Question about Compaq Armada E500 Notebook
Internal battery Where is the internal battery located? Also, cannot remember the password to start computer. How can I reset it or bipass to get into bios screen?
  • larryb2111 Jan 22, 2009
    Hi I have ordered a replacemnt batterie for the time and date ,,,,i just need to get access to it and plug it in can anyone show a picture or discribe the steps to follow thanks Larry
  • 23 Answers
Hi,The battery can be replaced by removing (unclipping)the top switch panel above the keypad,you may also need to remove the small circuit board below this,the replacment battery which should have a couple of wires attached and a small plug slips down the back of the motherboard at the top left hand side,it i connected by the plug to the board,as fr your password Im sorry but I cant help you with that one.
Posted on Feb 01, 2009
Asus s200e bios startup
do you mean the windows login password or the drive password? if it is happening before windows boots up, it is easy to fix, just open the laptop and short the internal battery for 5 seconds, that will wipe out all system password, but you have to reconfigure the bios settings,
Aug 14, 2014 | ASUS VivoBook S200E-RHI3T73 Laptop...
Bios passwords
Locate Phoenix BIOS Passwords
The basic input/output system, or BIOS, is a program that acts as a digital liaison, managing communications between peripherals and the operating system.
Because the BIOS is critical to the operation of a PC, some computer manufacturers and workplaces employ a password for security.
If the password is lost or has been reset through electrostatic discharge, it would be impossible to guess without the aid of computer forensics.
Sometimes you can gain access to the BIOS through the keyboard, depending on the computer, but typically the solution is mechanical.
Contact your computer manufacturer.
All computer manufacturers have websites with technical support available.
Have your computer model number and serial number ready.
If the manufacturer is unable to help locate a password, standard back-door passwords may help.
So-called back-door passwords may help you access the BIOS. Try using the following back-door passwords to access the BIOS: phoenix, PHOENIX, CMOS, BIOS. BIOS passwords are case sensitive.
3 Contact the motherboard's manufacturer if the back-door passwords failed.
Find the motherboard's website for technical support.
You will need to open the computer case if you do not know the motherboard brand.
Electrostatic discharge can reset a BIOS password.
Shutdown and unplug the computer.
Unplug the monitor and all peripherals from the PC, including speakers and USB devices.
Ground yourself by wearing an antistatic wristband clipped to the metal case, or touch something metal before you open the case.
Use the screwdriver to loosen and remove the screws from the case. Look for the motherboard, the largest circuit board inside, attached to one side of the case.
5
Printing on a motherboard can be hard to see without a magnifying glass. Examine the motherboard for a brand name.
A good place to start searching is near the processor, the large square box on the motherboard. A flashlight and magnifying glass are especially useful for a clear view of the motherboard.
The brand name could be printed anywhere or, sometimes, not at all.
6
The motherboard battery is round and fairly flat. Locate the CMOS battery while you have the case open.
If contacting the motherboard manufacturer failed, you will have to remove the battery.
The battery is circular, about the size of a dime, but as thick as two to three stacked dimes.
Do not disconnect or remove anything yet. Removing the CMOS Battery
7
Note the location of any cables that need to be disconnected. Use the digital camera to take pictures of the motherboard, or sketch the location of cables and connectors.
f any components or cables need to be moved or unplugged to reach the battery, you want to remember their exact location.
8
Leave the battery out for at least 20 minutes. Remove the CMOS battery carefully so as not to snap or break the clamps.
Leave the battery out for 20 to 25 minutes to allow the capacitors to completely discharge any memory. Avoid touching anything else in the computer.
9
Tighten the case screws when done. Return the battery to the motherboard, and reconnect any cables that were disconnected in the case. Close the computer case and tighten the screws.
10
Look for the setup message on the monitor. Turn on the computer and closely watch the monitor for the "Entering Setup" message that appears before Windows starts.
The message will tell you which key to press to enter the BIOS setup.
You may need to reboot a few times to see the message, as it appears on the screen for just a few seconds.
11
Carefully read the settings information on the monitor. Follow the directions on the monitor for changing the date, boot sequence, and any other settings.
Work slowly and read the screen directions thoroughly.
Be alert and cautious.
Once the settings are saved, the system will start, and the password will have been removed.
http://www.computerhope.com/help/phoenix.htm
Phoenix BIOS help and simulation
Reset a Phoenix BIOS Password
The Phoenix BIOS (Basic Input/Output System) is a simple program that resides on the CMOS ROM (Read Only Memory) chip on a computer system's motherboard.
There are a couple of major BIOS manufacturers, including Phoenix. Each BIOS contains a set of initial parameters that can be set using a simple text interface.
A security feature is built into the program that allows the computer user to set a password for the BIOS.
When activated, the computer will not complete the booting up process until the password is entered. If the password is unknown, then it must be reset in order to gain access to the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Turn off the computer and unplug all cables from the back of the case, labeling each one if it isn't color coded. This must include the power cable, which should also be unplugged from the wall or power strip.
·2
Open the computer case by removing the screws on the back that hold the side panel on the frame.
Some systems will use thumb screws and no tools will be required.
However, most computer systems will require the use of a Phillips head screwdriver.
·3
Locate the CMOS battery.
