Question about Kyocera Office Equipment & Supplies
Kyocera FS-C5300DN - We replaced toner M cartridge but it is still saying Replace Toner?
We replaced the Toner M colour cartridge but after stating it was adding Toner - the printer immediately stated that Toner M needs replacing. How do I get rid of the message & get the printer going again?
  • 217 Answers
SOURCE: Toner and Imaging Unit issues
If this IS a CLP-510, first make an information confirmation print.
Press MENU, then press ENTER, and ENTER again.
Look at the counter for the imaging unit, is it a low count confirming that you have indeed replaced it ?
If not you will need to reset the counter.
Check the counters for the toner cartridges, and check the capacity of the cartridge. On a CLP-510 the image counter for the toner is held on the chip on the cartridge (which also identifies the capacity of the cartridge).
There have been some faulty (oiginal Samsung chips), and of course re-manufactured cartridge chips could fail (many re-manufacturers don' test their cartridges before dispatch, they don't have the facility to do so without starting the count on the chip (or 'bowing' the reset fuse on a CLP-500 cartridge). VERY few re-manufacturers can test these cartridges without starting the count.
Sometimes the 'replace xxxxx toner' messages are caused by toner on the three contacts on the side of the cartridge, or their mating contacts inside the printer. Rarely, this can be caused by a faulty circuit board.
Posted on Jan 12, 2008
n25an
  • 622 Answers
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
Posted on Dec 24, 2009
SOURCE: states waste toner full, do i have to replace ? fs
I did not have a rubber plug, but removed the covers (sinked screws) and emptyd out the waste (aprox. 500 grams!).
apart from a fight with wife (I did it on the dinnertable) it did the job.
Posted on Feb 27, 2010
SOURCE: Hi, moved my FS 3830 and it now says check waste
If you are in Ho Chi Minh City,you can go to Dinh Cao Trading and Service Company at 63 Vinh Vien street district 10 and we'll solve the problem for you.
Posted on Mar 16, 2010
Testimonial: "We took machine there this morning. Will lwt you know how it goes..."
  • 670 Answers
SOURCE: I keep cleaning the toner/printer
How are you cleaning the tank? Just dumping the contents into a trashcan may not work. The printer uses a light sensor to detect whether the tank is full. When the light does not shine through the clear window of the tank, the printer thinks that the tank is full. Sometimes cleaning the window with a cotton swab will make it work, but it can be difficult since the location of the window with respect to the opening of the tank is not a straight shot.
Another way to clean it would be dump the waste toner into ther trashcan. Tap the tank a few time to get as much of the toner out. Then add some soap and water into the tank and seal the tank opening with the green lid. Then shake the soapy water in the tank for a about a minute. Then dump the soapy toner/water out. Rinse again with just water and and allow it to dry. You don't have to get the tank completely clean, just enough to stop the waste tank error message.
Hope this helps.
Posted on Nov 22, 2010
How do I reset the toner level?
you can't there is a crum chip on the toner cartridge that would need to be replaced. refilling is a bad idea by the way. it ends up costing you alot more in repairs on down the line
Nov 16, 2015 | Kyocera FS-1030D Laser Printer
My kyocera fs-1370dn suddenly says it is missing a developer unit
The developing unit is where the toner sits upon.Remove the toner cartridge and ensure that the developer unit is correctly inserted.Then re-instal the toner cartridge.
Mar 12, 2015 | Kyocera Office Equipment & Supplies
My cartridge is full of toner but the printer says it needs to be replaced, how do i reset the cartridge?
You can't. The toner levels are calculated and approximated. Make sure you use genuine Kyocera toner and replace it.
Sep 27, 2013 | Kyocera 1T05JK0US0 Model TK-152K Black...
[PRINTER ERROR]Please replace Toner
it seems that the problem is with your printer toner..so replace the toner. may be the toner is faulty
May 31, 2011 | Kyocera FS-1016 Printer
Mar 10, 2010 | Kyocera Mita FS-3830N Laser Printer
Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
Jan 24, 2010 | Kyocera FS-C5015N Laser Printer
Display says 'replace cartridge' & 'clean printer'. after cleaning out exces toner from where the waste bottle goes and around the toner cartridge and the cartridge that the toner sits in.
Try shaking gently the toner cartrige!!! This may help mix the toner which may be stuck together especially if the printer is not used often enough or stored in a place that is not as specified (humidity, ventilation, etc...).
Nov 13, 2009 | Kyocera FS-3900DN Laser Printer
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
