Question about Microsoft Windows XP Professional for PC
BSOD in windows XP Professional
Hi, I don't know what happened but suddenly the blue screen of death appear on my XP professional. I didn't even realize it still does that. I had it when I had windows 95 and 98 but since then I never saw it. Can anyone give me some advice what do to do?
  • Anonymous Oct 22, 2008
    i have some problem the problem is when iam going to install vista os in compaq laptop the process is going in first stage and then we restart in second stage the process still waiting not any response then i change vista cd no any response please replay this message as soon as possible
    thank you
    pradeep
A stop error occurs when Windows XP Professional stops responding. Stop error messages can be caused by hardware or software malfunctions. The error messages appear on a blue or black background. The following steps, which also appear on the stop error screen, help you find out the cause of a stop error and how to fix the problem. To troubleshoot General Stop Errors: 1. Restart your PC. Unplug each new hardware device, one at a time, to see if this resolves the error. Try to run any hardware diagnostic software supplied by your computer manufacturer. 2. If this is a new installation of hardware or software, contact the manufacturer for any Windows XP Professional updates or drivers you might need. Click Get support, or find information in Windows XP newsgroups (under "Ask for assistance") and then click Get help from Microsoft in the left-hand column. 3. Check the Microsoft Hardware Compatibility List (HCL) to verify that all your hardware and drivers are compatible with Windows XP Professional. 4. If you can start Windows XP Professional, check the System Log in Event Viewer for additional error messages that might help identify the device or driver causing the problem. 5. If you cant start Windows XP Professional, try to start your computer in safe mode, and then remove or disable any newly added programs or drivers. 6. Search the Microsoft Knowledge Base for "Windows XP Professional" and the number associated with the stop error you received. Specific Stop Errors Some stop errors display descriptive messages such as "DATA_BUS_ERROR" that can help you determine the exact solution for the error. This section discusses how to troubleshoot specific stop errors, based on the type of error you receive.
Posted on Jun 26, 2007
  • Anonymous Jun 26, 2007
    Software and device driver errors:
    0x0000001E KMODE_EXCEPTION_NOT_HANDLED__0X000000D1 DRIVER_IRQL_NOT_LESS_OR_EQUAL__0x000000EA THREAD_STUCK_IN_DEVICE_DRIVER__0x00000050 PAGE_FAULT_IN_NONPAGED_AREA__0X0000000A IRQL_NOT_LESS_OR_EQUAL__0x0000007B INACCESSIBLE_BOOT_DEVICE__0x0000009F DRIVER_POWER_STATE_FAILURE__0XC000021A STATUS_SYSTEM_PROCESS_TERMINATED__0XC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
    Note: Stop errors 0x0000001E, 0x0000000A, and 0x0000007B can also be caused by general hardware errors. If the steps provided here do not resolve these errors, see the steps under Hardware Failure Errors.
    1. Follow the procedure under General Stop Errors. If the stop error persists, try the following steps.
    2. Check that the driver identified in the stop message is signed and certified by Windows Hardware Quality Labs (WHQL).
    3. If you have a video driver not supplied with Windows XP Professional, try switching to the standard VGA driver or to a compatible driver supplied with Windows XP.
    4. Run Recovery Console, and allow the system to repair any errors that it detects.__If the error occurred immediately after RAM was added to the computer, the paging file might be corrupted or the new RAM might be either faulty or incompatible.
    File system errors:
    0x00000023 FAT_FILE_SYSTEM
    0x00000024 NTFS_FILE_SYSTEM
    Follow the procedure under General Stop Errors. If the stop error persists, try the following steps:
    1. If you're using a small computer system interface (SCSI) adapter, obtain the latest Windows XP Professional driver from the hardware vendor, disable the sync negotiation for the SCSI device, verify that the SCSI chain is correctly terminated, and check the SCSI IDs of the devices.
    2. If Windows XP Professional can't run Chkdsk, move the drive to another computer running Windows XP Professional, and run the Chkdsk command on the drive from that computer.
    Hardware Failure errors:
    0x0000000A IRQL_NOT_LESS_OR_EQUAL
    0x0000007F UNEXPECTED_KERNEL_MODE_TRAP
    0xC0000218 UNKNOWN_HARD_ERROR
    Note: Stop errors 0x0000001E, 0x0000000A, and 0x0000007B can also be caused by software and device driver errors. If the steps provided here do not resolve these errors, see the steps under Software and Device Driver Errors.
    Follow the procedure under General Stop Errors, earlier in this book. If the stop error persists, try the following steps:
    1. To troubleshoot hardware failure stop errors check that the devices on your computer have drivers that are signed and certified by Windows Hardware Quality Labs (WHQL).
    2. Run Recovery Console, and allow the system to repair any errors that it detects.
    If nothing works you will have to uninstall Windows XP, Click Start, click Control Panel, click Add or Remove Programs. Click Windows XP Professional, click Remove and then follow the instructions on your screen.
How to solve the problem?
Posted on Dec 02, 2008
    President:
  • 2,961 Answers
The screen normally gives a clue as to the problem with a description and code, but it could be anything from a driver to memory error, if you are able to get into windows, as you should, go to start>control panel>administrative tools> and click on the event viewer icon, then in the left pane of the window go through all the catagories and see if there are any red crosses, if so right click on the line and select properties and it will send you to microsoft for a fault description or a solution.
I found a great tutorial on Blue Screen XP errors.
Posted on Jul 19, 2008
Hello, I got bsod when i use BitTorrent 6.1.1 to download movies through my wireless networking. if i use wired lan within home or office there is no problem. I have used original set up disk to reinstall wireless networking programs which obtained from manufacturer (for my Samsung laptop X30) and the problem persists. the exact error message is like this:
STOP: 0X000000D1 (0X89800000, 0X00000002, 0X00000000, 0XB28E9988)
W22n51.sys--Adress B28E9988 base at B2875000: Datestamp 404c5c4c.
Please help with a solution.
Mansur.
Posted on Nov 15, 2008
SOURCE:
Microsoft Windows XP Professional for PC Logo
18,849 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