It will be located near the CMOS chip and looks like a large watch battery (see the link below).
http://www.dewassoc.com/support/bios/bios_password.htm
Check to see if there is a three-pin jumper switch near the CMOS battery as well.
It is only present on some motherboards and will be used in step 4 if it is there.
·4
Remove the CMOS battery.
Leave the battery out for 30 minutes to allow any residual electricity in the CMOS ROM to discharge.
This will effectively reset all settings in the CMOS to default values and clear the password.
If the three-pin jumper is present, leave the CMOS battery in place.
Move the jumper on the pins from the side it is on to the opposite pins.
Then attach the power cord and reboot the system.
It will not boot up but actually clear the CMOS settings.
Remove the power cord and move the jumper back to its original pins. ·5
Re-attach the computer system cover and replace the screws holding it in place.
Re-attach all of the cables to the back of the computer and reboot.
Your Phoenix BIOS password is now reset and you will be able to boot into your operating system.
You may need to re-enter the CMOS settings if it doesn't recognize all of your components such as expanded memory or DVD drives, etc.
Dec 29, 2013 | Computers & Internet
Cant remerber bios password on presario A900 laptop and cant unplug internal battery
Step 1:
Acer laptops are equipped with a BIOS utility. The BIOS (which stands for "Basic Input Output System") acts as an interface between the hardware and software installed on the computer. On some computers, a BIOS password may be required in order to boot the computer and make changes to the BIOS settings. If you are unable to access the BIOS settings and do not know how to reset the BIOS password, you might be tempted to send the computer back to the manufacturer for repair. Fortunately, that's not necessary as there is a simple way to do this on your own.
Go to "Start," then perform a search for "Command Prompt." The Windows Start button is located in the lower-left corner of your computer screen. Double-click on "Command Prompt" to open the application. You will need to use MS-DOS commands to reset the BIOS password. Type the following commands one by one in the order shown: debug o 70 2E o 71 FF quit Make sure that you are typing the letter "o" and not a zero at the beginning of the second and third commands. Reboot your computer by clicking "Start," "Shutdown," and then "Restart." The BIOS password will now be reset to default.
Mar 05, 2013 | Acer Power 1000 PC Desktop
How can i open my asus laptop when master password disable
If you set BIOS Passford, for some reasons it doesnt bipass, the only way to reset is to open laptop (Disassemble) where you need to take RTC (Real Time Clock)Battery for couple of min and reinstall. This process make all the settings in the BIOS to RESET. Hope this help.....
Dec 08, 2012 | ASUS Bios Chip:K43br, K43sa, K43sd, K43sm,...
How to remove a password so that i can start
more info needed, i.e type of computer make model laptop,windows version, bios version,
have you tried starting the computer in safe mode ? press F8 during boot i.e after post screen but before windows startup screen, select safe mode and see if you can get access via administrator account, then you can reset via user in control panel, last solution would be to pull out the internal watch battery to reset the bios and wipe any password stored
but really more information needed, try what ive mentioned and good luck
Sep 23, 2012 | Samsung NC110 Netbook
My sister gave me a Compaq evo computer. When i turn it on it goes right to a screen that says Power-on password with a picture of a key. She doesn't know what the password was and it doesn't let...
It seems to be BIOS password, if you don't remember or don't have the BIOS password you have to reset the password by opening your CPU cover and removing the CMOS coin battery, this will reset the BIOS password but dont forget to return back the battery and start using your PC.
Regards,
JJ
May 15, 2011 | Compaq Evo D500 PC Desktop
How to unlock my hp6930p notebook bios password
Hack HP Computer Password ' Erase HP Desktop / Laptop Password Without Being a Hacker In my received E-mail that people ask to recover lost PC password, a quarter of people are using HP computers. So I prepare this tutorial specially for these HP users
May 11, 2011 | HP EliteBook 6930p Notebook PC
I dont remember the maxtor 300 password
Inorder to reset the BIOS password, you have to open the laptop from the back, locate the CMOS battery, remove it and press down the terminal (with the help of a screw driver) for 5 sec, now turn ON the computer (keepon holding the terminal) short the BIOS. Now, Turn off the computer and restart the computer, it will reset the BIOS password.
Thanks and regards,
Anil.B.R
Sep 25, 2010 | Maxtor OneTouch II 300 GB Hard Drive
I boiught used computer but cannot start up bvecause of passcode
you need a password reset utility. these can be found on this site
You want to get a bootable cd that will allow you to reset the administrator password so that you can get into your os.
If the password comes up on a bios screen you need to open up the computer and disconnect the round bios battery and then reboot the computer. Remember to reinstall it later.
Jan 18, 2009 | Computers & Internet
Password
If you mean the BIOS password that comes up in the first few screens, then you will have to Disable the password in the BIOS utility. To open the BIOS utility, press F2 during the logo screen.
Then go to the Password screen and disable it.
To reset the windows logon password, you will need a boot disc such as "UBCD4Win" . Boot from the disc and use the password recovery utility on the disc to reset the pass word or to create another user without a password to start the computer from.
Feb 01, 2008 | Acer Aspire 3680 Laptop
Compaq Armada E500 Notebook Logo
83 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
