The start/pause button has been pushed in too far and I would like to know can I fix this???
  • 22 Answers
That happened to my machine once, I gently wiggled it whilst very quickly giving it a springy type push and it popped out again. if that doesn't work, Make sure your hands are DRY and UNPLUG the machine from elec remove lid and reach inside and release the spring.
Posted on Jan 03, 2013
2 Suggested Answers
  • 240 Answers
SOURCE: Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Posted on Apr 26, 2009
Alesis masterlink ml-9600 pauses during recording
  • alesis support
  • from what i can see about the device firmware update is probably what it needs...
  • Alesis Update
  • there address and phone is in top link.....sorry cant get much information from the company with out an account...
Nov 11, 2013 | Alesis MasterLink ML-9600
Trips out, signals F-1
pushed pause cancel button. canceled the load. turned power back on, re entered what I wanted the machine to do. pressed start. So far so good.
Sep 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How do you get the wash cycle off of ''pause''? I put it on pause to add more clothes, and don't know how to get it started washing again.
Hello and welcome to Fixya.
Starting it again from a "paused" status should just be a matter of pushing and holding for a couple of seconds the start button, provided the door is closed properly.
Hope that answer`s your question. Good luck.
macmarkus :)
May 19, 2010 | Kenmore HE3T Washer
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Fisher and Paykel smart drive 708 will not start
unplug the washer and wait 10 or 15 mins sometimes it takes time to reset the program
Aug 23, 2009 | Washing Machines
Fisher & Paykel front loader dryer ED56AU
What about the lint sensore, it may be faulty, sending a signal of a fire hazard.
Aug 11, 2009 | Fisher DEIX2 Dryer
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Pause button is stuck
hi soblessed,
the plastic push lock that holds the button is possibly broken, but hopefully the mechanism incorporated with the button has not been damaged because it was pushed too far.
to have this issue resolved, you may use something pointed to nudge the button from its place and free it from being stuck. Or you may remove the screws from the button, freeing the upper case from the lower case exposing the other side of the controls, so you can push the pause button out.
regards,
voodoo
Apr 19, 2009 | Emerson PD6870RD Radio/Cassette/CD Boombox
''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Mar 26, 2009 | Dishwashers
How do i remove write protection from my music so i can copy it onto my mp3 player?
I had this same problem with a cheapie mp3 I bought off of ebay. I read on another site to make sure that your player is not set to 'pause'. On this shuffle it's hard to tell so I pushed the pause/play button just once and then had absolutely no problems in copying music files or listening.
Others have said to flip a write-protected switch from on to off. But as far as I can tell mine had no such switch. Also have heard to format and start all over but I wasn't able to do that either.
So please try to push your pause/play button and try again.
Jan 28, 2008 | Delstar DS 31024 MP3 Player
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
