then defragmen all drive
now your sys really speed up.
best of luck my friend.
Mar 25, 2008 | IBM ThinkPad T30 2366 Notebook
Internet explorer 7
Virus or spyware. I would do a virus check for free on my partner website
TRENDMICRO.COM
Use Housecall.
It will scan your whole computer and remove for free anything that is causing the Prob
Questions I live in Californina and Can help
Feb 13, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
