Question about Transcend JetFlash 530 - USB flash drive - 8 GB
I hve a problem with my jetflash 8gb transcend pendrive
First i have copied some files to pen drive.then i don't do safety remove as i always do.i removed it after some minutes i reinserted it but the all files in my pen drive disappears but when i click properties the space used is the same. help me i have an important data in it...
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
May be your pendrive is infected and all that files are in hidden and read only mode.
Posted on Jan 04, 2013
SOURCE: I am having Jetflash v10 16 gb model 'Transcend' USB Flash Drive.
Try formatting the drive using NTFS and re -copy your stuffs again. If it fails to copy as you want, then delete the partition and format it again .
Posted on Mar 26, 2009
SOURCE: write - protected message when I connect my Transcend 8GB Pendriv
write protection on transcend 16gb pen drive
Posted on Feb 10, 2009
saqeb
  • 47 Answers
SOURCE: Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
Posted on Jan 28, 2009
Shereena_M
  • 601 Answers
SOURCE: Remove Write protection from the Pen drive permanently
Hi Abhishek,
There is a samll tab in the which will have lock mark, move it to unlock.
That will remove the write proterction, still have issue replace the drive.
Thanks
Smith
Posted on Jul 15, 2009
bronk50
  • 27725 Answers
SOURCE: I have 8GB pendrive of
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart or you might tick one box then return after its finished the first repair the tick the second box
hope this helps
Posted on Mar 16, 2011
Pendrive not working
try wiping the usb plug on the pen drive with an alcohol wipe. i had to wipe mine and then wiggle it around in the computers usb port when i had that problem
Oct 10, 2012 | Transcend 8GB JetFlash 560 Pen Drive,...
Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Nov 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a transcend 4GB pendrive. it has become write protected due to virus. how can i format it. i have tried many processes but can't get my pendrive formatted.pls help
Some usb keys or flash drives have a little switch thatlocks it & makes it read only. Try looking for something like this. Or youtry following these steps:
For USBdrives:
1. Open Start -> Run...
2. type diskmgmt.msc and press enter
3. right click on the partitin you want to format (where the leter and is)
4. select 'Delete Partition...' and confirm
5. right mose button in the same place and select 'Create partition'
6. select primary partition
6. select , file format, disk leter, label etc should be all right if youleave defaults.
7. click ok
This will recreat the partition and format it in proper way.
I hope this information will be helpful. Thank you for using FixYa!
Please vote if it helped you.
Jun 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How can i convert 4GB pendrive to 8GB ...?
can i convert the 4gb pendrive to 8gb..?
this is because the mc used in both are same, how to change default firmware installed in mc that flashes and make mc to increase its intensity of storage...if any1 kno..pls tell me da process..
Aug 19, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend JetFlash V10 -8GB when opened shows ''insert disk''
your pendrive is out of order Transcend JetFlash V10 -8GB whenever you purchase a pendrive only
buy a 1,2,4GB
Jul 22, 2009 | Electronics - Others
Hi Abhishek,
Thanks
Smith
Jul 15, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Transcend 8 GB Pendrive showing write protected
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
It worked for me and my friends....
Other pen drive users may visit there vendors site and download any fromat utility present there for your model.
Nov 07, 2008 | Transcend (589307) Media
8GB TRANSCEND PEN DRIVE - WRITE PROTECTION DELAYED - REMOVE WRITE PROTECTION
Use following link to download recover jetflash from transcend site.
http://www.transcend.nl/support/dlcenter...
note that the data on the pen drive will be erased. so back it up before you run it.
  • 1 week ago
Sep 16, 2008 | Electronics - Others
Transcend JetFlash 530 - USB flash drive - 8 GB Logo
94 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
