The photocopies come out very dark.
And the paper comes out folded on the top left corner, sometimes.
  • 62 Answers
Normally this is cause by some media (paper) remians on the path,. clean up your machine with air (on pressure)
Posted on Jan 22, 2009
Re - Phaser 8200DP Solid wax printer; very often doesn't pick up paper from bottom tray, resulting in 'jam' message. Also, tends to fold the top corner of a two-sided (duplex) print job on exiting after...
Clean the pick up rollers with alcohol. They need to be really grippy.
If it's folding the corner of paper I expect there is a bit of torn paper stuck in it.
Oct 29, 2013 | Xerox Phaser 8200 Laser Printer
Paper is coming out scrunched (folded) and sometimes torn at the top left corner.
Make sure the printer is clear of any paper jams and don't load the tray full of paper, load it 75% full but not 100%.
Feb 28, 2011 | HP LaserJet 3380 All-In-One Printer
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
Paper feed problem from both tray 1 & 2
There is a long set of sensor flags on the bottom of the paper input unit that can get stuck and not move freely. This will cause jams from both trays. Try unplugging the printer, removing the toner cartridges and tray 2. Turn the printer on its back or side. You will see a long, black plastic bar with flags on it that runs the length of the paper input unit. make sure it moves freely.
Feb 17, 2009 | HP LaserJet CP3505n Printer
the reason why i ask that because if the fold looks like its been pressed then its before the fuser but if its loose than its after. And thats how we can determine where it begins
Feb 12, 2009 | HP LaserJet 4350 Printer
Loading paper into a 1205-3 Victor calculator?
I just got the same calculator without a manual. Fold over one corner of the tape so it almost goes to the other edge of the paper, making a 45 degree angle. Insert the tip of the tape into the slot at the back of the calculator and push it ahead until the corner goes under the black plastic part. I had to push it ahead a little more until it was starting to come upward on the other side. Push the arrow button at the top left corner of the keypad to advance the tape.
Jan 25, 2009 | Victor 1205 Calculator
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
Bell & Howell Copiscan Spectrum corner problems
It can be a nightmare to find out what is causing the dog ear page or folded page at the corner. Check your glass **** inside the scanner to make sure its seated in the scanner properly. The big one is the check the metal paper guides in the scanner paper path. If a guide is bend it will hook the paper and cause it to fold over.
Oct 15, 2007 | Bell & Howell B we Bell & Howell Spectrum...
My printer folds top lefthand corner intermittently? why?
Do you run labels through the unit? If so, ther is probably a little bit of the glue or label that is inside the feed asm. Hard to find it. Have you tried to open the top door when the paper has fed just under the toner cartridge to see if the bent edge begins at that point. Did the problem appear right after the new maintenance kit? Do you still have the old fuser asm? Reinstall the old fuser and see if problem goes away.
Jul 31, 2007 | HP LaserJet 4250n Printer
